Detailed Guide: Creating a Grafana Dashboard for Traefik Metrics in Pangolin Stack- Part 2
I’ll guide you through setting up a Grafana dashboard to monitor your Traefik metrics in the Pangolin stack step by step.
Part 1: Enable Metrics in Traefik
Step 1: Edit Traefik Configuration
  1. Edit your Traefik configuration file:
nano config/traefik/traefik_config.yml
  1. Add the Prometheus metrics endpoint by adding this section:
metrics:
  prometheus:
    addEntryPointsLabels: true
    addServicesLabels: true
    addRoutersLabels: true
    buckets:
      - 0.1
      - 0.3
      - 1.2
      - 5.0
  1. Your updated file should include this section (make sure it’s at the same indentation level as other main sections like api:, providers:, etc.):
# API and Dashboard
api:
  insecure: true
  dashboard: true
# Metrics
metrics:
  prometheus:
    buckets:
      - 0.1
      - 0.3
      - 1.2
      - 5.0
# Providers
Part 2: Setting Up Prometheus
Step 1: Create a Prometheus Configuration File
  1. Create a directory for Prometheus:
mkdir -p config/prometheus
  1. Create a prometheus.yml file:
nano config/prometheus/prometheus.yml
  1. Add the following configuration:
global:
  scrape_interval: 15s
  evaluation_interval: 15s
scrape_configs:
  - job_name: 'traefik'
    static_configs:
      - targets: ['gerbil:8080']
    metrics_path: /metrics
  - job_name: 'crowdsec'
    static_configs:
      - targets: ['crowdsec:6060']
Step 2: Add Prometheus to Your Docker Compose
  1. Edit your docker-compose.yml file:
nano docker-compose.yml
  1. Add the Prometheus service:
prometheus:
  image: prom/prometheus:latest
  container_name: prometheus
    - pangolin
    - ./config/prometheus:/etc/prometheus
    - prometheus-data:/prometheus
  command:
    - '--config.file=/etc/prometheus/prometheus.yml'
    - '--storage.tsdb.path=/prometheus'
    - '--web.console.libraries=/etc/prometheus/console_libraries'
    - '--web.console.templates=/etc/prometheus/consoles'
    - "9091:9090"
  1. Add a volumes section at the end of your docker-compose file if it doesn’t exist:
  prometheus-data:
Step 3: Modify Traefik Service to Expose Metrics
  1. In your docker-compose.yml, make sure your Traefik service exposes port 8080:
traefik:
  image: traefik:v3.3.3
  container_name: traefik
  network_mode: service:gerbil
  depends_on:
    pangolin:
      condition: service_healthy
  command:
    # Add metrics endpoint
    - --metrics.prometheus=true
    - --metrics.prometheus.addServicesLabels=true
    - --metrics.prometheus.addEntryPointsLabels=true
    - ./config/traefik:/etc/traefik:ro
    - ./config/letsencrypt:/letsencrypt
    - ./config/traefik/conf/:/etc/traefik/conf/
    - ./config/traefik/rules:/rules
  1. In the gerbil service, make sure port 8080 is exposed:
gerbil:
  # your existing configuration
    - 51820:51820/udp
    - 443:443
    - 80:80
    - 8085:8080  # Add this for Traefik metrics
Part 3: Setting Up Grafana
Step 1: Add Grafana to Docker Compose
  1. Add the Grafana service to your docker-compose.yml:
grafana:
  image: grafana/grafana:latest
  container_name: grafana
    - pangolin
    - grafana-data:/var/lib/grafana
    - GF_SECURITY_ADMIN_USER=admin
    - GF_SECURITY_ADMIN_PASSWORD=strongpassword
    - GF_USERS_ALLOW_SIGN_UP=false
    - "3035:3000"
  1. Add to the volumes section:
  prometheus-data:
  grafana-data:
Step 2: Apply Changes
  1. Apply the changes to your Docker Compose stack:
docker compose down
docker compose up -d
  1. Verify all services are running:
docker ps
Step 3: Configure Grafana
  1. Access Grafana in your browser:
  2. Log in with:
    • Username: admin
    • Password: strongpassword (or whatever you set in docker-compose)
  3. Add Prometheus as a data source:
    • Click on “Configuration” (gear icon) in the left sidebar
    • Select “Data sources”
    • Click “Add data source”
    • Select “Prometheus”
    • Set URL to: http://prometheus:9090
    • Click “Save & Test” to verify connection
Part 4: Creating the Traefik Dashboard
Method 1: Import a Pre-made Dashboard
  1. In Grafana, click the “+” icon in the left sidebar
  2. Select “Import”
  3. Enter one of these dashboard IDs:
    • 17346 (Traefik Dashboard)
    • 2870 (Traefik v3 Dashboard)
  4. Click “Load”
  5. Select your Prometheus data source
  6. Click “Import”
Method 2: Build a Custom Dashboard
If you prefer to build your own dashboard, follow these steps:
  1. Click the “+” icon in the left sidebar
  2. Select “Create Dashboard”
  3. Click “Add new panel”
  4. Create a panel for Request Rate:
    • In the Query field enter: sum(rate(traefik_service_requests_total[1m])) by (service)
    • Panel title: “Requests per minute by service”
    • Visualization: “Time series”
    • Click “Apply”
  5. Create a panel for Response Status Codes:
    • Click “Add panel”
    • Query: sum(traefik_service_requests_total) by (code)
    • Panel title: “Response Status Codes”
    • Visualization: “Pie Chart”
    • Click “Apply”
  6. Create a panel for Request Duration:
    • Click “Add panel”
    • Query: histogram_quantile(0.95, sum(rate(traefik_service_request_duration_seconds_bucket[5m])) by (le, service))
    • Panel title: “Request Duration (95th percentile)”
    • Click “Apply”
  7. Create a panel for Connections:
    • Click “Add panel”
    • Query: traefik_entrypoint_open_connections{entrypoint="websecure"}
    • Panel title: “Open Connections (HTTPS)”
    • Visualization: “Stat”
    • Click “Apply”
  8. Save your dashboard:
    • Click the save icon in the top right
    • Name: “Traefik Monitoring”
    • Click “Save”
Part 5: Advanced Traefik Metrics
Here are some additional panels you might want to add:
  1. Add a panel for Error Rates:
    • New panel
    • Query: sum(rate(traefik_service_requests_total{code=~"5.*"}[1m])) by (service) / sum(rate(traefik_service_requests_total[1m])) by (service)
    • Title: “Error Rate by Service”
  2. Add a panel for Entrypoint Traffic:
    • New panel
    • Query: sum(rate(traefik_entrypoint_requests_total[1m])) by (entrypoint)
    • Title: “Requests by Entrypoint”
  3. Add a panel for Top Routes:
    • New panel
    • Query: topk(10, sum(traefik_router_requests_total) by (router))
    • Title: “Top 10 Routes”
    • Visualization: “Bar gauge”
Part 6: Troubleshooting
If you don’t see metrics:
  1. Check if Traefik is exposing metrics:
curl http://localhost:8080/metrics
  1. Verify Prometheus can reach Traefik:
docker exec -it prometheus wget -O- gerbil:8080/metrics
  1. Check Prometheus logs:
docker logs prometheus
  1. Check if Traefik metrics are in Prometheus:
  2. Make sure ports are correctly exposed:
docker-compose ps
Part 7: Setting Up Alerts (Optional)
  1. In Grafana, go to Alerting in the left sidebar
  2. Click “New alert rule”
  3. Configure a rule, for example:
    • Query: sum(rate(traefik_service_requests_total{code=~"5.*"}[1m])) > 5
    • Condition: When value is above 5
    • For: 5m
    • Set rule name: “High error rate”
  4. Set notification channels
  5. Save the rule
That’s it! You now have a complete Grafana dashboard to monitor your Traefik metrics from your Pangolin stack.
How does this work with the new network_mode / default bridge that they’ve got in the v1 docker-compose.yml? Ultimately, it looks like prometheus doesn’t have access to traefik via docker network, even though they all seem to share the default bridge “pangolin” network?
  default:
    driver: bridge
it looks like this should be docker exec -it prometheus wget -O- gerbil:8080/metrics with the new network_mode: service:gerbil setting…
… as such, I modified the config/prometheus/prometheus.yml file as follows:
scrape_configs:
    static_configs:
