HI I NEED HELP What is going on? My Pangolin panel shows it is online
GIT NOT WORK
timeout
INFO: 2025/05/26 19:13:53 Starting ping check
INFO: 2025/05/26 19:13:53 Ping attempt 2
INFO: 2025/05/26 19:13:53 Pinging 100.89.128.1
INFO: 2025/05/26 19:13:53 Started tcp proxy from 100.89.128.4:59009 to 192.168.1
.5:5244
INFO: 2025/05/26 19:13:53 Started tcp proxy from 100.89.128.4:48315 to 127.0.0.1
:5244
WARN: 2025/05/26 19:14:03 Ping attempt 2 failed: failed to read ICMP packet: i/o
timeout
INFO: 2025/05/26 19:14:05 Ping attempt 3
INFO: 2025/05/26 19:14:05 Pinging 100.89.128.1
what do you mean git not work
YES git NOT WORK 100.89.128.1 PING error
This topic has had no activity for 30 days. It will close in 7 days unless someone replies.
  • Still broken? Reply with your current versions and logs, and it stays open.
  • Fixed it? Post what worked and mark it as the solution, so the next person finds it.
