***Help***Single Authelia Server for Multiple Endpoints Nginx Proxy Manager
If you authelia setup in a docker container behind an NGINx proxy on Server 1.
If you successfully use set $upstream_authelia http://[host_ip]:9091/api/verify; to use authelia to protect endpoints on Server 1.
However, say on Server 2 if you have other endpoints and want to protect. If you use
set $upstream_authelia https://authelia.mydomain.com/api/verify;
the redirect fails and you get a 500 error.
you can use below authelia NPM config fles on remote endpoints securely.
On the server hosting Authelia :
Head over to advanced and paste the following :
location /api/verify {
set $upstream_authelia http://authelia:9091;
proxy_pass $upstream_authelia;
location / {
client_body_buffer_size 128k;
#Timeout if the real server is dead
proxy_next_upstream error timeout invalid_header http_500 http_502 http_503;
# Advanced Proxy Config
send_timeout 5m;
proxy_read_timeout 360;
proxy_send_timeout 360;
proxy_connect_timeout 360;
# Basic Proxy Config
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $http_host;
proxy_set_header X-Forwarded-Uri $request_uri;
proxy_set_header X-Forwarded-Ssl on;
proxy_redirect  http://  $scheme://;
proxy_http_version 1.1;
proxy_set_header Connection "";
proxy_cache_bypass $cookie_session;
proxy_no_cache $cookie_session;
proxy_buffers 64 256k;
set_real_ip_from 10.0.0.0/8;
set_real_ip_from 172.0.0.0/8;
set_real_ip_from 192.168.0.0/16;
set_real_ip_from fc00::/7;
real_ip_header X-Forwarded-For;
real_ip_recursive on;
On the endpoint you’re trying to protect :
location /authelia {
internal;
set $upstream_authelia https://<FQDN of Authelia>/api/verify;
proxy_pass_request_body off;
proxy_set_header Content-Length "";
# Timeout if the real server is dead
proxy_set_header X-Original-URL $scheme://$http_host$request_uri;
proxy_set_header X-Forwarded-For $remote_addr;
proxy_buffers 4 32k;
send_timeout 5m;
proxy_read_timeout 240;
proxy_send_timeout 240;
proxy_connect_timeout 240;
location / {
set $upstream_app http://<upstream app>:8006;
proxy_pass $upstream_app;  #change name of the service
auth_request /authelia;
auth_request_set $target_url https://$http_host$request_uri;
auth_request_set $user $upstream_http_remote_user;
auth_request_set $email $upstream_http_remote_email;
auth_request_set $groups $upstream_http_remote_groups;
proxy_set_header Remote-User $user;
proxy_set_header Remote-Email $email;
proxy_set_header Remote-Groups $groups;
error_page 401 =302 https://<FQDN of Authelia>/?rd=$target_url;
send_timeout 5m;
proxy_set_header Connection upgrade;
proxy_set_header Accept-Encoding gzip;
proxy_set_header 'Access-Control-Allow-Origin' *;
