Hedgedoc/hedgedoc releases
New releases of hedgedoc/hedgedoc are posted here automatically.
Join @releases-hedgedoc to get a DM and a bell for every release.
hedgedoc/hedgedoc HedgeDoc 1.12.3
This release should fix the bugs in the withdrawn releases 1.12.1 and 1.12.2 by repairing the database.
Therefore, please inspect the release notes for 1.12.1 and 1.12.2 as well.
Note: This release changes the local database to enforce uniqueness on the email column for local accounts.
In theory your instance should not have duplicate email addresses. However, it might be good to ensure this is
true for your database as well and remove duplicate user entries otherwise.
The repair migrations - especially for SQLite - are a bit overcautious in order to not destroy any data.
In case your database has some weird situation which the repair does not recognize, it might abort and print a
message to the log. So, please check your log on the first start of your instance after this update.
Also remember to create a backup before updating.
Security fixes
  • GHSA-5q59-fhxv-4r9x reports a possible authorization check bypass when validating OAuth2 role or SAML group claims.
Bugfixes
  • Fixed the failing migrations of 1.12.1 and 1.12.2
  • Fixed registration breaking due to missing default values
  • Fixed login breaking due to a circular dependency import
  • Fixed permission check accessing invalid properties on realtime socket vs HTTP API
  • Fixed the first slide being printed as an empty page in Firefox
  • Fixed a crash on startup when DATABASE_URL is set and the config file has no section for the current environment, and CMD_DB_URL now takes precedence over the legacy DATABASE_URL
Contributors
