Enabling Health Checks for Private Resources in Pangolin: The Newt Solution
Health checks are a powerful feature in Pangolin for monitoring the status of your resources, enabling intelligent load balancing, automatic failover, and better visibility into service health. However, many users run into a common roadblock: health checks don’t work (or appear gray/unknown) for “local” or private resources until you properly configure Newt.
This guide, inspired by real community troubleshooting, walks through why this happens and how to fix it efficiently.
Understanding the Components
- Pangolin: The core identity-aware VPN and tunneled reverse proxy server (based on WireGuard). It handles authentication, access control, and routing.
- Newt: The companion client — a fully user-space WireGuard tunnel client and TCP/UDP proxy. It securely connects remote/private resources back to your Pangolin instance. Newt runs near (or alongside) your backend services and performs active health checks.
- Resources/Sites: In Pangolin, you define “sites” and attach resources (containers, services, etc.). Resources can be marked as “local” (direct on the Pangolin host/network) or tunneled via Newt.
Key Insight: Health checks are executed from inside Newt. Without a Newt-connected site, Pangolin has no active monitor performing checks, so the status remains “unknown” (often shown as gray).
The Problem
Users often see something like this in the UI:
- Cannot enable health checks for private resources.
- Status stays gray/unknown even after attempting configuration.
- Docker Compose examples (like the official
docker-compose.example.yml) may not mention Newt, leading to confusion.
This is expected behavior in versions like v1.18.1 — health checks rely on Newt performing the probes and reporting back.
The Solution: Migrate to a Newt Site
- Create a New Site in Pangolin (preferably the top-level/default site for lowest latency, unless you have specific multi-site needs).
- Provision Newt for that site (copy the credentials/config from the Pangolin UI).
- Update your resources:
- Change the resource selector/type from Local to Newt.
- Point them to the Newt-connected site.
- Run Newt near your services (Docker recommended for self-hosted setups).
Once Newt is active and resources are attached, health checks become available and statuses update to green (healthy) or red (unhealthy).
Optimized Docker Compose Setup (Avoid Extra Hops)
To keep traffic efficient, use Docker network aliases so Newt can reach services directly via the internal Docker network instead of looping out through the public internet/WireGuard unnecessarily.
Here’s a recommended configuration:
gerbil: # Example backend service (replace with your actual services)
image: your-service-image
default:
aliases:
- pangolin.domain.com # Alias so Newt resolves it locally via Docker DNS
# Add more aliases as needed for your resource hostnames
pangolin:
# Your Pangolin container config...
- default
# Do not attach to Traefik/external networks if not needed
newt:
image: fosrl/newt:latest
depends_on:
pangolin:
condition: service_healthy
gerbil: # Ensure backends are ready
condition: service_started
- PANGOLIN_ENDPOINT=https://pangolin.yourdomain.com
- NEWT_ID=your_newt_id_from_pangolin
- NEWT_SECRET=your_newt_secret_from_pangolin
- default
default:
enable_ipv6: true # Optional, depending on your setup
Why aliases matter: They prevent unnecessary network hops (Newt → public → back in). Internal Docker resolution is faster and more reliable.
Post-Migration Steps
- Restart services and verify Newt connects successfully in the Pangolin dashboard.
- Edit existing resources to use the Newt site.
- Enable health checks on resources (HTTP, TCP, etc., as supported).
- Monitor the UI — statuses should now transition from gray/unknown to green.
Users report that after this migration, “health checks are working” and the system behaves as expected.
Best Practices & Tips
- Latency: Use the top-level site unless you need geographic or logical separation.
- Multiple Resources: Update selectors one by one or in bulk if your UI supports it.
- Security: Newt handles the secure tunneling — keep your
NEWT_IDandNEWT_SECRETprotected. - Updates: Keep Pangolin and Newt versions aligned for best compatibility and performance.
- Troubleshooting: Check Newt logs for connection/health check errors. Ensure firewall rules allow the WireGuard traffic.
Why This Architecture?
Newt’s design (user-space WireGuard + proxy) makes it ideal for distributed, zero-trust environments. It eliminates complex manual WireGuard configs and NAT issues while adding powerful capabilities like health monitoring directly from the resource’s network context.
This approach scales for self-hosted setups, IoT, internal tools, or hybrid cloud deployments.
Switching private resources to Newt unlocks the full power of Pangolin’s health checking and load balancing. While it requires a small migration step, the benefits in reliability, observability, and performance are well worth it.
Resources:
- Official Pangolin Docs: https://docs.pangolin.net
- Newt GitHub: GitHub - fosrl/newt: Pangolin tunneled site & network connector · GitHub
- Pangolin GitHub: GitHub - fosrl/pangolin: Identity-aware VPN and tunneled reverse proxy for remote access based on WireGuard®. · GitHub
Have questions or a unique setup? Drop them in the comments or the community forums.
