| Containerization |
Containerization is like packaging an application into a self-contained unit, a container. It allows the application to run consistently across different environments. |
Example: Packaging a Python web app and its dependencies in a Docker container. |
| Docker |
Docker is an open-source platform for containerization. It simplifies the process of creating, deploying, and running applications in containers. |
Tools: Docker, containerd, CRI-O. |
| Container Image |
A container image is a lightweight, standalone, and executable package that includes everything needed to run an application, such as code, libraries, and dependencies. |
Example: Creating an image for a Node.js application with its runtime dependencies. |
| Container Registry |
A container registry is a centralized repository for storing and distributing container images. It provides a convenient way to share and manage container images. |
Tools: Docker Hub, Google Container Registry, AWS ECR. |
| Container Orchestration |
Container orchestration involves managing the deployment, scaling, and operation of containerized applications in a distributed system. |
Tools: Kubernetes, Docker Swarm, Amazon ECS. |
| Kubernetes |
Kubernetes is an open-source container orchestration platform that automates the deployment, scaling, and management of containerized applications. |
Tools: Kubernetes, kops, Minikube. |
| Pod |
A pod is the basic unit of deployment in Kubernetes, representing one or more containers that are deployed together on the same host. |
Example: Deploying a pod with a frontend and backend container in Kubernetes. |
| Service |
A service in Kubernetes is a logical set of pods and a policy by which to access them, often using a load balancer. It enables stable network access to the pods. |
Tools: Kubernetes Services, Docker Compose, OpenShift Services. |
| Deployment |
Deployment in Kubernetes specifies how a container or set of containers should be deployed and updated in the cluster. It defines the desired state of the application. |
Example: Configuring a rolling update deployment in Kubernetes. |
| Scaling |
Scaling involves adjusting the number of replicas of a container or set of containers based on demand. It ensures that the application can handle varying workloads. |
Tools: Kubernetes Horizontal Pod Autoscaler, Docker Swarm Scaling. |
| Health Check |
A health check is a mechanism for testing the health of a container or set of containers. It helps determine whether a container should be restarted or removed from service. |
Tools: Kubernetes Liveness Probe, Docker Health Check. |
| Volumes |
Volumes provide a persistent storage mechanism for containers. They allow data to be shared between containers and preserved across container restarts. |
Tools: Kubernetes Volumes, Docker Volumes, OpenShift Persistent Storage. |
| Namespaces |
Namespaces in Kubernetes are a mechanism for dividing cluster resources among multiple users or projects, providing isolation. |
Example: Using namespaces to separate development and production environments. |
| Secrets |
Secrets in Kubernetes provide a secure way to store sensitive data, such as passwords or TLS certificates, within the cluster. |
Example: Storing a database password as a Kubernetes Secret. |
| ConfigMaps |
ConfigMaps in Kubernetes store configuration data for use by containers. They allow decoupling configuration from the container images. |
Example: Managing application configuration using ConfigMaps. |
| Resource Limits |
Resource limits in Kubernetes specify the maximum amount of compute resources, such as CPU and memory, that a container is allowed to use. |
Example: Setting resource limits for a Java application in Kubernetes. |
| Rollout |
Rollout is the process of deploying new code or configuration changes to a container or set of containers. It ensures a controlled and managed update. |
Example: Rolling out a new version of a web application in production. |
| Canary Deployment |
Canary deployment is a strategy where a small number of containers running the new code or configuration are gradually increased, allowing for testing before a full rollout. |
Tools: Kubernetes Canary Deployments, Istio Traffic Management. |
| A/B Testing |
A/B testing is a deployment strategy where two or more versions of an application are deployed and tested concurrently, with traffic being routed to different versions. |
Example: Testing two variations of a website to determine user preferences. |
| Blue-Green Deployment |
Blue-Green deployment is a strategy in which two identical copies of an application are run concurrently, with traffic being routed to one while the other is updated. |
Example: Switching traffic from the Blue to the Green environment after an update. |
| Container Runtime |
Container runtime is the software responsible for executing containers on a host. It interprets container images and manages their execution. |
| Container Networking |
Container networking is the process of connecting containers to each other and to the external network. Various drivers enable communication between containers. |
Tools: Default Bridge Driver, Kubernetes Networking, Calico. |
| Multi-Tenancy |
Multi-tenancy allows running multiple isolated workloads on a shared cluster, using mechanisms like namespaces to prevent interference between workloads. |
Tools: Kubernetes Namespaces, OpenShift Multi-Tenancy. |
| Sidecar Pattern |
The sidecar pattern involves adding an auxiliary container (sidecar) to a pod to perform specific tasks, such as logging or monitoring. |
Example: Adding a sidecar container for log processing in a pod. |
| Istio |
Istio is an open-source service mesh platform that provides advanced networking and security features for containerized applications. |
Tools: Istio, Linkerd, Consul. |
| Cloud Native |
Cloud-native refers to applications and infrastructure designed to be deployed in a cloud environment, leveraging containers and modern technologies. |
Example: Developing and deploying microservices in a cloud environment. |
| Microservices |
Microservices is an architectural style where a single application is decomposed into smaller, independent services that can be developed, deployed, and scaled independently. |
Tools: Kubernetes, Docker, Istio. |
| Serverless Computing |
Serverless computing is a model where the cloud provider dynamically allocates resources to run code in response to incoming requests, without managing servers. |
Tools: AWS Lambda, Azure Functions, Google Cloud Functions. |
| Container Security |
Container security involves securing the host system, container images, and runtime environment to protect against threats and vulnerabilities. |
Tools: Clair, Aqua Security, Twistlock. |
| Image Signing |
Image signing is a security mechanism for verifying the authenticity and integrity of container images, using digital signatures and trusted image repositories. |
Example: Signing Docker images using Docker Content Trust. |
| Vulnerability Scanning |
Vulnerability scanning is the process of identifying and mitigating vulnerabilities in container images and runtime environments. |
| AppArmor |
AppArmor is a Linux kernel security module that allows administrators to specify fine-grained access controls for programs running in containers. |
Example: Applying AppArmor profiles in Kubernetes. |
| SELinux |
SELinux is a Linux security module providing mandatory access control (MAC) to prevent unauthorized access to resources within a container. |
Example: Setting SELinux labels for Docker containers. |
| Container Isolation |
Container isolation is the process of separating resources and processes of one container from another, ensuring security and preventing interference. |
Tools: Kubernetes PodSecurityPolicy, Docker Security Mode. |
| Container Placement |
Container placement involves deciding on which host or hosts to run a container or set of containers, based on factors like resource availability and network latency. |
Strategy: Kubernetes Scheduler, Docker Swarm Scheduler. |
| Batch Processing |
Batch processing is the process of running a large number of jobs, often using containers to parallelize work and improve resource utilization. |
Example: Using Apache Flink for distributed batch processing. |
| CI/CD |
CI/CD (Continuous Integration and Continuous Delivery) automates building, testing, and deploying code changes to ensure a consistent and reliable development pipeline. |
Tools: Jenkins, GitLab CI, CircleCI. |
| Rolling Updates |
Rolling updates involve updating containers gradually over time, allowing for a more gradual transition and the ability to roll back if necessary. |
Strategy: Kubernetes Rolling Updates, Docker Swarm Rolling Updates. |
| Persistent Storage |
Persistent storage ensures data is retained across container restarts and host failures. It is crucial for applications that require durable data storage. |
Tools: Kubernetes Persistent Volumes, Docker Volumes, NAS. |
| Stateful Applications |
Stateful applications maintain a persistent state, such as databases. They require persistent storage for data consistency across container restarts. |
Example: Running a stateful MySQL database in Kubernetes. |
| Stateless Applications |
Stateless applications do not maintain persistent state and can be easily scaled horizontally by adding more instances. They are often simpler to containerize. |
Example: Stateless microservices in a cloud-native architecture. |
| Container-Native Virtualization |
Container-native virtualization allows containers to run directly on a host’s kernel without a traditional hypervisor, enhancing performance and resource utilization. |
Tools: Kata Containers, gVisor, runC. |
| Immutable Infrastructure |
Immutable infrastructure involves treating infrastructure components, like servers or containers, as disposable and replacing them rather than modifying in place. |
Tools: Docker, Kubernetes, Terraform. |
| 12-Factor App |
The 12-factor app is a set of best practices for building cloud-native applications, emphasizing factors like codebase, dependencies, and config. |
Example: Adhering to the 12-factor app principles in a microservices architecture. |
| Cloud-Agnostic |
Cloud-agnostic refers to the ability to run containerized applications on any cloud platform, avoiding vendor lock-in. Portable container orchestration tools, like Kubernetes, support this. |
Tools: Kubernetes, Docker, OpenShift. |
| Service Mesh |
A service mesh is a layer of infrastructure providing advanced networking and security features, such as load balancing and service discovery, for containerized applications. |
| Sidecar Proxy |
A sidecar proxy is a container running alongside a primary container, intercepting network traffic and providing features like service discovery and load balancing. |
Tools: Envoy, Linkerd, NGINX. |
| Ingress Controller |
An ingress controller sits in front of services and routes incoming traffic based on rules defined in a Kubernetes Ingress resource. It manages external access to services. |
Tools: Nginx Ingress, Traefik, HAProxy. |
| Ingress Resource |
An Ingress resource in Kubernetes defines rules for routing incoming traffic to services within a cluster. It acts as a configuration for external access. |
Example: Defining rules for routing HTTP traffic to different services. |
| Virtual Kubelet |
Virtual Kubelet acts as a bridge between a Kubernetes cluster and other infrastructure, allowing non-Kubernetes workloads to be treated as first-class citizens. |
Tools: Virtual Kubelet, AKS Virtual Nodes, KubeVirt. |
| Container-Based Infrastructure |
Container-based infrastructure uses containers as the primary packaging and deployment mechanism for applications, providing improved resource utilization and portability. |
Tools: Docker, Kubernetes, OpenShift. |
| Container Platform |
A container platform is a suite of tools and services for building, deploying, and managing containerized applications. Examples include Docker Enterprise and Red Hat OpenShift. |
Tools: Docker Enterprise, Red Hat OpenShift, Kubernetes. |
| Container Security Scanning |
Container security scanning involves analyzing container images for vulnerabilities and security issues before deployment. |
| Container Networking Model |
Container networking model defines how containers communicate with each other and the external network. It involves various drivers and protocols for networking. |
| Service Discovery |
Service discovery is the process of locating and connecting to other services in a distributed system. It often uses a registry or directory service for discovery. |
Tools: Consul, etcd, Kubernetes Service Discovery. |
| Load Balancing |
Load balancing distributes incoming requests across multiple instances of a service to improve resource utilization and availability. |
Tools: HAProxy, NGINX, Kubernetes Load Balancer. |
| Request Routing |
Request routing is the process of directing incoming requests to the appropriate service based on rules, such as the path or hostname of the request. |
Tools: NGINX, Traefik, Istio Traffic Management. |
| Service Registry |
A service registry is a directory of available services and their locations, used by clients to discover and connect to services in a distributed system. |
Tools: Consul, etcd, ZooKeeper. |
| Container Networking Overlay |
A container networking overlay spans multiple hosts, allowing containers on different hosts to communicate as if they were on the same network. |
Tools: Docker Overlay Network, Kubernetes Network Policies, Calico. |
| Container Networking Bridge |
A container networking bridge is a virtual network interface connecting a container to the host network, enabling communication with the outside world. |
Tools: Docker Bridge Network, Kubernetes Networking, Weave. |
| Container Networking Port Mapping |
Port mapping is the process of mapping a port on the host network to a port on a container, allowing incoming traffic to be forwarded to the container. |
Tools: Docker Port Mapping, Kubernetes Service NodePort, Traefik. |
| Container Networking DNS |
Container networking DNS resolves hostnames to IP addresses within a containerized environment, allowing communication using domain names instead of IP addresses. |
Tools: CoreDNS, kube-dns, Docker DNS. |
| Container Networking Service Discovery |
Service discovery in container networking involves locating and connecting to other services, often using a registry or directory service for efficient discovery. |
| Container Networking Load Balancing |
Load balancing in container networking distributes incoming requests across multiple instances of a service to enhance resource utilization and availability. |
| Container Networking Request Routing |
Request routing in container networking directs incoming requests to the appropriate service based on rules like path or hostname of the request. |
| Container Networking Service Registry |
A service registry in container networking is a directory of available services and their locations, facilitating client discovery and connection to services. |
| Container Networking Service Mesh |
A service mesh in container networking is a layer of infrastructure providing advanced features like load balancing, service discovery, and secure communication. |
| Container Networking IPC |
Inter-Process Communication (IPC) in container networking is the way processes communicate within a system, utilizing mechanisms like pipes, sockets, or message queues. |
Tools: Docker IPC, Kubernetes IPC, Container Orchestrator IPC. |
| Container Scaling |
Container scaling is the process of adjusting the number of replicas of a container or set of containers based on demand, ensuring optimal resource usage. |
| Autoscaling |
Autoscaling automatically adjusts the number of replicas of a container or set of containers based on predefined policies or metrics like CPU utilization or request volume. |
Tools: Kubernetes Autoscaler, AWS Auto Scaling, Azure Autoscale. |
| Horizontal Scaling |
Horizontal scaling involves scaling a service by adding more replicas, distributing the workload, and improving performance without increasing individual instance resources. |
| Vertical Scaling |
Vertical scaling involves increasing the resources of individual instances, such as CPU or memory, to handle increased workload demands for a specific container. |
Tools: Kubernetes Vertical Pod Autoscaler, Docker Resource Scaling. |
| Deployment Strategies |
Deployment strategies are methods for deploying and updating containerized applications, including rolling updates, blue-green deployments, and canary deployments. |
Strategies: Kubernetes Rolling Updates, Blue-Green Deployments, Canary Deployments. |
| Deployment Automation |
Deployment automation uses tools and processes to automate the deployment and management of containerized applications, ensuring consistency and efficiency. |
Tools: Jenkins, GitLab CI/CD, Kubernetes Deployments. |
| Continuous Integration (CI) |
Continuous Integration (CI) merges code changes frequently and automatically builds and tests the codebase to maintain a consistent and deployable state. |
| Continuous Delivery (CD) |
Continuous Delivery (CD) automates the process of delivering code changes to production, ensuring that the code is always in a deployable state. |
Tools: Jenkins, GitLab CI/CD, ArgoCD. |
| Continuous Deployment |
Continuous Deployment (CD) automatically deploys code changes to production without human intervention, ensuring rapid and consistent delivery. |
| Cloud-Native Design Principles |
Cloud-native design principles guide the development of applications for the cloud, emphasizing factors like being loosely coupled, horizontally scalable, and resilient. |
Principles: Twelve-Factor App, Microservices, Stateless Design. |
| Container Clustering |
Container clustering groups multiple containers to form a logical unit, enabling them to be managed and scaled as a single entity for efficient resource utilization. |
Tools: Kubernetes, Docker Swarm, OpenShift. |
| Container Scheduling |
Container scheduling involves deciding on which host to run a container, considering factors like resource availability, affinity rules, and taints and tolerations. |
| Resource Constraints |
Resource constraints set limits on the amount of resources, such as CPU or memory, that a container is allowed to use, preventing resource exhaustion. |
Tools: Kubernetes ResourceQuotas, Docker Resource Constraints. |
| Affinity Rules |
Affinity rules specify which containers should be co-located on the same host or which hosts a container should be excluded from based on certain criteria. |
Tools: Kubernetes Affinity, Docker Compose Placement. |
| Taints and Tolerations |
Taints and tolerations mark a node as unsuitable for certain pods, allowing specific pods to be scheduled onto tainted nodes based on defined tolerations. |
Tools: Kubernetes Taints, Docker Swarm Constraints. |
| Pod Disruption Budget |
A pod disruption budget specifies the minimum number of pod replicas that must be available at all times and controls the rate of pod terminations during events. |
Tools: Kubernetes PodDisruptionBudget, OpenShift Disruption Controllers. |
| Container Security Context |
Container security context involves applying security-related settings to a container, such as privilege levels, AppArmor profiles, and SELinux labels. |
Tools: Kubernetes SecurityContext, Docker Security Options. |
| Container Networking Policies |
Container networking policies are rules that specify which containers are allowed to communicate with each other and define how they are allowed to communicate. |
Tools: Kubernetes NetworkPolicies, Calico, Cilium. |
| Kubernetes Operators |
Kubernetes Operators are a method of packaging, deploying, and managing applications as code using custom resources, extending Kubernetes functionality. |
Tools: Operator SDK, Helm, Ansible. |
| Infrastructure as Code (IaC) |
Infrastructure as Code (IaC) represents the practice of managing and provisioning infrastructure using machine-readable script files, improving consistency. |
Tools: Terraform, Ansible, CloudFormation. |
| Cloud-Native Storage |
Cloud-native storage solutions are designed for containerized environments, providing scalable and dynamic storage that can be easily integrated with orchestration tools. |
Tools: Rook, OpenEBS, Portworx. |
| StatefulSet |
StatefulSet in Kubernetes is a workload API object used for managing stateful applications, providing guarantees about the ordering and uniqueness of pods. |
Tools: Kubernetes StatefulSet, Helm, OpenShift StatefulSet. |
| Helm |
Helm is a package manager for Kubernetes that simplifies deploying and managing applications using charts, which are packages of pre-configured Kubernetes resources. |
Tools: Helm, Helmfile, Kustomize. |
| GitOps |
GitOps is a set of practices for managing infrastructure and application configurations using version-controlled Git repositories, ensuring declarative state. |
Tools: ArgoCD, Flux, Jenkins X. |
| Event-Driven Architecture |
Event-Driven Architecture (EDA) is an architectural style where services communicate and react to events, enabling decoupled and scalable systems. |
Example: Building a system using Apache Kafka for event streaming. |
| Domain-Driven Design (DDD) |
Domain-Driven Design (DDD) is a methodology for developing software systems based on understanding and modeling the business domain, fostering collaboration. |
Tools: None specific, but DDD principles can be applied in software design. |
| Pipeline |
A CI/CD pipeline automates the steps from code integration to deployment, ensuring code is tested and delivered consistently and quickly. |
Tools: Jenkins, GitLab CI/CD, CircleCI. |
| Canary Release |
Canary release is a deployment strategy where a small subset of users receives the new version first, allowing testing before a full rollout. |
Strategies: Kubernetes Canary Deployments, Istio Traffic Shifting, Spinnaker. |
| Dark Launch |
Dark launch is a technique where new features are deployed but kept hidden from users, allowing testing and gradual exposure based on performance. |
Strategies: Feature toggles, LaunchDarkly, Unleash. |
| Feature Toggle |
Feature toggle is a technique where a feature is selectively enabled or disabled at runtime, providing control over the release of new functionalities. |
Tools: LaunchDarkly, Unleash, ConfigCat. |
IaC involves managing infrastructure using code, enabling version control, repeatability, and automation of infrastructure provisioning. |
Tools: Terraform, Ansible, AWS CloudFormation. |
| ChatOps |
ChatOps integrates chat platforms into the development process, allowing teams to collaborate, automate tasks, and receive notifications within chat tools. |
Tools: Slack, Microsoft Teams, Hubot. |
| GitOps |
GitOps is an approach where Git repositories serve as a source of truth for declarative infrastructure and application configurations. |
| Chaos Engineering |
Chaos engineering involves intentionally introducing failures into a system to identify weaknesses and improve overall resilience. |
Tools: Chaos Monkey, Gremlin, Chaos Toolkit. |
| Log Aggregation |
Log aggregation centralizes and collects logs from various services and applications, making it easier to analyze and troubleshoot issues. |
Tools: ELK Stack (Elasticsearch, Logstash, Kibana), Splunk, Fluentd. |
| Monitoring and Alerting |
Monitoring tracks system health, while alerting provides notifications for abnormal conditions, helping teams respond to issues promptly. |
Tools: Prometheus, Grafana, Nagios. |
| Incident Response Plan |
An incident response plan outlines steps and procedures for handling and mitigating incidents, ensuring a structured and coordinated response. |
Strategies: Runbooks, Incident Command System (ICS), PagerDuty. |
| Microservices Architecture |
Microservices architecture decomposes a monolithic application into smaller, independent services, allowing development, deployment, and scaling of individual components. |
| Observability |
Observability involves understanding and measuring the internal state of a system using metrics, logs, and traces to facilitate effective troubleshooting. |
Tools: Prometheus, Grafana, Jaeger. |
| Security as Code |
Security as code integrates security practices into the development process, applying security measures through code and automation. |
Tools: Checkmarx, SonarQube, Snyk. |
| Compliance as Code |
Compliance as code ensures that infrastructure and applications adhere to regulatory requirements by codifying compliance rules and checks. |
Tools: InSpec, Chef Compliance, OpenSCAP. |
| Configuration Management |
Configuration management automates the setup and maintenance of system configurations, ensuring consistency across environments. |
Tools: Ansible, Puppet, Chef. |
| Disaster Recovery Planning |
Disaster recovery planning involves creating strategies and procedures for recovering systems and data in case of unexpected failures or disasters. |
Strategies: Backup and Restore, Multi-region Deployments, Cloud Endure. |
| Secret Management |
Secret management securely stores and manages sensitive information such as passwords and API keys, preventing exposure and unauthorized access. |
Tools: HashiCorp Vault, AWS Secrets Manager, Azure Key Vault. |
| Git Workflow |
A Git workflow defines how code changes are managed, reviewed, and integrated into a codebase, ensuring a structured and collaborative development process. |
Workflows: Gitflow, GitHub Flow, GitLab Flow. |
| Change Management |
Change management controls and manages changes to the IT environment, ensuring that modifications are planned, approved, and communicated effectively. |
Strategies: ITIL Change Management, Version Control Systems. |
| Test Automation |
Test automation involves automating the execution of tests to ensure code quality and catch defects early in the development process. |
Tools: Selenium, JUnit, TestNG. |
| Continuous Testing |
Continuous testing integrates testing practices throughout the CI/CD pipeline, ensuring that each code change undergoes automated tests before deployment. |
Tools: Jenkins, GitLab CI/CD, Travis CI. |
| Shift-Left Testing |
Shift-left testing involves moving testing activities earlier in the development process, identifying and fixing issues during the initial stages of development. |
Tools: SonarQube, Snyk, Checkmarx. |
| Code Review |
Code review is a collaborative process where developers assess each other’s code changes, ensuring code quality, best practices, and knowledge sharing. |
Tools: GitHub, GitLab, Bitbucket. |
| Infrastructure Monitoring |
Infrastructure monitoring focuses on tracking and analyzing the performance and health of servers, networks, and other infrastructure components. |
Tools: Nagios, Prometheus, Datadog. |
| Git Hooks |
Git hooks are scripts triggered by Git events, allowing custom actions to be performed at different stages of the version control workflow. |
Tools: Git, Husky, Overcommit. |
| Server Configuration Management |
Server configuration management automates the provisioning and maintenance of server configurations, ensuring consistency and reducing manual effort. |
| Dependency Management |
Dependency management tracks and controls external libraries and components used in a project, ensuring consistent and secure dependencies. |
Tools: Maven, Gradle, npm. |
| Technical Debt |
Technical debt represents the cost of delaying necessary work, often resulting from shortcuts or compromises made during the development process. |
Strategies: Refactoring, Regular Code Reviews, SonarQube. |
| Release Management |
Release management oversees the planning, scheduling, and coordination of software releases, ensuring a smooth and controlled deployment process. |
Tools: Spinnaker, AWS CodePipeline, Octopus Deploy. |
| Observability Tools |
Observability tools help monitor and gain insights into system performance, including metrics, logs, and traces, for effective troubleshooting. |
Tools: Prometheus, Grafana, ELK Stack. |
| Policy as Code |
Policy as code translates compliance and security policies into code, automating checks and ensuring adherence to organizational standards. |
Tools: Open Policy Agent (OPA), Conftest, Kyverno. |
| Rolling Updates |
Rolling updates gradually replace instances of an application with new ones, ensuring continuous availability and allowing easy rollback if issues arise. |
Strategies: Kubernetes Rolling Updates, AWS Elastic Beanstalk, Spinnaker. |
| Multicloud Strategy |
A multicloud strategy involves using services from multiple cloud providers, reducing dependency on a single provider and enhancing flexibility. |
Strategies: Kubernetes Multi-Cluster Management, Terraform, Anthos. |
| API Gateway |
An API gateway manages and secures API traffic, handling tasks such as authentication, authorization, and rate limiting for microservices. |
Tools: Kong, Apigee, AWS API Gateway. |
| Infrastructure Resilience |
Infrastructure resilience ensures that systems can withstand and recover from failures, incorporating redundancy and failover mechanisms. |
Strategies: Load Balancing, High Availability Architectures, Chaos Engineering. |
| Build Automation |
Build automation automates the process of compiling source code into executable artifacts, ensuring consistency and efficiency in the build process. |
Tools: Jenkins, Maven, Gradle. |
| ITIL (Information Technology Infrastructure Library) |
ITIL is a set of practices for IT service management, providing guidance on aligning IT services with business needs. |
Strategies: ITIL Framework, ServiceNow, Jira Service Management. |
| Risk Management |
Risk management involves identifying, assessing, and mitigating potential risks that may impact the success of a project or the stability of a system. |
Strategies: Risk Assessment Matrix, Risk Register, Monte Carlo Simulation. |
| User Acceptance Testing (UAT) |
UAT is a testing phase where end-users evaluate the software to ensure it meets their requirements and is ready for production deployment. |
Strategies: Manual Testing, Automated Testing, TestRail. |
| Test-Driven Development (TDD) |
TDD involves writing tests before implementing the corresponding code, ensuring that code meets the specified requirements and reducing defects. |
Strategies: JUnit, NUnit, Pytest. |
