#17 · 2026-11-24 · Severity: Critical
Threat types: vulnerability-exploit, zero-day · Industries: cross-industry
Verified status
| CVE | CVSS | Vendor/product | Exploitation | References |
| CVE-2026-133968 | 9.8 | Project MONAI MONAI Label | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-134624 | 9.3 | N-able MailAssure | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-135202 | 9.8 | — | None known | NVD |
| CVE-2026-135211 | 9.2 | — | None known | NVD |
| CVE-2026-135743 | 9.2 | — | None known | NVD |
| CVE-2026-87268 | 7.8 | oracle vm_virtualbox | None known | NVD |
| CVE-2026-123903 | N/A | — | None known | NVD |
Checked against NVD and CISA KEV on 2026-11-24.
TL;DR
- The top story is the N-able MailAssure SpamExperts Server-Side Request Forgery vulnerability. Other notable entries include the Project MONAI MONAI Label Path Traversal vulnerability and advisory 3. Additionally, VMware vCenter was hit by another critical 9.8-rated auth bypass flaw following zero-day exploitation.
- 2 new CISA KEV entries in this window
Executive summary
The overall threat level is critical. Monitoring identified 2 new CISA KEV entries, 49 critical or high CVEs published, and 17 new ransomware victims listed. Additionally, 5 verified CVEs were tracked for the first time. Since yesterday, 5 items were newly tracked, consisting of CVE-2026-133968, CVE-2026-135202, CVE-2026-135211, CVE-2026-135743, and CVE-2026-87268.
Top threats
1. N-able MailAssure: (SpamExperts) Server-Side Request Forgery (SSRF) Vulnerability
CVE-2026-134624 | Disclosed: November 22, 2026
Project : N-able MailAssure
Technical Details : N-able MailAssure (SpamExperts) before 20261121.1943 does not restrict the destination of the LDAP synchronisation connection check performed when a relay is configured. CISA confirmed exploitation in the wild.
- Severity : Critical (CVSS 9.3)
- Affected : n-able mail assure < 20261121.1943
- Fixed : Check the vendor release notes.
- Workaround : None published. Upgrade when a fix is available.
| CVE | CVSS | Exploitation | EPSS | Action |
| CVE-2026-134624 | 9.3 | Confirmed exploited (CISA KEV) | 0.6% (50th percentile) | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-134624 following the vendor guidance. CISA set a remediation due date of 2026-11-26.
- Review exposed systems for signs of exploitation.
- If remediation requires a restart, verify the fix and service health afterward.
Official References
- NVD CVE-2026-134624: NVD - Home
- CISA KEV: Known Exploited Vulnerabilities Catalog | CISA
- Vendor advisory: NableMe
- The Hacker News: Hackers Exploit N-able MailAssure Flaw While AI Agents Exploit MONAI Label Zero-Day
Reference : CVE-2026-134624
2. Project MONAI MONAI Label: Path Traversal Vulnerability
CVE-2026-133968 | Disclosed: November 20, 2026
GHSA-qc22-rmgc-vg94
Project : Project MONAI MONAI Label
New today
Technical Details : CISA confirmed exploitation in the wild. Use the linked guidance to check your exposure.
- Severity : Critical (CVSS 9.8)
- Affected : monai monai label < 0.8.6
| CVE-2026-133968 | 9.8 | Confirmed exploited (CISA KEV) | 49.8% (99th percentile) | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-133968 following the vendor guidance. CISA set a remediation due date of 2026-11-26.
Official References
- NVD CVE-2026-133968: https://nvd.nist.gov/vuln/detail/CVE-2026-133968
- Vendor advisory: Path traversal in datastore upload endpoints allows arbitrary file write · Advisory · Project-MONAI/MONAILabel · GitHub
Reference : CVE-2026-133968
3. VMware vCenter Hit by Another Critical 9.8-Rated Auth Bypass Flaw After Zero-Day Exploitation
Source : The Hacker News
Technical Details : The Hacker News published the linked report. Compare the report with activity in your environment.
- Affected : Not applicable
- Fixed : Not applicable
- Workaround : Not applicable
Remediation Steps
- Check the linked report for products you run and verify details with the vendor before acting.
- Record which systems or detection rules need follow-up.
Official References
- The Hacker News: VMware vCenter Hit by Another Critical 9.8-Rated Auth Bypass Flaw After Zero-Day Exploitation
Reference : The Hacker News
4. CVE-2026-135211: BISHENG before 3.0.0 contains a missing authentication vulnerability in the /api/v2/workflow/invoke and…
CVE-2026-135211 | Disclosed: November 23, 2026
New today
Technical Details : BISHENG before 3.0.0 contains a missing authentication vulnerability in the /api/v2/workflow/invoke and /api/v2/workflow/stop routes that allows unauthenticated attackers to run workflows as the administrator. Use the linked guidance to check your exposure.
- Severity : Critical (CVSS 9.2)
- Affected : Affected versions are not listed in the available sources.
| CVE-2026-135211 | 9.2 | None known | 1.1% (67th percentile) | Patch within 72h |
Remediation Steps
- Check whether you run the affected product and apply the vendor fix when it is available.
- Prioritise internet-facing systems.
Official References
Reference : CVE-2026-135211
5. CVE-2026-135202: Several plugins for WordPress published by WP connect
CVE-2026-135202 | Disclosed: November 24, 2026
New today
Technical Details : The linked advisory records provide details for CVE-2026-135202. Use the linked guidance to check your exposure.
| CVE-2026-135202 | 9.8 | None known | 0.6% (49th percentile) | Patch within 72h |
Remediation Steps
Official References
Reference : CVE-2026-135202
Ongoing: previously reported
| CVE | Vendor/product | CVSS | KEV due date | First reported |
| CVE-2026-111793 | Openwave Messaging Limited Webtop Media Transcoder | 4.3 | 2026-11-24 | 2026-11-11 |
| CVE-2026-124194 | Microsoft Office | 6.5 | 2026-11-24 | 2026-11-11 |
| CVE-2026-125350 | Google Chromium | 8.8 | 2026-11-24 | 2026-11-10 |
| CVE-2026-20320 | Cisco BroadWorks | 7.5 | 2026-11-24 | 2026-11-11 |
| CVE-2026-115731 | Perforce Puppet Enterprise | 9.4 | 2026-12-01 | 2026-11-18 |
| CVE-2026-40217 | BerriAI LiteLLM | 8.8 | 2026-12-02 | 2026-11-19 |
Today’s action checklist
- Patch or mitigate the newly listed CISA KEV vulnerabilities (CVE-2026-134624, CVE-2026-133968) first; they are exploited in the wild and carry a CISA due date.
- Ransomware activity is concentrated in Manufacturing: verify offline backups, patch internet-facing edge devices and review remote-access logins.
- Pull current indicators from the linked abuse.ch and OTX pages and add them to blocklists or detection rules where relevant.
- Read the linked sources for the products you run and subscribe to vendor security notices.
Indicators
17 new ransomware victims were listed in this window.
| Sector | Victims | Most active groups |
| Manufacturing | 4 | qilin, aurora |
| Education | 3 | PixelLeaks, Dark Project, Scarlettgroup |
| Government & Defense | 2 | PixelLeaks, SoulGroup |
| Professional Services | 2 | Aoqin, rhysida |
| Technology | 2 | safepay, medusalocker |
Raw indicators are not republished here. Pull them from the source pages.
- ThreatFox: 6068 new IOCs (view on threatfox.abuse.ch)
- URLhaus: 100 new malicious URLs (view on urlhaus.abuse.ch)
- MalwareBazaar: 25 new malware samples (view on bazaar.abuse.ch)
Source notes
- CISA Advisories check failed for this window.
- CISA ICS Advisories check failed for this window.
- OTX skipped: OTX_KEY not set
Sources
- CISA Known Exploited Vulnerabilities Catalog
- CISA Cybersecurity Advisories and ICS Advisories
- This product uses data from the NVD API but is not endorsed or certified by the NVD
- EPSS scores by FIRST
- Ransomware victim data: ransomware.live
- Data: abuse.ch (URLhaus, ThreatFox, MalwareBazaar) Used non-commercially.
- BleepingComputer
- The Hacker News
- SecurityWeek
- The Record
- Krebs on Security
- NCSC UK
- CERT-EU
AI-assisted, published automatically, not human-reviewed; verify with vendors before acting.
