Comprehensive Guide: Deploying Pangolin on AlmaLinux in AWS
https://asciinema.org/a/EXTNqMyTMpxMJRyPxQcvwTv78
This guide will walk you through deploying Pangolin, a self-hosted tunneled reverse proxy management server, on an AlmaLinux EC2 instance in AWS.
1. Prerequisites
- An AWS account
- A domain name with access to DNS settings
- Basic knowledge of AWS services and Linux command line
2. AWS Setup
Creating an EC2 Instance
- Log in to the AWS Management Console and navigate to EC2
- Click “Launch Instance”
- Provide a name (e.g., “pangolin-server”)
- Select “AlmaLinux 9” from the AMI catalog (search in AWS Marketplace)
- Choose an instance type:
- Recommended: t3.micro (1 vCPU, 1GB RAM) for testing
- Production: t3.small (2 vCPU, 2GB RAM) or better
- Create or select a key pair for SSH access
- Configure network settings:
- Create a new security group with the following rules:
- SSH (TCP port 22) from your IP
- HTTP (TCP port 80) from anywhere
- HTTPS (TCP port 443) from anywhere
- WireGuard (UDP port 51820) from anywhere
- Configure storage (8GB minimum, 20GB recommended)
- Launch the instance
Allocate an Elastic IP
- Navigate to “Elastic IPs” in the EC2 dashboard
- Click “Allocate Elastic IP address”
- Select “Amazon’s pool of IPv4 addresses”
- Click “Allocate”
- Select the newly allocated IP and click “Associate Elastic IP address”
- Select your EC2 instance and click “Associate”
3. DNS Configuration
- In your domain registrar’s DNS settings, create the following records:
- An A record for your root domain (e.g.,
example.com) pointing to your Elastic IP - An A record for a subdomain (e.g.,
proxy.example.com) pointing to your Elastic IP - A wildcard A record (e.g.,
*.example.com) pointing to your Elastic IP
4. Server Preparation
Connect to Your Instance
ssh -i your-key.pem ec2-user@your-elastic-ip
Update the System
sudo dnf update -y
sudo dnf install -y curl wget git vim
Install Docker and Docker Compose
# Install Docker
sudo dnf config-manager --add-repo https://download.docker.com/linux/centos/docker-ce.repo
sudo dnf install -y docker-ce docker-ce-cli containerd.io
# Start and enable Docker
sudo systemctl start docker
sudo systemctl enable docker
# Add your user to the docker group (optional but recommended)
sudo usermod -aG docker $USER
# Log out and back in for this to take effect
# Install Docker Compose
sudo curl -L "https://github.com/docker/compose/releases/latest/download/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
sudo chmod +x /usr/local/bin/docker-compose
sudo ln -s /usr/local/bin/docker-compose /usr/bin/docker-compose
Create the Pangolin Directory
mkdir -p ~/pangolin
cd ~/pangolin
5. Install Pangolin
Download and Run the Installer
# Download the installer (AMD64 architecture)
wget -O installer "https://github.com/fosrl/pangolin/releases/download/1.0.0-beta.14/installer_linux_amd64" && chmod +x ./installer
# Run the installer as root
sudo ./installer
When prompted, provide the following information:
- Base Domain Name: Your domain (e.g.,
example.com) - Dashboard Domain Name: Your preferred dashboard domain (e.g.,
proxy.example.com) - Let’s Encrypt Email: Your email for SSL certificate registration
- Tunneling: Choose “Yes” to install Gerbil for tunneling support
- Admin Email: Email for the admin account (e.g.,
admin@example.com) - Admin Password: Create a strong password meeting the requirements
- Security Settings:
- Disable signup without invite (recommended)
- Allow/disallow users to create organizations based on your needs
- Email Configuration (optional but recommended):
- SMTP host
- SMTP port
- SMTP username
- SMTP password
- No-reply email address
The installer will:
- Create necessary directories
- Generate configuration files
- Pull Docker images
- Start the containers
6. Verify Installation
Check Container Status
cd ~/pangolin
docker compose ps
You should see the following containers running:
- pangolin
- gerbil
- traefik
- crowdsec (optional)
Check Logs
# Check logs for all containers
docker compose logs
# Or check logs for a specific container
docker compose logs pangolin
Access the Dashboard
Open your browser and navigate to your dashboard domain (e.g., https://proxy.example.com).
You should see the Pangolin login page.
7. Initial Configuration
First Login
- Log in with the admin email and password you provided during installation
- Follow the setup wizard:
- Create your first organization
- Create your first site
Create a Site
- Go to the “Sites” tab and click “Add Site”
- Give your site a name (e.g., “Home Lab”)
- Choose your connection method:
- Newt (recommended for most users)
- WireGuard (advanced)
- Copy the connection command/configuration
- Click “Create Site”
Connect a Client
Using Newt:
On your client machine (the one you want to expose services from):
# Download Newt (change architecture if needed)
wget -O newt "https://github.com/fosrl/newt/releases/latest/download/newt_linux_amd64"
chmod +x ./newt
# Run Newt with the credentials copied from the Pangolin UI
./newt \
--id YOUR_ID \
--secret YOUR_SECRET \
--endpoint https://your-domain.com
Create a Resource
- Go to the “Resources” tab and click “Add Resource”
- Give your resource a name
- Choose a subdomain for this resource
- Select the site you created earlier
- Click “Create Resource”
Configure Resource
On the “Connectivity” page:
- Keep “Enable SSL” enabled for HTTPS
- Add a target (e.g.,
http://192.168.1.100:8080) - Click “Add Target” and “Save Changes”
On the “Authentication” page:
- Choose your preferred authentication method
- Configure accordingly
- Save changes
8. Advanced Configuration (Optional)
Edit Configuration File
cd ~/pangolin
sudo vim config/config.yml
Refer to the Configuration documentation for all available options.
Set Up Wildcard Certificates
For better performance with multiple subdomains, consider setting up wildcard certificates:
- Edit the Traefik configuration:
sudo vim config/traefik/traefik_config.yml
Update the
certificatesResolverssection to use DNS challenge instead of HTTP challenge -
Set
prefer_wildcard_cert: truein your Pangolin configuration
9. Troubleshooting
Container Issues
If containers aren’t starting:
# Check logs
docker compose logs
# Restart containers
docker compose down
docker compose up -d
Certificate Issues
If Let’s Encrypt certificates aren’t being generated:
- Check that ports 80 and 443 are open in your AWS security group
- Verify your DNS settings are pointing to your Elastic IP
- Check Traefik logs:
docker compose logs traefik
Connection Issues
If clients can’t connect to your Pangolin server:
- Verify port 51820 (UDP) is open in your AWS security group
- Check Gerbil logs:
docker compose logs gerbil
10. Maintenance
Backing Up Data
# Stop containers
cd ~/pangolin
docker compose down
# Backup config directory
sudo tar -czvf pangolin-backup-$(date +%Y%m%d).tar.gz config/
Updating Pangolin
cd ~/pangolin
# Stop the stack
docker compose down
# Update the docker-compose.yml file with new version numbers
# Edit versions in docker-compose.yml:
# - pangolin:VERSION
# - gerbil:VERSION
# Pull the latest images
docker compose pull
# Start the stack
You now have a fully functional Pangolin deployment on AlmaLinux in AWS!
For more information and advanced features, refer to the official Pangolin documentation.
