Guide: Adding Custom Error Pages to Pangolin Resources
This guide will walk you through implementing custom error pages for your Pangolin resources using the Middleware Manager or in general without middleware manager.
Overview
When users encounter errors like 404 (page not found) or 502 (bad gateway), we’ll redirect them to a dedicated error page service that displays professionally designed error templates. This is accomplished using Traefik’s error middleware and a dedicated error page container.
Step 1: Add Error Pages Service to Docker Compose
First, add the error pages service to your docker-compose.yml file:
error-pages:
  image: ghcr.io/tarampampam/error-pages:3
  container_name: error-pages
    TEMPLATE_NAME: connection  # Choose from available templates: ghost, connection, shuffle, etc.
  labels:
    traefik.enable: true
This service uses the tarampampam/error-pages container which provides many pre-designed error page templates. You can choose different templates by changing the TEMPLATE_NAME value.
Step 2: Add Error Pages Service to dynamic_config.ymlTraefik Configuration
In your dynamic_config.yml Traefik configuration, add the error pages service:
http:
    error-pages-service:
      loadBalancer:
        servers:
          - url: "http://error-pages:8080"
Full File
http:
  middlewares:
    redirect-to-https:
      redirectScheme:
        scheme: https
  routers:
    # HTTP to HTTPS redirect router
    main-app-router-redirect:
      rule: "Host(`pangolin.development.hhf.technology`)"
      service: next-service
      entryPoints:
        - web
      middlewares:
        - redirect-to-https
    # Next.js router (handles everything except API and WebSocket paths)
    next-router:
      rule: "Host(`pangolin.development.hhf.technology`) && !PathPrefix(`/api/v1`)"
      entryPoints:
        - websecure
      tls:
        certResolver: letsencrypt
    # API router (handles /api/v1 paths)
    api-router:
      rule: "Host(`pangolin.development.hhf.technology`) && PathPrefix(`/api/v1`)"
      service: api-service
      entryPoints:
        - websecure
      tls:
    # WebSocket router
    ws-router:
      entryPoints:
        - websecure
      tls:
    error-pages-router:
      rule: "HostRegexp(`.+`)"          # Catches any host
      priority: 10                     # Low priority, acts as a fallback
      entryPoints:
        - web                        # Assigns to the 'web' entrypoint
        - websecure
      middlewares:
        - error-pages-middleware@file
    next-service:
      loadBalancer:
        servers:
          - url: "http://pangolin:3002"  # Next.js server
    api-service:
      loadBalancer:
        servers:
          - url: "http://pangolin:3000"  # API/WebSocket server
      loadBalancer:
        servers:
Step 3: Create an Error Pages Middleware
Now you need to add an error pages middleware. You can do this in two ways:
Option A: Using the Middleware Manager UI
  1. Open the Middleware Manager UI (http://your-server:3456)
  2. Go to the “Middlewares” tab
  3. Click “Create Middleware”
  4. Fill in the following details:
    • Name: Error Pages Middleware
    • Type: errors
    • Configuration (JSON):
      "status": ["400-599"],
      "service": "error-pages-service",
      "query": "/{status}.html"
  5. Click “Create Middleware”
Option B: Using Templates File
Alternatively, add the middleware configuration to your templates.yaml file:
middlewares:
  - id: error-pages-middleware
    name: Error Pages Middleware
    type: errors
    config:
      status:
        - "400-599"
      service: "error-pages-service"
      query: "/{status}.html"
Place this file at ./config/middleware-manager/templates.yaml and ensure it’s mounted in your middleware-manager container as shown in your docker-compose.yml.
Step 4: Apply the Error Pages Middleware to Resources
Now you can apply the error pages middleware to your resources in two ways:
Option A: Apply to Individual Resources
  1. In the Middleware Manager UI, go to the “Resources” tab
  2. Click “Manage” next to the resource you want to protect
  3. Click “Add Middleware”
  4. Select “Error Pages Middleware” from the dropdown
  5. Set the priority (recommended: 100, lower numbers have higher priority)
  6. Click “Add Middleware”
Option B: Apply as a Global Fallback (Recommended)
To apply error pages to all resources, add a low-priority catch-all router in your Traefik dynamic configuration:
http:
  routers:
    error-pages-router:
      entryPoints:
        - websecure             # For HTTPS
        - web                   # For HTTP
      middlewares:
      service: error-pages-service
This creates a fallback router that will handle any request that results in an error status code.
Step 5: Test Your Error Pages
To test your error pages:
  1. Restart your Docker Compose stack to apply changes
  2. Try accessing a non-existent URL on your domain
  3. You should see the custom error page instead of the default browser error
For specific error codes, you can test with:
  • 404: Access a non-existent URL
  • 502: Temporarily stop a backend service
  • 503: Configure rate limiting and exceed the limit
Advanced Customization
Using Different Templates
The error-pages container offers multiple templates. Change the TEMPLATE_NAME environment variable to try different designs:
  • ghost - Minimal ghost design
  • shuffle - Colorful design with moving elements
  • noise - Static design with noise pattern
  • connection - Network connection themed
  • hacker-terminal - Terminal style theme
Creating Custom Templates
For fully custom error pages:
  1. Create a custom template directory
  2. Mount it to the error-pages container:
error-pages:
  # ... other configuration
    - ./custom-error-pages:/app/templates/custom
    TEMPLATE_NAME: custom
  1. Create HTML files named after status codes (e.g., 404.html, 500.html)
Customizing Error Page Content
You can customize the error page text by setting additional environment variables:
error-pages:
    ERROR_PAGES_TITLE: "Our Company - Error Occurred"
    ERROR_PAGES_BACK_URL: "https://www.example.com"
    ERROR_PAGES_BACK_TITLE: "Return to homepage"
  1. Error pages not showing: Check Traefik logs for routing issues
  2. Wrong error page content: Verify the correct template is selected
  3. Service unreachable: Ensure the error-pages container is running and healthy
By following this guide, you’ve successfully added custom error pages to your Pangolin resources, improving user experience when errors occur.
Would anyone have got this working with more recent versions of Pangolin (v1.4.x) and Middleware Manager v3.0.3 ?
Using the above guides, finding this is failing and traefik is reporting:
{“level”:“error”,“entryPointName”:“websecure”,“routerName”:“websecure-error-pages-router@file”,“error”:“middleware “error-pages-middleware@file” does not exist”,
{“level”:“warn”,“entryPointName”:“websecure”,“routerName”:“websecure-error-pages-router@file”,“time”:“2025-12-27T10:32:16Z”,“message”:“No domain found in rule HostRegexp(.+), the TLS options applied for this router will depend on the SNI of each request”}
I have to check. Technically it should work no matter which version but currently lots going on with traefik and docker. So not sure. I am on 3.5 traefik and last time I checked it was working. Will you after 1st
in the docker compose added Ports: - 8080:8080 and got this going. However if I try going to a made up url (i.e. abc.my-domain.com ) the browser gets the certificate warning message, as the traefik self-signed certificate is being used. Is this correct or is there a way to stop this?
I personally realized if i do wildcards, then this can happen. What i do is I add each domain(Cloudflare DNS) rather than set a wildcard to avoid this. Maybe there are better ways to do this with wildcards. It is a pain but i guess future me won’t be happy :upside_down_face:.
@po_tato could you paste how you enter multiple domains to be ‘recognised’? TIA
My “multiple domains" are in Cloudflare. I setup each domain xyz.domain.tld and point it to my pangolin VPS. That’s about it.
Is it possible to add this without Middleware Manager?
@Bundas18 Guide: Deploying Custom Error Pages in Traefik
