Detailed Guide: Creating a Grafana Dashboard for CrowdSec Metrics in Pangolin Stack- Part 1
I’ll guide you through setting up a Grafana dashboard to monitor your CrowdSec metrics step by step. This guide assumes you have your Pangolin stack with CrowdSec already running.
Part 1: Understanding the Components
  • CrowdSec: Security automation tool that detects and responds to attacks
  • Prometheus: Collects and stores metrics
  • Grafana: Visualizes metrics in dashboards
Part 2: Setting Up Prometheus
Step 1: Create a Prometheus Configuration File
  1. Create a directory for Prometheus:
mkdir -p config/prometheus
  1. Create a prometheus.yml file:
nano config/prometheus/prometheus.yml
  1. Add the following configuration:
global:
  scrape_interval: 15s
  evaluation_interval: 15s
scrape_configs:
  - job_name: 'crowdsec'
    static_configs:
      - targets: ['crowdsec:6060']
Step 2: Add Prometheus to Your Docker Compose
  1. Edit your docker-compose.yml file:
nano docker-compose.yml
  1. Add the Prometheus service:
prometheus:
  image: prom/prometheus:latest
  container_name: prometheus
    - pangolin
    - ./config/prometheus:/etc/prometheus
    - ./config/prometheus_data:/prometheus
  command:
    - '--config.file=/etc/prometheus/prometheus.yml'
    - '--storage.tsdb.path=/prometheus'
    - '--web.console.libraries=/etc/prometheus/console_libraries'
    - '--web.console.templates=/etc/prometheus/consoles'
    - "9091:9090"
Step 3: Apply Changes
  1. Apply the changes to your Docker Compose stack:
docker compose down
docker compose up -d
  1. Verify Prometheus is running:
docker ps | grep prometheus
  1. Check if Prometheus is collecting metrics by visiting:
Part 3: Setting Up Grafana
Step 1: Add Grafana to Docker Compose
  1. Edit your docker-compose.yml file again:
  1. Add the Grafana service:
grafana:
  image: grafana/grafana:latest
  container_name: grafana
    - pangolin
    - ./config/grafana:/var/lib/grafana
    - GF_SECURITY_ADMIN_USER=admin
    - GF_SECURITY_ADMIN_PASSWORD=strongpassword
    - GF_USERS_ALLOW_SIGN_UP=false
    - "3035:3000"
  1. Apply the changes:
  1. Verify Grafana is running:
docker ps | grep grafana
Step 2: Configure Grafana
  1. Access Grafana in your browser:
  2. Log in with:
    • Username: admin
    • Password: strongpassword (or whatever you set in docker-compose)
  3. Add Prometheus as a data source:
    • Click on “Configuration” (gear icon) in the left sidebar
    • Select “Data sources”
    • Click “Add data source”
    • Select “Prometheus”
    • Set URL to: http://prometheus:9090
    • Click “Save & Test” to verify connection
Part 4: Creating the CrowdSec Dashboard
Step 1: Import a Pre-made Dashboard
  1. In Grafana, click the “+” icon in the left sidebar
  2. Select “Import”
  3. Enter dashboard ID: 21419 (CrowdSec official dashboard)
  4. Click “Load”
  5. Select your Prometheus data source
  6. Click “Import”
Step 2: Create a Custom Dashboard (Alternative)
If you prefer to build your own:
  1. Click the “+” icon in the left sidebar
  2. Select “Create Dashboard”
  3. Click “Add new panel”
  4. Configure the first panel to show active decisions:
    • In the Query field enter: crowdsec_active_decisions
    • Panel title: “Active Decisions”
    • Visualization: “Stat”
    • Click “Apply”
  5. Add a panel for bouncer activity:
    • Click “Add panel”
    • Query: crowdsec_bouncer_requests_total
    • Panel title: “Bouncer Requests”
    • Visualization: “Time series”
    • Click “Apply”
  6. Add a panel for decisions by type:
    • Click “Add panel”
    • Query: sum by (type) (crowdsec_decisions_total)
    • Panel title: “Decisions by Type”
    • Visualization: “Pie Chart”
    • Click “Apply”
  7. Add a panel for top attacked IPs:
    • Click “Add panel”
    • Query: topk(10, sum by (source_ip) (crowdsec_decisions_total))
    • Panel title: “Top Attacked IPs”
    • Visualization: “Bar Gauge”
    • Click “Apply”
  8. Save your dashboard:
    • Click the save icon (disk) in the top right
    • Give your dashboard a name: “CrowdSec Monitoring”
    • Click “Save”
Part 5: Adding CrowdSec-Specific Panels
  1. Add a panel for alerts by scenario:
    • New panel
    • Query: sum by (scenario) (crowdsec_alerts_total)
    • Title: “Alerts by Scenario”
    • Visualization: “Bar chart”
  2. Add a panel for parser metrics:
    • New panel
    • Query: sum by (parser) (crowdsec_parser_hits_total)
    • Title: “Parser Activity”
  3. Add a panel for API metrics:
    • New panel
    • Query: sum by (endpoint) (crowdsec_http_requests_total)
    • Title: “API Endpoint Activity”
Part 6: Troubleshooting
If you don’t see metrics:
  1. Check if CrowdSec is exposing metrics:
curl http://localhost:6060/metrics
  1. Verify Prometheus can reach CrowdSec:
docker exec -it prometheus wget -O- crowdsec:6060/metrics
  1. Check Prometheus logs:
docker logs prometheus
  1. Check if the metrics are in Prometheus:
  2. Inspect your docker network:
docker network inspect pangolin
Part 7: Setting Up Alerts (Optional)
  1. In Grafana, go to Alerting in the left sidebar
  2. Click “New alert rule”
  3. Configure a rule, for example:
    • Query: sum(crowdsec_active_decisions) > 100
    • Condition: When value is above 100
    • For: 5m
    • Set rule name: “High number of CrowdSec decisions”
  4. Set notification channels (email, Slack, etc.)
  5. Save the rule
That’s it! You now have a complete Grafana dashboard to monitor your CrowdSec metrics from your Pangolin stack.
Full Compose file for Ref
  pangolin:
    driver: bridge
  pangolin:
    image: public.ecr.aws/g5j5p7x0/pangolin2:pre1
    container_name: pangolin
      - pangolin
      - ./config:/app/config
    healthcheck:
      interval: "3s"
      timeout: "3s"
      retries: 5
  gerbil:
    image: fosrl/gerbil:1.0.0-beta.3
    container_name: gerbil
    depends_on:
      pangolin:
        condition: service_healthy
      - pangolin
    command:
      - ./config/:/var/config
    cap_add:
      - NET_ADMIN
      - SYS_MODULE
      - 51820:51820/udp
      - 8085:8080 # Port for traefik dashboard
      - 443:443 # Port for traefik because of the network_mode
      - 80:80 # Port for traefik because of the network_mode
  # Add CrowdSec services
  crowdsec:
    image: crowdsecurity/crowdsec:latest
    container_name: crowdsec
      GID: "1000"
      COLLECTIONS: crowdsecurity/traefik crowdsecurity/appsec-virtual-patching crowdsecurity/appsec-generic-rules
      ENROLL_INSTANCE_NAME: "pangolin-crowdsec"
      ENROLL_KEY: dhoashdfosahosdhfoisdhfjhdfjsdpvjdsj
      ACQUIRE_FILES: "/var/log/traefik/*.log"
      ENROLL_TAGS: docker
      - pangolin
    healthcheck:
      test: ["CMD", "cscli", "capi", "status"]
    depends_on:
      - gerbil
    labels:
      - "traefik.enable=false"
      # crowdsec container data
      - ./config/crowdsec:/etc/crowdsec
      - ./config/crowdsec/db:/var/lib/crowdsec/data
      # log bind mounts into crowdsec
      - ./config/crowdsec_logs/auth.log:/var/log/auth.log:ro
      - ./config/crowdsec_logs/syslog:/var/log/syslog:ro
      - ./config/crowdsec_logs:/var/log
      - 8080:8080 # port mapping for local firewall bouncers
      - 6060:6060 # metrics endpoint for prometheus
    expose:
      - 8080 # http api for bouncers
      - 6060 # metrics endpoint for prometheus
      - 7422 # appsec waf endpoint
    command: -t # Add test config flag to verify configuration
  traefik:
    image: traefik:v3.3.3
    container_name: traefik
    network_mode: service:gerbil # Ports appear on the gerbil service
    depends_on:
      pangolin:
    command:
      - ./config/traefik:/etc/traefik:ro # Volume to store the Traefik configuration
      - ./config/letsencrypt:/letsencrypt # Volume to store the Let's Encrypt certificates
      - ./config/traefik/conf/:/etc/traefik/conf/
      - ./config/traefik/rules:/rules
  prometheus:
      - pangolin
    depends_on:
      - crowdsec
    command:
      - 9091:9090
  grafana:
      - pangolin
    depends_on:
      - crowdsec
      - GF_SECURITY_ADMIN_USER=admin12
      - GF_SECURITY_ADMIN_PASSWORD=strongpassword1
      - 3035:3000
@german and @daschmidt guide is tested on my machine and deployment is smooth.
I’ve tried everything to get it to work, my grafana/prometheus are running at home, but pangolin is running on a vps at Hetzner. I don’t want to open too many ports etc., so I played around with headscale (I prefer it to tailscale because of self-hosting), but I can’t get it to work because of the port conflicts with pangolin. I’ll let you know when I’ve managed it, because more people will definitely use it if they have part of it on an external vps.
Hi, Can I ask if I can keep the Pangolin yml file clean and spin up the Grafana dashboard separately, will that work? And same for for Prometheus or maybe combine Prometheus and Grafana in one docker compose to spin up but keeping Panglin compose untouched…
One more thing would a VPS with 2gb ram and 1vpu handle all the containers you think?
I got this working and also with Traefik though it’s not exactly helpful with Traefik yet. I’m sure you know how to do it but I redirected the port through gerbil after enabling the metrics in the traefik-config.yml and it’s all working well.
I do have a stupid question though. Pangolin is obviously on a VPS and I have rerouted all my home services through it… but how do I get access to the Grafana dashboard without an IP address? Would I use the Traefik reverse proxy on the VPS already somehow?
Because I need to make an * A record, rerouting to it is going to be difficult and awkward, surely? Or am I missing something incredibly simple? I thought about installing newt on the VPS so it had it’s own site but surely that would cause issues?
Thanks for any advice given.
tailscale is your answer. simple and efficient. that was your firewall remains intact and you don’t need to open any ports.
I would like to add traefik dashboard in grafana can you explain why traefik dashboard is not helpful…and how to add the traefik dashboard instead of crowdsec.
That seems correct to me create prometheus and grafana containers and just add pangolin network to them and add to resources using local site.I would like to add traefik dashboard to grafana.
