system
October 20, 2025, 10:10am
GitHub discussion traefik-log-dashboard #95 in Help , started by rantanlan on GitHub
First, let me say thanks for this; I’ve already located several issues regarding my setup with it.
Right now I’m struggling to get the geolocation to work. The agent shows the DB is initialized.
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 env.go:29: No .env file found, using system environment variables
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:21: Starting Traefik Log Dashboard Agent...
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:22: Access Log Path: /logs/access.log
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:23: Error Log Path: /logs/access.log
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:24: System Monitoring: true
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:25: Port: 5001
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:29: GeoIP: Enabled
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 location.go:52: GeoLite2 City database loaded successfully
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:36: GeoIP: Successfully initialized
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:50: Authentication: Enabled
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 routes.go:69: Loaded 1 position(s) from /data/.position
[TRAEFIK-LOG-DASHBOARD] 2025/10/20 10:00:55 main.go:95: Server listening on port 5001
Not sure where to look or how the geolocation is determined. Any hint where to look would be appreciated!
Using JSON logs for Traefik, the rest seems to get parsed fine…
Join in here or on GitHub .
system
October 20, 2025, 3:35pm
2
hhftechnology commented on GitHub :
you have to share you compose file first , so i can help you with it
system
October 27, 2025, 1:33pm
3
rantanlan replied in a thread on GitHub to hhftechnology :
added:
traefik-agent:
image: hhftechnology/traefik-log-dashboard-agent:latest
container_name: traefik-log-dashboard-agent
# ports:
# - "5001:5001"
- /var/log/traefik:/logs:ro
- /srv/traefik/data/maxmind/data:/geoip:ro
- /srv/traefik/data/maxmind/positions:/data
# Log Paths
- TRAEFIK_LOG_DASHBOARD_ACCESS_PATH=/logs/access.log
- TRAEFIK_LOG_DASHBOARD_ERROR_PATH=/logs/access.log
# Authentication - GENERATE A STRONG TOKEN
- TRAEFIK_LOG_DASHBOARD_AUTH_TOKEN=token
# System Monitoring
- TRAEFIK_LOG_DASHBOARD_SYSTEM_MONITORING=true
# GeoIP Configuration
- TRAEFIK_LOG_DASHBOARD_GEOIP_ENABLED=true
- TRAEFIK_LOG_DASHBOARD_GEOIP_CITY_DB=/geoip/GeoLite2-City.mmdb
- TRAEFIK_LOG_DASHBOARD_GEOIP_COUNTRY_DB=/geoip/GeoLite2-Country.mmdb
# Log Format
- TRAEFIK_LOG_DASHBOARD_LOG_FORMAT=json
# Server Port
- PORT=5001
healthcheck:
test: ["CMD", "wget", "--no-verbose", "--tries=1", "--spider", "http://localhost:5001/api/logs/status"]
interval: 30s
timeout: 10s
retries: 3
start_period: 10s
traefiklog:
traefik-dashboard:
image: hhftechnology/traefik-log-dashboard:latest
# ports:
# - "3000:3000"
- AGENT_API_URL=http://traefik-agent:5001
- AGENT_API_TOKEN=token
- NODE_ENV=production
- PORT=3000
depends_on:
traefik-agent:
condition: service_healthy
# healthcheck:
# test: ["CMD", "wget", "--no-verbose", "--tries=1", "--spider", "http://localhost:3000"]
# interval: 30s
# timeout: 10s
# retries: 3
# start_period: 30s
labels:
traefik.enable: "true"
traefik.http.routers.traefiklog.entrypoints: websecure
traefik.http.routers.traefiklog.rule: HOST(`domain.com`)
traefik.http.routers.traefiklog.middlewares: oidc-auth@file,forwarded-headers@file
traefik.http.routers.traefiklog.tls: "true"
traefik.http.routers.traefiklog.service: traefiklog
traefik.http.services.traefiklog.loadbalancer.server.port: "3000"
traefiklog:
proxy:
ipv4_address: 172.31.191.252
ipv6_address: fd00:1:be:a:7001:0:3e:7ffd
system
November 20, 2025, 3:20am
4
hieuvts commented on GitHub :
@rantanlan Did you try open DevTools on Traefik Log Dashboard (port 3000 on your compose) and fitler XHR request of “access” path like this: https://ibb.co/LDq5LMCn
Post the error response back here.
