[!NOTE]
All scripts in this document should be executed in Windows Powershell as Administrator.
- Windows Defender ignore list
- Powershell
- Mount network shares
- WinGet (Windows Package Manager CLI)
- Universal time
- Visual Studio Code
- Node.js
- Common commands
- WSL2
- Docksal (WSL2)
- Edit hosts
- List of
ENVIRONMENTvariables
Activation
Codecs
Open in browser:
- HEVC:
ms-windows-store://pdp/?ProductId=9n4wgh0z6vhq - AV1:
ms-windows-store://pdp/?ProductId=9MVZQVXJBQ9V
ForEach ($item in @(
"${env:WINDIR}\System32\drivers\etc\hosts"
"D:\Apps"
"E:\Install"
)) { Add-MpPreference -ExclusionPath (Convert-Path -Path $item) }
Powershell
Update help for powershell:
Update-Help -ErrorAction Ignore
Allow to run PS scripts:
Set-ExecutionPolicy RemoteSigned
Disable hibernation
powercfg.exe /hibernate off
$cred = Get-Credential -Message "Enter NAS User credentials"
$drives = @{
B = "\\192.168.50.123\Books"
H = "\\192.168.50.123\Homes\admin"
M = "\\192.168.50.123\Music\Музыка"
V = "\\192.168.50.123\Videos"
}; foreach($driveLetter in $drives.keys) {
Remove-PSDrive -Name $driveLetter -ErrorAction SilentlyContinue
New-PSDrive -Name $driveLetter -Root $drives[$driveLetter] -Persist -PSProvider "FileSystem" -Credential $cred
[!NOTE]
wingetapp is not available by default. App Installer app needs to be installed first (using Microsoft Store).
Search for packages
winget search <appName>
List installed apps
winget list
Update apps
winget upgrade --all
Install packages
#"SteelSeries.GG"
#"Nvidia.GeForceExperience"
###> Internet
"AgileBits.1Password"
"Discord.Discord"
"Google.Chrome"
"Mozilla.Firefox"
"Notion.Notion"
"qBittorrent.qBittorrent"
"ProtonTechnologies.ProtonVPN"
"SlackTechnologies.Slack"
"Telegram.TelegramDesktop"
"Viber.Viber"
#"TorProject.TorBrowser"
#"WireGuard.WireGuard"
#"Cloudflare.Warp" # CloudFlare's VPN
#"tailscale.tailscale"
#"Transmission.Transmission"
###< Internet
###> System
"7zip.7zip"
"CrystalDewWorld.CrystalDiskInfo"
"CrystalDewWorld.CrystalDiskMark"
"CrystalRich.LockHunter"
"namazso.OpenHashTab"
"REALiX.HWiNFO" # Hardware Analysis, Monitoring and Reporting
"Rufus.Rufus"
"Synology.DriveClient"
"TeamViewer.TeamViewer"
"WinDirStat.WinDirStat"
#"WiseCleaner.WiseRegistryCleaner"
#"WiseCleaner.WiseProgramUninstaller"
#"WiseCleaner.WiseDiskCleaner"
#"HermannSchinagl.LinkShellExtension"
#"Piriform.CCleaner"
#"Piriform.Defraggler"
#"Piriform.Recuva"
#"Piriform.Speccy"
###< System
###> Media
"CodecGuide.K-LiteCodecPack.Mega"
"HandBrake.HandBrake" # Video converter
"XnSoft.XnViewMP"
#"VideoLAN.VLC"
###< Media
###> Runtimes, language interpriters
"Microsoft.DotNet.DesktopRuntime.3_1"
"Microsoft.DotNet.DesktopRuntime.5"
"Microsoft.DotNet.DesktopRuntime.6"
"Microsoft.DotNet.DesktopRuntime.7"
"Microsoft.DotNet.DesktopRuntime.8"
"Microsoft.VCRedist.2005.x64"
"Microsoft.VCRedist.2005.x86"
"Microsoft.VCRedist.2008.x64"
"Microsoft.VCRedist.2008.x86"
"Microsoft.VCRedist.2010.x64"
"Microsoft.VCRedist.2010.x86"
"Microsoft.VCRedist.2012.x64"
"Microsoft.VCRedist.2012.x86"
"Microsoft.VCRedist.2013.x64"
"Microsoft.VCRedist.2013.x86"
"Microsoft.VCRedist.2015+.x64"
"Microsoft.VCRedist.2015+.x86"
#"Microsoft.VCRedist.2019.arm64"
#"Microsoft.VCRedist.2022.arm64"
"OpenJS.NodeJS.LTS"
"Python.Python.3"
"Microsoft.OpenJDK.11" # LTS
#"AdoptOpenJDK.OpenJDK.11" # LTS
###< Runtimes, language interpriters
###> Developer tools, editors, IDEs
"Git.Git"
"JetBrains.Toolbox"
"Microsoft.VisualStudioCode"
#"Amazon.AWSCLI"
#"Amazon.SAM-CLI"
#"Docker.DockerDesktop"
#"GitHub.cli"
#"SublimeHQ.SublimeMerge"
#"SublimeHQ.SublimeText.4"
###< Developer tools, editors, IDEs
###> Games
#"EpicGames.EpicGamesLauncher"
#"Libretro.RetroArch"
#"Valve.Steam"
###< Games
###> Office
#"TheDocumentFoundation.LibreOffice"
"ONLYOFFICE.DesktopEditors"
"TrackerSoftware.PDF-XChangePRO"
###< Office
)) { winget install --id $item --accept-source-agreements }
Universal time
For fixing incorrect time in Windows with dual-boot installed linux, import following to registry:
Enable:
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\TimeZoneInformation" -Name "RealTimeIsUniversal" -Type DWord -Value 1
Disable:
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Control\TimeZoneInformation" -Name "RealTimeIsUniversal" -Type DWord -Value 0
Visual Studio Code
Install using winget
winget install Microsoft.VisualStudioCode
Use config from my dotfiles repo:
Invoke-WebRequest https://raw.githubusercontent.com/alexander-danilenko/dotfiles/main/.config/Code/User/settings.json -OutFile "${env:APPDATA}\Code\User\settings.json"
Following command installs code extensions by extension id:
ForEach ($extension in @(
"acarreiro.calculate" # Calculates inline math expr
"amazonwebservices.aws-toolkit-vscode" # AWS toolkit
"christian-kohler.path-intellisense" # File path autocomplete
"coenraads.bracket-pair-colorizer" # Bracket Pair Colorizer
"dakara.transformer" # Filter, Sort, Unique, Reverse, Align, CSV, Line Selection, Text Transformations and Macros
"editorconfig.editorconfig" # EditorConfig support
"esbenp.prettier-vscode" # Prettier - Code formatter
"golang.go" # Golang support
"hookyqr.beautify" # HTML/JSON beautifier
"mhutchie.git-graph" # Git graph
"mikestead.dotenv" # .env support
"ms-azuretools.vscode-docker" # Docker support
"ms-python.python" # Python support
"ms-vscode-remote.remote-ssh" # SSH support
"tommasov.hosts" # Hosts file syntax highlighter.
"tyriar.lorem-ipsum" # Lorem Ipsum generator
"william-voyek.vscode-nginx" # nginx.conf support
"yzhang.markdown-all-in-one" # Markdown tools
#"alefragnani.Bookmarks" # Bookmarks
#"TabNine.tabnine-vscode" # AI-assisted autocomplete
# Node/NPM/Yarn specific extensions
"christian-kohler.npm-intellisense" # NPM better autocomplete
"dbaeumer.vscode-eslint" # Eslint support
"mariusschulz.yarn-lock-syntax" # yarn.lock syntax highlight
# PHP/Drupal specific extensions
"ikappas.composer" # Composer support
"ikappas.phpcs" # PHP CodeSniffer
# Themes
"github.github-vscode-theme" # GitHub color theme
"pkief.material-icon-theme" # Material Icon Theme
"rokoroku.vscode-theme-darcula" # JetBrains-like theme.
)) { code --install-extension $extension --force }
Node.js
Install node:
winget install --id OpenJS.NodeJS.LTS
[!IMPORTANT]
After installing node.js need to restart terminal before installing npm packages.
NPM global packages:
$packages=@(
"bower"
"dynamodb-admin" # Handy Web-UI for viewing local DynamoDB data
"eslint"
"eslint-config-airbnb"
"eslint-config-google"
"eslint-config-standard"
"eslint-plugin-import"
"eslint-plugin-jsx-a11y"
"eslint-plugin-node"
"eslint-plugin-promise"
"eslint-plugin-react"
"eslint-plugin-react-hooks"
"firebase-tools"
"flow"
"flow-bin"
"gulp"
"http-server"
"lsp"
"snyk"
"typescript"
"vscode-css-languageserver-bin"
"vscode-html-languageserver-bin"
"yarn"
); npm install -g $packages
Common commands
| Action | Command |
| Disable password prompt on windows load | netplwiz |
| Reset DNS | ipconfig /flushdns; netsh winsock reset |
WSL2
Enable WSL (Windows Subsystem Linux) and set WSL2 as the default.
wsl --install
wsl --set-default-version 2
List all available to install distros:
wsl --list --online
[!IMPORTANT]
After WSL installation and before installing any distro you need to reboot!
Install distros:
wsl --install --distribution Ubuntu-20.04
wsl --install --distribution Debian
List installed versions:
wsl --list --verbose
Get distro ip address:
wsl --distribution Ubuntu-20.04 --exec ip route list default
Docksal (WSL2)
[!IMPORTANT]
Make sure you have WSLv2 engine used for Ubuntu distro by runningwsl --list --verbose.VERSIONshould be2.
Run Windows Terminal, open Ubuntu terminal tab.
Install docker using docker repos (run in Ubuntu shell):
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg && \
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null && \
sudo apt update && \
sudo apt install -y docker-ce docker-ce-cli docker-compose
Add current user to docker user group (run in Ubuntu shell):
sudo usermod -aG docker "$USER" && \
newgrp docker
Install Docksal (run in Ubuntu shell):
bash <(curl -fsSL https://get.docksal.io) && \
fin config set --global DOCKSAL_VHOST_PROXY_IP=127.0.0.1 && \
fin config set --global DOCKSAL_DNS_DOMAIN=docksal.site && \
fin system reset vhost-proxy
Grab WSL Distro IP (run in Ubuntu shell):
Add all projects to windows hosts using WSL distro IP.
Backup
$backupDate=$(Get-Date -Format 'yyyyMMdd_HHmm')
$dirs=@{
$env:USERNAME = $env:USERPROFILE
APPDATA = $env:APPDATA
}; foreach ($key in $dirs.GetEnumerator()) {
$backupDir=$($key.Value)
$backupType=$($key.Name)
$archiveName="${backupDate}_${backupType}.zip"
Write-Host -ForegroundColor Yellow "Archiving '$backupDir' to '$archiveName'..."
Compress-Archive $backupDir -Force -CompressionLevel NoCompression -DestinationPath $archiveName
Write-Host -ForegroundColor Green "Archive created: $archiveName"
pause
Edit hosts
code %SystemRoot%\System32\drivers\etc\hosts
List of ENVIRONMENT variables
See table
| Variable | Volatile (Read-Only) | Default value assuming the system drive is C: |
ALLUSERSPROFILE |
C:\ProgramData | |
APPDATA |
C:\Users{username}\AppData\Roaming | |
CD |
Y | The current directory (string). |
ClientName |
Y | Terminal servers only - the ComputerName of a remote host. |
CMDEXTVERSION |
Y | The current Command Processor Extensions version number. (NT = “1”, Win2000+ = “2”.) |
CMDCMDLINE |
Y | The original command line that invoked the Command Processor. |
CommonProgramFiles |
C:\Program Files\Common Files | |
COMMONPROGRAMFILES(x86) |
C:\Program Files (x86)\Common Files | |
COMPUTERNAME |
{computername} | |
COMSPEC |
C:\Windows\System32\cmd.exe or if running a 32 bit WOW - C:\Windows\SysWOW64\cmd.exe | |
DATE |
Y | The current date using same region specific format as DATE. |
ERRORLEVEL |
Y | The current ERRORLEVEL value, automatically set when a program exits. |
FPS_BROWSER_APP_PROFILE_STRING FPS_BROWSER_USER_PROFILE_STRING |
Internet Explorer Default These are undocumented variables for the Edge browser in Windows 10. | |
HighestNumaNodeNumber |
Y (hidden) | The highest NUMA node number on this computer. |
HOMEDRIVE |
Y | C: |
HOMEPATH |
Y | \Users{username} |
LOCALAPPDATA |
C:\Users{username}\AppData\Local | |
LOGONSERVER |
\{domain_logon_server} | |
NUMBER_OF_PROCESSORS |
Y | The Number of processors running on the machine. |
PATH |
User and System | C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem;{plus program paths} |
PATHEXT |
.COM; .EXE; .BAT; .CMD; .VBS; .VBE; .JS ; .WSF; .WSH; .MSC Determine the default executable file extensions to search for and use, and in which order, left to right. The syntax is like the PATH variable - semicolon separators. | |
PROCESSOR_ARCHITECTURE |
Y | AMD64/IA64/x86 This doesn’t tell you the architecture of the processor but only of the current process, so it returns “x86” for a 32 bit WOW process running on 64 bit Windows. See detecting OS 32/64 bit |
PROCESSOR_ARCHITEW6432 |
=%PROCESSOR_ARCHITECTURE% (but only available to 64 bit processes) | |
PROCESSOR_IDENTIFIER |
Y | Processor ID of the user’s workstation. |
PROCESSOR_LEVEL |
Y | Processor level of the user’s workstation. |
PROCESSOR_REVISION |
Y | Processor version of the user’s workstation. |
ProgramW6432 |
=%ProgramFiles%(but only available when running under a 64 bit OS) | |
ProgramData |
C:\ProgramData | |
ProgramFiles |
C:\Program Files or C:\Program Files (x86) | |
ProgramFiles(x86) 1 |
C:\Program Files (x86) (but only available when running under a 64 bit OS) | |
PROMPT |
Code for current command prompt format,usually $P$G C:> | |
PSModulePath |
%SystemRoot%\system32\WindowsPowerShell\v1.0\Modules\ | |
Public |
C:\Users\Public | |
RANDOM |
Y | A random integer number, anything from 0 to 32,767 (inclusive). |
%SessionName% |
Terminal servers only - for a terminal server session, SessionName is a combination of the connection name, followed by #SessionNumber. For a console session, SessionName returns “Console”. | |
SYSTEMDRIVE |
C: | |
SYSTEMROOT |
By default, Windows is installed to C:\Windows but there’s no guarantee of that, Windows can be installed to a different folder, or a different drive letter. systemroot is a read-only system variable that will resolve to the correct location. Defaults in early Windows versions are C:\WINNT, C:\WINNT35 and C:\WTSRV | |
TEMP and TMP |
User Variable | C:\Users{Username}\AppData\Local\Temp Under XP this was {username}\Local Settings\Temp |
TIME |
Y | The current time using same format as TIME. |
UserDnsDomain |
Y User Variable | Set if a user is a logged on to a domain and returns the fully qualified DNS domain that the currently logged on user’s account belongs to. |
USERDOMAIN |
{userdomain} | |
USERDOMAIN_roamingprofile |
The user domain for RDS or standard roaming profile paths. Windows 8/10/2012 (or Windows 7/2008 with Q2664408) | |
USERNAME |
{username} | |
USERPROFILE |
%SystemDrive%\Users{username} This is equivalent to the $HOME environment variable in Unix/Linux | |
WINDIR |
%windir% is a regular User variable and can be changed, which makes it less robust than %SystemRoot% Set by default as windir=%SystemRoot% %WinDir% pre-dates Windows NT, its use in many places has been replaced by the system variable: %SystemRoot% |
