***Guide*** Pfsense, Tailscale, Raspberry Pi, Ubuntu, WiFi, Bluetooth
To install Tailscale on pfSense, you can follow the instructions provided for OPNsense with slight modifications. Here’s how you can adapt the process for pfSense:
Installation
  1. Access the Shell: Connect to the pfSense console via SSH or through the web interface. From the web interface, navigate to Diagnostics > Command Prompt, and select the “Execute Shell Command” option.
  2. Download the Ports Tree: pfSense, like OPNsense, is based on FreeBSD. However, pfSense does not have the opnsense-code command. Instead, you need to manually fetch and extract the ports tree:
    fetch https://github.com/freebsd/freebsd-ports/archive/refs/heads/main.zip
    unzip main.zip
    mv freebsd-ports-main /usr/ports
  3. Navigate to the Tailscale Port: Once the ports tree is downloaded and extracted, navigate to the Tailscale port directory:
    cd /usr/ports/security/tailscale
  4. Install Tailscale: Build and install Tailscale using the ports collection:
    make install clean
  5. Enable and Start Tailscale: Enable and start the Tailscale service:
    sysrc tailscaled_enable=YES
    service tailscaled start
  6. Verify Tailscale Installation: Check that Tailscale is installed and running:
    tailscale version
Connect to Tailscale Network
  1. Authenticate Tailscale: Add the pfSense machine to your Tailscale network:
    tailscale up
    Follow the provided URL to authenticate in your browser.
Updating Tailscale
  1. Update Process: To update Tailscale, follow these steps:
    make deinstall
    make clean
    make install clean
    service tailscaled restart
Enabling Direct Connections for LAN Clients
For enabling direct connections for LAN clients behind pfSense, you can configure NAT as follows:
  1. Static NAT Port Mapping: Navigate to Firewall > NAT > Outbound and set the mode to “Hybrid Outbound NAT rule generation”. Add new outbound NAT rules for the appropriate address family (IPv4 and IPv6) and ensure “Static Port” is enabled in the translation section.
  2. NAT-PMP: Enable NAT-PMP by navigating to Services > UPnP & NAT-PMP. Enable the UPnP service and allow NAT-PMP port mapping.
Verification
  • Use tailscale ping <node> to verify connectivity between Tailscale nodes.
  • Use tailscale netcheck to diagnose network conditions.
Notes
  • Ensure your pfSense version is compatible with FreeBSD ports.
  • Some commands might need minor adjustments depending on the specific pfSense configuration and setup.
By following these steps, you should be able to install and configure Tailscale on pfSense, enabling it to join your Tailscale network and support direct connections for LAN clients.
To configure your Raspberry Pi to connect to your iPhone’s hotspot over Bluetooth at boot and maintain its own ad-hoc WiFi network, you need to set up both the Bluetooth PAN and Tailscale to ensure seamless connectivity. Here’s a step-by-step guide to achieving this:
Step 1: Bluetooth PAN Setup
  1. Create a Script for Bluetooth PAN Connection:
    Create a script that will handle the Bluetooth PAN connection:
    sudo nano /usr/local/bin/bluetooth_pan.sh
    Add the following script to /usr/local/bin/bluetooth_pan.sh:
    #!/bin/bash
    # Enable Bluetooth
    sudo rfkill unblock bluetooth
    # Start Bluetooth service
    sudo systemctl start bluetooth
    # Start Bluetooth PAN connection to iPhone
    BLUETOOTH_DEVICE="XX:XX:XX:XX:XX:XX"
    sudo bluetoothctl << EOF
    power on
    agent on
    connect $BLUETOOTH_DEVICE
    trust $BLUETOOTH_DEVICE
    exit
    EOF
    # Create and bring up bnep0 interface
    sudo pand -c $BLUETOOTH_DEVICE -n
    sudo ifconfig bnep0 up
    # Request IP address via DHCP
    sudo dhclient bnep0
    Replace XX:XX:XX:XX:XX:XX with your iPhone’s Bluetooth address.
  2. Make the script executable:
    sudo chmod +x /usr/local/bin/bluetooth_pan.sh
  3. Create a Systemd Service for the Script:
    sudo nano /etc/systemd/system/bluetooth_pan.service
    Add the following configuration:
    [Unit]
    Description=Bluetooth PAN Connection
    After=multi-user.target
    [Service]
    Type=simple
    ExecStart=/usr/local/bin/bluetooth_pan.sh
    [Install]
    WantedBy=multi-user.target
  4. Enable the new service:
    sudo systemctl enable bluetooth_pan.service
Step 2: Configure the Ad-Hoc WiFi Network
  1. Edit the dhcpcd.conf file:
    sudo nano /etc/dhcpcd.conf
    Add the following lines:
    interface wlan0
    static ip_address=192.168.4.1/24
    nohook wpa_supplicant
  2. Create the ad-hoc network configuration:
    sudo nano /etc/network/interfaces.d/adhoc
    auto wlan0
    iface wlan0 inet static
        address 192.168.4.1
        netmask 255.255.255.0
        wireless-channel 1
        wireless-essid MyAdHocNetwork
        wireless-mode ad-hoc
  3. Set Up a DHCP Server for the Ad-Hoc Network:
    sudo apt install isc-dhcp-server
  4. Configure the DHCP server:
    sudo nano /etc/dhcp/dhcpd.conf
    subnet 192.168.4.0 netmask 255.255.255.0 {
        range 192.168.4.2 192.168.4.20;
        option broadcast-address 192.168.4.255;
        option routers 192.168.4.1;
        default-lease-time 600;
        max-lease-time 7200;
  5. Specify the interface for the DHCP server:
    sudo nano /etc/default/isc-dhcp-server
    Modify the line to specify wlan0:
    INTERFACESv4="wlan0"
  6. Restart the DHCP server:
    sudo systemctl restart isc-dhcp-server
    sudo systemctl enable isc-dhcp-server
Step 3: Install and Configure Tailscale
  1. Install Tailscale:
    curl -fsSL https://tailscale.com/install.sh | sh
  2. Start and authenticate Tailscale:
    sudo tailscale up
    Follow the URL provided in the terminal to authenticate your device via the Tailscale web interface oai_citation:1,Installing Tailscale to the Raspberry Pi - Pi My Life Up oai_citation:2,How to Remotely Access Your Raspberry Pi from Anywhere Using Tailscale » DIY Usthad oai_citation:3,How to SSH into a Raspberry Pi · Tailscale.
Step 4: Automate the Setup on Boot
To ensure that both the Bluetooth PAN and Tailscale services start on boot, they should be enabled as systemd services. The Bluetooth PAN service is already set up in Step 1. Tailscale should be configured to start on boot automatically.
Step 5: Reboot and Test
  1. Reboot your Raspberry Pi:
    sudo reboot
  2. Verify that the Bluetooth PAN connection is established and that the Raspberry Pi is connected to the iPhone’s hotspot.
  3. Check that the ad-hoc WiFi network is up and running.
  4. Ensure that Tailscale is active and that your Raspberry Pi is accessible via the Tailscale network.
These steps should provide a reliable setup for connecting your Raspberry Pi to your iPhone’s hotspot over Bluetooth while maintaining an ad-hoc WiFi network and integrating Tailscale for remote access.
    #!/bin/bash
    # Enable Bluetooth
    power on
    agent on
    exit
    EOF
    sudo dhclient bnep0
    [Unit]
    [Service]
    Type=simple
    [Install]
    interface wlan0
    auto wlan0
        address 192.168.4.1
        wireless-channel 1
    sudo tailscale up
    sudo reboot
To refactor your article on integrating MinIO and Tailscale, you can leverage several features and best practices from Tailscale’s documentation. Here are some key aspects to consider:
Tailscale Features for Integration
  1. ACLs and Device Management:
    • Access Control Lists (ACLs): Define policies to control which devices and users can access specific resources. This ensures secure and controlled access to your MinIO setup.
    • Device Management: Use tags and device management features to organize and secure your network. Tags help to manage access policies dynamically without modifying ACLs every time a new device is added.
  2. Routing and Networking:
    • Subnet Routing: Set up a subnet router to allow devices on the Tailscale network to access resources in other private networks. This is useful if your MinIO server is in a different subnet.
    • Exit Nodes: Configure an exit node for traffic routing, enabling devices to access the internet through a specific node. This can help route traffic securely through a trusted server.
  3. MagicDNS and DNS Management:
    • MagicDNS: Simplify the management of hostnames within your Tailscale network. MagicDNS automatically resolves the names of your Tailscale nodes, making it easier to connect to your MinIO server without needing to remember IP addresses.
    • DNS Configuration: Customize DNS settings to ensure your Tailscale network uses the preferred DNS servers for resolving addresses.
  4. SSH and Auth Keys:
    • Tailscale SSH: Enable SSH access over Tailscale, providing secure, direct SSH connections between your devices. This feature is particularly useful for managing your MinIO server remotely.
    • Auth Keys: Use auth keys to automate device authentication and enrollment, facilitating the setup of new devices without manual intervention.
  5. Logging and Monitoring:
    • Logging and Auditing: Implement logging to monitor access and usage within your Tailscale network. This helps in maintaining security and troubleshooting issues.
    • Log Streaming and Webhooks: Stream logs to external systems and use webhooks to trigger actions based on specific events in your Tailscale network.
Implementation Steps
  1. Set Up Tailscale:
    • Install Tailscale on all devices that need to connect to your MinIO server.
    • Configure MagicDNS for simplified hostname resolution.
  2. Configure Access Controls:
    • Define ACLs to restrict access to the MinIO server to only authorized devices and users.
    • Apply tags to devices for easier management and dynamic policy updates.
  3. Enable Subnet Routing and Exit Nodes:
    • Set up a subnet router if your MinIO server resides in a different network.
    • Configure an exit node for secure internet access through your Tailscale network.
  4. Utilize Tailscale SSH and Auth Keys:
    • Enable Tailscale SSH for secure management access.
    • Use auth keys for seamless device enrollment and authentication.
  5. Monitor and Audit:
    • Implement logging to monitor network activity.
    • Set up log streaming and webhooks for real-time monitoring and automated actions.
Additional Resources
By leveraging these features and best practices, you can ensure a secure and efficient integration of MinIO with Tailscale, making your setup robust and easier to manage.
