Holyarrs/holyarrs releases
New releases of holyarrs/holyarrs are posted here automatically.
Join @releases-holyarrs to get a DM and a bell for every release.
holyarrs/holyarrs 1.3.2
Added
  • Import files by hand right from the Library Add menu. (#692)
  • Movie files are checked before import: length, video and audio. (#611)
  • Plugins can open a site’s bot check for you. (#865) (#918)
  • Approved anime can go to its own folder. (#855)
  • Delete a single movie file from the Library tab. (#821)
  • Import a library keeps going with the page closed. (#712)
  • Pick rules get an SDR 4K trait and catch more AI upscales. (#610)
  • Pick anyway on a season search takes releases named for the show. (#764)
  • YTS is built in as a movie search and feed. (#817)
  • Titlovi joins the subtitle sites. (#688)
  • The owner and an API key can come from files at start. (#660)
  • Discord Alerts come as one card with the poster, and mark upgrades. (#733)
  • The Alerts panel shows an alert’s full text. (#852)
  • Library alerts open their title; search alerts name show and episode. (#830)
  • A plugin can bring its own download type. (#864)
  • A plugin can list and remove its own links. (#854)
  • The approve screen shows the remote-access warning. (#699)
  • The No file lock tag explains what it means. (#698)
  • Download counts show on first view and on Language Packs. (#851)
  • A movie in a 1080p and a 4K Radarr becomes one title. (#648)
  • Files keep scene name and group, and score with the original language. (#783)
  • One Source per site when Prowlarr, Sonarr and Radarr are imported. (#669)
  • Naming comes over with the Radarr-style words. (#857)
  • Removing a copy’s protection asks in the app’s own dialog. (#150)
  • Show settings get a Future seasons only option. (#720) (#721)
Fixed
  • Back keeps you on the Explore or New & Popular tab. (#753)
  • Each watch link shows once when a server is added twice. (#717)
  • Rescan commands rescan the title, or the whole Library. (#808)
  • Shows with hundreds of episodes on a network share now import. (#682)
  • A show no longer takes another show’s picture or episodes. (#342)
  • Feed checks no longer time out on big libraries. (#747)
  • SABnzbd speed goes only to jobs that are downloading. (#838)
  • Empty Usenet job folders are deleted after a move import. (#724)
  • Imports retry when files from a remote downloader arrive late. (#829)
  • qBittorrent works behind proxies that compress answers, like qui. (#846)
  • DUAL or MULTi names now say audio is checked at import. (#797)
  • German DL keeps the original language in imported Pick rules. (#858)
  • MULTi releases without your language are skipped before download. (#750)
  • “amp” in a release name matches “&”. (#762)
  • Anime names with alt-titles or [Group][Title][Episode] read right. (#763)
  • MKV audio with no language tag is read as English. (#850)
  • IPTorrents sizes with odd spaces are read right. (#833)
  • Single sign-on started from another address goes through. (#708)
  • An expired sign-in goes to sign-in, not stuck on Reconnecting. (#793)
  • Only warnings and errors light the Settings dot. (#786)
  • Plugin limit labels stay whole and boxes stay on one line. (#862)
  • The report says tags stay behind, not that HolyArrs has none. (#672)
  • Forgetting saved keys while HolyArrs runs now says how. (#676)
  • An empty show folder no longer breaks an import. (#845)
  • Who watched what no longer breaks on two same-name accounts. (#734)
  • Old import reports open, and plugin screens drop garbled symbols. (#925)
Changed
  • The key icon’s bar starts at the ring’s edge. (#683)
  • Plain permission names, full-width own-server box, one-line TV shows button. (#945)
Security
  • Release builds keep signing keys apart and ship with provenance. (#839)
Thanks
Thanks to @​dhruv1220, @​NotCavnfox, @​diblaze, @​lancewilhelm, @​mbartsch, @​wai-lau, @​wlatic, @​wozniakpawel, u/Blegrand15, @​maaximal, @​prantzos, @​aguanitallc, @​ansuehu, @​aritmp, @​bobberb, @​gorpet, @​sittingmongoose, @​soybean-alien, @​sunboyy, @​toverux, @​tydude001, @​venzellucas, to AlmostEpic89, chesh1r3k and Harybo on Discord, and to xrandallx on the forum.
holyarrs/holyarrs 1.3.3
Fixed
  • Sources work through an HTTP proxy like Gluetun again. (#768)
  • Pick rules in Check releases can be changed from Standard. (#714)
  • SABnzbd downloads import when the job folder is the save folder. (#861)
  • Knaben feed checks ask only for the kinds you want. (#806)
  • Developer plugins with settings show the Settings button. (#834)
  • Install on a developer plugin’s card uses its folder. (#835)
  • Owner hosts keep every port saved for a host name. (#836)
  • History shows subtitle and cleanup details. (#823)
  • Import takes a release the Pick rules chose as equal. (#826)
Changed
  • Cleanup says All languages, with a hint. (#824)
holyarrs/holyarrs 1.3.4
Added
  • Outside links now sit higher on the title page. (#745)
  • Music import shows which artist is which in the match list. (#741)
Fixed
  • 4K files with no quality in the name now show as 4K. (#874)
  • Episode names from TheTVDB come in your language. (#769)
  • Future-only show asks with nothing listed show Upcoming, not Processing. (#716)
  • Deleted files leave the holding folder right on their keep time. (#802)
  • Removing an artist stops its running refresh. (#805)
  • Sync fix only retimes subtitles HolyArrs saved. (#837)
  • Who watched what opens when two accounts share a name. (#734)
Security
  • Thanks to Andreas Døhl for reporting the signing-key gap fixed in 1.3.2. (#839)
holyarrs/holyarrs 1.3.5
Fixed
  • A missing movie file no longer blocks its new file. (#798)
  • Prowlarr music indexers now search for albums. (#849)
  • Language packs install again on new versions. (#767)
  • One rescan marks a moved file missing. (#809)
  • Movies with no poster get one in the scheduled refresh. (#810)
  • Long title pills clear the search bar; spacing fixes. (#931)
  • Show imports read quality from the grabbed release. (#770)
  • Imports trust the grab when a file shortens the show name. (#950)
  • Staff can change a show’s only Version. (#796)
  • Show settings say Kept in part when some is kept. (#927)
  • The empty season note fits on one line. (#928)
  • Calendar jumps back to the current day again. (#929)
  • Found music files match after an artist refresh. (#735)
  • Album folders like “5_55 [FLAC 24-96]” match their album. (#898)
  • Import by hand can pick the album’s Pressing. (#777)
  • Plugins get an API token without the file lock. (#746)
  • Newly published plugins show when none are installed. (#924)
  • An empty number setting turns Save off. (#922)
  • Developer plugins no longer show a Signed chip. (#921)
  • The bell counts the same alerts the panel shows. (#909)
  • The alerts panel scrolls so pinned rows aren’t cut off. (#936)
  • The same Downloader warning names the shared category. (#952)
  • Paused search-only Sources retry once their wait is over. (#711)
  • Home no longer waits for pictures on every visit. (#758)
  • Partly fixed: tvdb: search without a TheTVDB key says why. (#732)
Security
  • Plugins trust a new main signing key and an offline backup key. (#960)
holyarrs/holyarrs 1.3.6
Fixed
  • Plugin lists update again after the signing key change.
Community plugins
holyarrs/holyarrs 1.3.7
Added
  • The owner picks what new people can do when they join. (#691)
  • History shows why a search failed. (#999)
Fixed
  • Searching a title with its year, like “Strike 2017”, finds it. (#989)
  • Show files named by the show’s letters, like “DBS”, import again. (#950)
  • Two Downloaders on one qBittorrent no longer share categories. (#952)
  • IPTorrents added with a cookie shows sizes again. (#930)
  • The Plugins Refresh button fetches the lists right away. (#1006)
Community plugins
holyarrs/holyarrs 1.3.8
Added
  • Needs a decision alerts open the download they are about. (#939)
Fixed
  • Imports that worked on a retry show as imported in History. (#1064)
  • Settings no longer stays blank after leaving My account. (#1032)
  • The bell count matches the pinned alerts in the list. (#909)
  • Pinned alerts are no longer cut off at the bottom. (#936)
  • Kodi picks up new shows and clears removed ones. (#1024)
  • Single-file torrents from rdt-client import again. (#984)
holyarrs/holyarrs 1.3.9
Fixed
  • Album tracks named with “&” or a shorter title import again. (#1049)
  • Usenet albums are no longer refused for their file count. (#1046)
  • An album grab that waits in the queue keeps all its tracks. (#1048)
  • Sources work again through proxies like Gluetun. (#718)
  • A failed metadata lookup no longer counts as refreshed. (#1013)
  • Plugins get their key when the owner allows running without the file lock. (#746)
  • A file matched by hand shows its quality right away. (#1038)
holyarrs/holyarrs 1.3.10
Added
  • Link an album to its folder by hand, with a preview. (#898)
  • Plugins pick their folders from your Library folders. (#1030)
  • Settings warns when tags leave titles with no Source to search. (#1003)
Fixed
  • Stall times go under an hour; dead grabs no longer block them. (#1058)
  • Library shows titles in your language, like Explore. (#1044)
  • A refused movie download is cleared from its Downloader. (#1053)
Thanks
Thanks to @​Jaylouisw, @​wai-lau, @​NiftyMule, @​NotCavnfox, @​alexneo2003, @​wlatic, @​ArBohe, @​booooza and @​Burner3212.
holyarrs/holyarrs 1.3.11
Added
  • Plugins can add subtitle sites, even ones that write subtitles from the audio. (#327)
  • Save a movie or episode file to your device. (#784)
  • Pick the page HolyArrs opens on: Home, Explore, New & Popular or Library. (#785)
  • Set tags on a title from its Library tab or when adding it. (#1001)
  • Want an episode in one Version only, like just the dub. (#842)
  • qBittorrent can move imported torrents to one category or one per type. (#1098)
Fixed
  • Releases rank by the seeder counts the trackers really see. (#1059)
  • Symlinked downloads import when links are followed. (#754)
  • A file replaced in place is read again on rescan. (#832)
Community plugins
