FastAPI Deployment Guide for CloudPanel
- Prerequisites
- CloudPanel Setup
- Project Structure
- FastAPI Application Setup
- Virtual Environment Configuration
- Gunicorn Setup
- Nginx Configuration
- SSL Configuration
- Deployment Steps
1. Prerequisites
- CloudPanel installed on your server
- Python 3.8+ installed
- Basic knowledge of Linux commands
- Domain name pointed to your server
2. CloudPanel Setup
CloudPanel Directory Structure
/home/your-user/htdocs/
└── your-domain.com/
├── private/
│ ├── python/
│ └── logs/
└── public/
└── static/
Creating a New Site in CloudPanel
- Log in to CloudPanel UI (typically at https://your-server-ip:8443)
- Navigate to “Sites” in the left sidebar
- Click “Add Site”
- Fill in the following details:
- Domain Name: your-domain.com
- Technology Stack: Python
- Python Version: 3.8+ (recommended)
- Document Root: /public
- SSL: Enable (recommended)
3. Project Structure
After site creation, organize your FastAPI project like this:
/home/your-user/htdocs/your-domain.com/
├── private/
│ ├── python/
│ │ ├── venv/
│ │ ├── app/
│ │ │ ├── __init__.py
│ │ │ ├── main.py
│ │ │ ├── routers/
│ │ │ ├── models/
│ │ │ └── dependencies/
│ │ ├── requirements.txt
│ │ └── gunicorn_config.py
│ └── logs/
│ ├── access.log
│ └── error.log
└── public/
└── static/
4. FastAPI Application Setup
Create main.py
from fastapi import FastAPI
from fastapi.staticfiles import StaticFiles
app = FastAPI()
# Mount static files
app.mount("/static", StaticFiles(directory="/home/your-user/htdocs/your-domain.com/public/static"), name="static")
@app.get("/")
async def root():
return {"message": "Hello from FastAPI"}
Create requirements.txt
fastapi==0.104.1
uvicorn==0.24.0
gunicorn==21.2.0
python-multipart==0.0.6
5. Virtual Environment Configuration
cd /home/your-user/htdocs/your-domain.com/private/python
python3 -m venv venv
source venv/bin/activate
pip install -r requirements.txt
6. Gunicorn Setup
Create gunicorn_config.py
import multiprocessing
bind = "unix:/home/your-user/htdocs/your-domain.com/private/python/app.sock"
workers = multiprocessing.cpu_count() * 2 + 1
worker_class = "uvicorn.workers.UvicornWorker"
timeout = 120
keepalive = 5
errorlog = "/home/your-user/htdocs/your-domain.com/private/logs/error.log"
accesslog = "/home/your-user/htdocs/your-domain.com/private/logs/access.log"
access_log_format = '%(h)s %(l)s %(u)s %(t)s "%(r)s" %(s)s %(b)s "%(f)s" "%(a)s"'
7. Nginx Configuration
CloudPanel automatically manages Nginx configuration, but here’s the recommended setup:
server {
location / {
proxy_pass http://unix:/home/your-user/htdocs/your-domain.com/private/python/app.sock;
proxy_http_version 1.1;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
location /static {
alias /home/your-user/htdocs/your-domain.com/public/static;
expires 30d;
add_header Cache-Control "public, no-transform";
8. SSL Configuration
- In CloudPanel UI, go to Sites > your-domain.com
- Click “SSL/TLS”
- Choose either:
- Let’s Encrypt (free, automatic renewal)
- Custom SSL certificate
- Follow the wizard to complete SSL setup
9. Deployment Steps
- Upload your FastAPI application:
# Assuming you're using git
git clone your-repository-url .
- Set up virtual environment and install dependencies:
- Start Gunicorn:
gunicorn app.main:app -c gunicorn_config.py --daemon
- Set up systemd service for automatic startup:
# /etc/systemd/system/fastapi-your-domain.service
[Unit]
Description=FastAPI application for your-domain.com
After=network.target
[Service]
User=your-user
Group=your-user
WorkingDirectory=/home/your-user/htdocs/your-domain.com/private/python
Environment="PATH=/home/your-user/htdocs/your-domain.com/private/python/venv/bin"
ExecStart=/home/your-user/htdocs/your-domain.com/private/python/venv/bin/gunicorn app.main:app -c gunicorn_config.py
Restart=always
[Install]
WantedBy=multi-user.target
Enable and start the service:
sudo systemctl enable fastapi-your-domain
sudo systemctl start fastapi-your-domain
10. Troubleshooting
Common Issues and Solutions
- Permission Issues
sudo chown -R your-user:your-user /home/your-user/htdocs/your-domain.com/
chmod -R 755 /home/your-user/htdocs/your-domain.com/
- Socket Connection Issues
- Check socket file exists and has correct permissions
- Verify Gunicorn is running:
ps aux | grep gunicorn - Check logs:
tail -f /home/your-user/htdocs/your-domain.com/private/logs/error.log
- Static Files Not Loading
- Verify static directory permissions
- Check Nginx configuration for correct static file path
- Clear browser cache
- 502 Bad Gateway
- Check if Gunicorn is running
- Verify socket file permissions
- Check application logs for Python errors
Maintenance Commands
# Restart FastAPI application
sudo systemctl restart fastapi-your-domain
# Check application status
sudo systemctl status fastapi-your-domain
# View logs
tail -f /home/your-user/htdocs/your-domain.com/private/logs/access.log
Common CloudPanel-Specific Notes
The nginx configuration is managed by CloudPanel in the UI, but you can add custom configurations through the CloudPanel interface under Sites > your-domain.com > Vhost.
Python versions can be switched in the CloudPanel UI under Sites > your-domain.com > PHP Version (despite the name, it handles Python versions too).
Always check the CloudPanel logs in addition to your application logs when troubleshooting:
tail -f /var/log/your-app/logs/error.log -
When updating your application, you may need to:
# Restart the FastAPI service sudo systemctl restart fastapi-your-domain
