Deploying **WG-EASY** with **Pangolin**
is there setup information for connecting to a wg-easy deployment on my home server through the VPS which hosts Pangolin? I’m behind CG-NAT so I can’t connect to my home network.
I did it on my phone, just download the client(windows/mac/linux) and upload/setup the config file. that’s it. your traffic is routed through VPS. thats simple.
Maybe I am mis-understanding the purpose of using wg-easy but I am not able to access my home network resources. Is that supposed to be the case? The wireguard VPN works and shows my IP as my VPS IP, just can’t access my home servers.
You will have to give a bit more on how your home network is setup and how routes are configured on your vpn
Everything for the VPN side is a copy and paste from your guide. The only thing I changed was the WG_HOST variable in the compose file to my domain (vpn.mydomain.xyz). When I connected my phone through wireguard I left everything as default.
I’m not sure what exactly to describe about my home network. I have a bunch of servers running on a mac mini and it’s also running Newt that connects it to Pangolin on my VPS.
