Daily Threat Briefing: Tuesday, November 17, 2026
#10 · 2026-11-17 · Severity: Critical
Threat types: vulnerability-exploit, ransomware, zero-day · Industries: healthcare, technology
Verified status
CVE CVSS Vendor/product Exploitation References
CVE-2026-84869 9.9 ConnectWise ScreenConnect Confirmed exploited (CISA KEV) NVD · CISA KEV
CVE-2026-129952 9.3 — None known NVD
CVE-2026-130366 9.2 — None known NVD
CVE-2026-130371 9.2 — None known NVD
Checked against NVD and CISA KEV on 2026-11-17.
TL;DR
  • Top story: CVE-2026-130366: AdminNeo before 5.9.1 contains an authentication bypass vulnerability in the ClickHouse driver
  • Also notable: CVE-2026-130371: phpMyFAQ before 4.1.12 and 4.2.0-alpha before 4.2.0-RC.2 contains an authentication bypass vulnerability…
  • Also notable: CVE-2026-129952: NodePress through 8.5.1 contains an authentication bypass vulnerability that allows unauthenticated remote…
  • No new CISA KEV entries in this window
Executive summary
The overall threat level for this window is critical. We tracked 38 critical or high CVEs published, and 45 new ransomware victims listed. The briefing tracked 4 verified CVEs for the first time.
Top threats
1. CVE-2026-130366: AdminNeo before 5.9.1 contains an authentication bypass vulnerability in the ClickHouse driver
CVE-2026-130366 | Disclosed: November 17, 2026
New today
Technical Details : AdminNeo before 5.9.1 contains an authentication bypass vulnerability in the ClickHouse driver that allows remote attackers to log in to passwordless accounts without the configured defaultPasswordHash password. Use the linked guidance to check your exposure.
  • Severity : Critical (CVSS 9.2)
  • Affected : Affected versions are not listed in the available sources.
  • Fixed : Check the vendor release notes.
  • Workaround : None published. Upgrade when a fix is available.
CVE CVSS Exploitation EPSS Action
CVE-2026-130366 9.2 None known 0.6% (49th percentile) Patch within 72h
Remediation Steps
  1. Check whether you run the affected product and apply the vendor fix when it is available.
  2. Prioritise internet-facing systems.
  3. Review exposed systems for signs of exploitation.
  4. If remediation requires a restart, verify the fix and service health afterward.
Official References
Reference : CVE-2026-130366
2. CVE-2026-130371: phpMyFAQ before 4.1.12 and 4.2.0-alpha before 4.2.0-RC.2 contains an authentication bypass vulnerability…
CVE-2026-130371 | Disclosed: November 17, 2026
New today
Technical Details : phpMyFAQ before 4.1.12 and 4.2.0-alpha before 4.2.0-RC.2 contains an authentication bypass vulnerability because the web installer ignores the legacy config/database.php during 3.x upgrades. Use the linked guidance to check your exposure.
CVE-2026-130371 9.2 None known 0.5% (46th percentile) Patch within 72h
Remediation Steps
Official References
Reference : CVE-2026-130371
3. CVE-2026-129952: NodePress through 8.5.1 contains an authentication bypass vulnerability that allows unauthenticated remote…
CVE-2026-129952 | Disclosed: November 16, 2026
New today
Technical Details : NodePress through 8.5.1 contains an authentication bypass vulnerability that allows unauthenticated remote attackers to gain administrator access by forging JWTs with the hardcoded ‘nodepress-secret’ fallback key. Use the linked guidance to check your exposure.
  • Severity : Critical (CVSS 9.3)
CVE-2026-129952 9.3 None known 0.5% (46th percentile) Patch within 72h
Remediation Steps
Official References
Reference : CVE-2026-129952
4. N-able Kills Legacy APIs, Patches 17 N-central Zero-Days
Source : SecurityWeek
Technical Details : Operators should compare the SecurityWeek report with activity in their environment, check the report for products they run, and verify details with the vendor before acting. This high-severity issue requires recording which systems or detection rules need follow-up.
  • Severity : High
  • Affected : Not applicable
  • Fixed : Not applicable
  • Workaround : Not applicable
Remediation Steps
  1. Check the linked report for products you run and verify details with the vendor before acting.
  2. Record which systems or detection rules need follow-up.
Official References
Reference : SecurityWeek
5. Ransomware: 45 new victims listed across 12 sectors
Source : ransomware.live
Technical Details : The ransomware.live feed listed 45 victims across 12 sectors in this window, with Healthcare being the most affected sector at 9 listings. The severity is high. Operators should verify offline backups, patch internet-facing edge devices, review remote-access logins, and record which systems or detection rules need follow-up.
  • Severity : High
Remediation Steps
  1. Verify offline backups, patch internet-facing edge devices and review remote-access logins.
Official References
Reference : ransomware.live
Ongoing: previously reported
CVE Vendor/product CVSS KEV due date First reported
CVE-2026-19868 SonicWall SonicOS SSLVPN 7.5 2026-11-20 2026-11-09
CVE-2026-111793 Openwave Messaging Limited Webtop Media Transcoder 4.3 2026-11-24 2026-11-11
CVE-2026-124194 Microsoft Office 6.5 2026-11-24 2026-11-11
CVE-2026-125350 Google Chromium 8.8 2026-11-24 2026-11-10
CVE-2026-20320 Cisco BroadWorks 7.5 2026-11-24 2026-11-11
Today’s action checklist
  • Ransomware activity is concentrated in Healthcare: verify offline backups, patch internet-facing edge devices and review remote-access logins.
  • Pull current indicators from the linked abuse.ch and OTX pages and add them to blocklists or detection rules where relevant.
  • Read the linked sources for the products you run and subscribe to vendor security notices.
Indicators
45 new ransomware victims were listed in this window.
Sector Victims Most active groups
Healthcare 9 Vortex, Curious Worm, Inception
Manufacturing 8 qilin, Vortex, aurora
Technology 7 qilin, everstake, Inception
Unknown 5 PixelLeaks, Curious Worm, SilentRansomGroup
Financial Services 4 Inception, Vortex, Shiba
Raw indicators are not republished here. Pull them from the source pages.
Source notes
  • CISA Advisories check failed for this window.
  • CISA ICS Advisories check failed for this window.
  • OTX skipped: OTX_KEY not set
Sources
AI-assisted, published automatically, not human-reviewed; verify with vendors before acting.
