GeoIP not working (traefik-log-dashboard discussion #142)
:speech_balloon: GitHub discussion traefik-log-dashboard #142 in Help, started by balc11 on GitHub
I’ve setup the traefik log dashboard but I am continuously getting error with the GeoIP
Failed to open GeoIP database: [Error: ENOENT: no such file or directory, stat ‘/app/node_modules/geolite2-redist/dist/GeoLite2-City.mmdb’] {
errno: -2,
code: ‘ENOENT’,
syscall: ‘stat’,
path: ‘/app/node_modules/geolite2-redist/dist/GeoLite2-City.mmdb’
Below is the docker-compose.yml
traefik-agent:
image: hhftechnology/traefik-log-dashboard-agent:dev-dashboard
container_name: traefik-agent
- ./data/logs:/logs:ro
- ./data/geoip:/geoip
- ./data/positions:/data
# Log Paths
- TRAEFIK_LOG_DASHBOARD_ACCESS_PATH=/logs/access.log
- TRAEFIK_LOG_DASHBOARD_ERROR_PATH=/logs/access.log
  # Authentication
  - TRAEFIK_LOG_DASHBOARD_AUTH_TOKEN=token
  # System Monitoring
  - TRAEFIK_LOG_DASHBOARD_SYSTEM_MONITORING=true
  # GeoIP Configuration
  - TRAEFIK_LOG_DASHBOARD_GEOIP_ENABLED=true
  - TRAEFIK_LOG_DASHBOARD_GEOIP_CITY_DB=/geoip/GeoLite2-City.mmdb
  - TRAEFIK_LOG_DASHBOARD_GEOIP_COUNTRY_DB=/geoip/GeoLite2-Country.mmdb
  # Log Format
  - TRAEFIK_LOG_DASHBOARD_LOG_FORMAT=json
  # Server Port
  - PORT=5555
healthcheck:
  test: ["CMD", "wget", "--no-verbose", "--tries=1", "--spider", "http://localhost:5555/api/logs/status"]
  interval: 30s
  timeout: 10s
  retries: 3
  start_period: 10s
:speech_balloon: Join in here or on GitHub.
balc11 commented on GitHub:
It was because I was using the dev-dashboard, the main github page can probably be updated to use latest instead of dev-dashboard. Once I updated to latest the error is gone.
florianreiser-droid replied in a thread on GitHub to balc11:
Hi, I actually have the same problem (same error message) but I have always used hhftechnology/traefik-log-dashboard-agent:latest and hhftechnology/traefik-log-dashboard:latest.
My dashboard start looks like this:
▲ Next.js 15.5.9
✓ Starting…
Added environment agent to database
Initializing Traefik Log Dashboard Services…
Starting Historical Data Archival Service…
Historical data storage is disabled
✓ All services initialized successfully
Service Manager auto-initialized
✓ Ready in 635ms
Updated environment agent in database
[Instrumentation] Starting background scheduler (30min interval)…
Fetching from agent [Environment Agent]: http://traefik-agent:5000/api/logs/access?position=-1&lines=1000&tail=false
Agent [Environment Agent] returned 1000 logs
errno: -2,
code: ‘ENOENT’,
syscall: ‘stat’,
And the agent:
#[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 env.go:27: No .env file found, using system environment variables
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 main.go:21: Starting Traefik Log Dashboard Agent…
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 main.go:22: Access Log Path: /logs/access.log
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 main.go:23: Error Log Path: /logs/traefik.log
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 main.go:24: System Monitoring: true
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 main.go:25: Port: 5000
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 main.go:32: Authentication: Enabled
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 state.go:63: Loaded 1 position(s) from /data/.position
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:30 main.go:78: Server listening on port 5000
[TRAEFIK-LOG-DASHBOARD] 2025/12/15 15:38:50 system.go:348: Root disk stats: total=37.23 GB, used=6.78 GB, free=28.88 GB, percent=18.2%
So I am actually surprised to find that your agent is referencing GeoIP as mine is not. I will further investigate…
