#18 · 2026-11-25 · Severity: Critical
Threat types: vulnerability-exploit, iot-ot, zero-day · Industries: cross-industry
Verified status
| CVE | CVSS | Vendor/product | Exploitation | References |
| CVE-2026-103406 | 9.8 | Hewlett Packard Enterprise (HPE) Juniper Session Smart Conductor and Session Smart Router | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-131914 | 9.3 | Idunno AntiCsrf | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-132224 | 7.1 | Optimizely Web Experimentation | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-132165 | N/A | Drupal Core | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-135792 | 9.3 | — | None known | NVD |
| CVE-2026-135797 | 9.3 | — | None known | NVD |
| CVE-2026-136549 | 9.3 | — | None known | NVD |
| CVE-2026-120705 | N/A | — | None known | NVD |
| CVE-2026-129243 | N/A | — | None known | NVD |
Checked against NVD and CISA KEV on 2026-11-25.
TL;DR
- Top story: Hewlett Packard Enterprise (HPE) Juniper Session Smart Conductor and Session Smart Router: OS Command Injection Vulnerability
- Also notable: Drupal Core: Remote Code Execution Vulnerability
- Also notable: Idunno AntiCsrf: Deserialization of Untrusted Data Vulnerability
- 4 new CISA KEV entries in this window
Executive summary
The overall threat level for this window is critical. We tracked 4 new CISA KEV entries, 63 critical or high CVEs published, and 45 new ransomware victims listed. The briefing tracked 6 verified CVEs for the first time.
Top threats
1. Hewlett Packard Enterprise (HPE) Juniper Session Smart Conductor and Session Smart Router: OS Command Injection Vulnerability
CVE-2026-103406 | Disclosed: October 28, 2026
Project : Hewlett Packard Enterprise (HPE) Juniper Session Smart Conductor and Session Smart Router
New today
Technical Details : Critical CVE-2026-103406 carries a CVSS score of 9.8 and has been confirmed exploited in the wild, prompting CISA to set a remediation due date of November 28, 2026. Operators of Hewlett Packard Enterprise (HPE) Juniper Session Smart Conductor and Session Smart Router should patch or mitigate the vulnerability following vendor guidance, as no workaround has been published. Additionally, review exposed systems for signs of exploitation and verify service health after applying the fix.
- Severity : Critical (CVSS 9.8)
- Affected : Affected versions are not listed in the available sources.
- Fixed : Check the vendor release notes.
- Workaround : None published. Upgrade when a fix is available.
| CVE | CVSS | Exploitation | EPSS | Action |
| CVE-2026-103406 | 9.8 | Confirmed exploited (CISA KEV) | 0.9% (56th percentile) | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-103406 following the vendor guidance. CISA set a remediation due date of 2026-11-28.
- Review exposed systems for signs of exploitation.
- If remediation requires a restart, verify the fix and service health afterward.
Official References
Reference : CVE-2026-103406
2. Drupal Core: Remote Code Execution Vulnerability
CVE-2026-132165 | Disclosed: November 24, 2026
Project : Drupal Core
New today
Technical Details : Drupal Core contains a not failing securely vulnerability that could allow an unauthenticated attacker to take over an existing site or execute arbitrary code via the Drupal installer. CISA confirmed exploitation in the wild.
- Severity : Unscored
| CVE-2026-132165 | N/A | Confirmed exploited (CISA KEV) | N/A | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-132165 following the vendor guidance. CISA set a remediation due date of 2026-11-27.
Official References
- NVD CVE-2026-132165: NVD - Home
- CISA KEV: Known Exploited Vulnerabilities Catalog | CISA
- The Hacker News: Drupal Fail2Install Exploit Details Emerge as Critical RCE Flaw Faces Active Exploitation
Reference : CVE-2026-132165
3. Idunno AntiCsrf: Deserialization of Untrusted Data Vulnerability
CVE-2026-131914 | Disclosed: November 19, 2026
Project : Idunno AntiCsrf
Technical Details : Deserialization of untrusted data in double-submit cookie vs. CISA confirmed exploitation in the wild.
- Severity : Critical (CVSS 9.3)
- Affected : blowdart anticsrf 0.9.0, blowdart anticsrf 0.9.1
| CVE-2026-131914 | 9.3 | Confirmed exploited (CISA KEV) | 4.3% (92nd percentile) | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-131914 following the vendor guidance. CISA set a remediation due date of 2026-11-27.
Official References
- NVD CVE-2026-131914: NVD - Home
- SecurityWeek: Hackers Exploit Unpatched Flaw in Defunct Idunno AntiCsrf Library - SecurityWeek
Reference : CVE-2026-131914
4. Hackers now exploit critical Drupal RCE flaw to hijack sites
Source : BleepingComputer
Technical Details : BleepingComputer published the linked report. Compare the report with activity in your environment.
- Affected : Not applicable
- Fixed : Not applicable
- Workaround : Not applicable
Remediation Steps
- Check the linked report for products you run and verify details with the vendor before acting.
- Record which systems or detection rules need follow-up.
Official References
- BleepingComputer: https://www.bleepingcomputer.com/news/security/hackers-now-exploit-critical-drupal-rce-flaw-to-hijack-sites/
Reference : BleepingComputer
5. Microsoft confirms authentication issues after November updates
Remediation Steps
Official References
- BleepingComputer: https://www.bleepingcomputer.com/news/microsoft/microsoft-confirms-authentication-issues-after-november-updates/
Ongoing: previously reported
| CVE | Vendor/product | CVSS | KEV due date | First reported |
| CVE-2026-133968 | Project MONAI MONAI Label | 9.8 | 2026-11-26 | 2026-11-24 |
| CVE-2026-134624 | N-able MailAssure | 9.3 | 2026-11-26 | 2026-11-23 |
| CVE-2026-115731 | Perforce Puppet Enterprise | 9.4 | 2026-12-01 | 2026-11-18 |
| CVE-2026-40217 | BerriAI LiteLLM | 8.8 | 2026-12-02 | 2026-11-19 |
Today’s action checklist
- Patch or mitigate the newly listed CISA KEV vulnerabilities (CVE-2026-103406, CVE-2026-132224, CVE-2026-132165, CVE-2026-131914) first; they are exploited in the wild and carry a CISA due date.
- Ransomware activity is concentrated in Unknown: verify offline backups, patch internet-facing edge devices and review remote-access logins.
- Review the linked CISA ICS advisories if you run the affected industrial or IoT products, and keep them off the internet.
- Pull current indicators from the linked abuse.ch and OTX pages and add them to blocklists or detection rules where relevant.
- Read the linked sources for the products you run and subscribe to vendor security notices.
Indicators
45 new ransomware victims were listed in this window.
| Sector | Victims | Most active groups |
| Unknown | 14 | N0n, SilentRansomGroup, medusalocker |
| Professional Services | 7 | SilentRansomGroup, spacebears, incransom |
| Manufacturing | 6 | thegentlemen, play, PixelLeaks |
| Other | 5 | thegentlemen, spacebears, play |
| Retail & E-Commerce | 3 | rhysida, play, thegentlemen |
Raw indicators are not republished here. Pull them from the source pages.
- ThreatFox: 1862 new IOCs (view on threatfox.abuse.ch)
- URLhaus: 100 new malicious URLs (view on urlhaus.abuse.ch)
- MalwareBazaar: 10 new malware samples (view on bazaar.abuse.ch)
Source notes
- CISA Advisories check failed for this window.
- CISA ICS Advisories check failed for this window.
- OTX skipped: OTX_KEY not set
Sources
- CISA Known Exploited Vulnerabilities Catalog
- CISA Cybersecurity Advisories and ICS Advisories
- This product uses data from the NVD API but is not endorsed or certified by the NVD
- EPSS scores by FIRST
- Ransomware victim data: ransomware.live
- Data: abuse.ch (URLhaus, ThreatFox, MalwareBazaar) Used non-commercially.
- BleepingComputer
- The Hacker News
- SecurityWeek
- The Record
- Krebs on Security
- NCSC UK
- CERT-EU
AI-assisted, published automatically, not human-reviewed; verify with vendors before acting.
