#19 · 2026-11-26 · Severity: Critical
Threat types: vulnerability-exploit · Industries: cross-industry
Verified status
| CVE | CVSS | Vendor/product | Exploitation | References |
| CVE-2026-103406 | 9.8 | Hewlett Packard Enterprise (HPE) Juniper Session Smart Conductor and Session Smart Router | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-133303 | 9.8 | Mitel MiCollab | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-133323 | 9.8 | Mitel MiCollab | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-133469 | 9.8 | Vates Xen Orchestra | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2023-25914 | 8.8 | Danfoss AK-SM 800A Series | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2023-25915 | 8.8 | Danfoss AK-SM 800A Series | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2025-41450 | 7.5 | Danfoss AK-SM 800A Series | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-133311 | 5.9 | Mitel MiCollab | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-133275 | 5.3 | Mitel MiCollab | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-133324 | 5.3 | Mitel MiCollab | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-132165 | N/A | Drupal Core | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-136823 | 9.3 | — | None known | NVD |
| CVE-2026-137090 | 9.3 | — | None known | NVD |
| CVE-2026-77230 | 9.2 | — | None known | NVD |
| CVE-2026-136716 | N/A | — | None known | NVD |
Checked against NVD and CISA KEV on 2026-11-26.
TL;DR
- The top story features an improper validation of specified type of input vulnerability in Vates Xen Orchestra. Additionally, notable advisories cover Mitel MiCollab regarding an OS command injection vulnerability and an XML injection vulnerability.
- 10 new CISA KEV entries in this window
Executive summary
The overall threat level for this window is critical. We tracked 10 new CISA KEV entries, 85 critical or high CVEs published, and 25 new ransomware victims listed. The briefing tracked 13 verified CVEs for the first time.
Top threats
1. Vates Xen Orchestra: Improper Validation of Specified Type of Input Vulnerability
CVE-2026-133469 | Disclosed: November 23, 2026
GHSA-2r3w-c2vx-fv5g
Project : Vates Xen Orchestra
New today
Technical Details : XO (Xen Orchestra) is a solution to visualize, manage, backup and delegate your XCP-ng (or XenServer) infrastructure. CISA confirmed exploitation in the wild.
- Severity : Critical (CVSS 9.8)
- Affected : xen-orchestra xen orchestra server < 5.211.2, xen-orchestra xen orchestra server > 5.213.0, < 5.213.1, xen-orchestra xen orchestra < 6.9.2, xen-orchestra xen orchestra ≥ 6.10.0, < 6.10.1
- Fixed : 6.9.2
- Workaround : None published. Upgrade when a fix is available.
| CVE | CVSS | Exploitation | EPSS | Action |
| CVE-2026-133469 | 9.8 | Confirmed exploited (CISA KEV) | 31.8% (99th percentile) | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-133469 following the vendor guidance. CISA set a remediation due date of 2026-11-28.
- Review exposed systems for signs of exploitation.
- If remediation requires a restart, verify the fix and service health afterward.
Official References
- NVD CVE-2026-133469: NVD - Home
- CISA KEV: Known Exploited Vulnerabilities Catalog | CISA
- Vendor advisory: VSA-2026-062: Empty-object login token | Vates VMS Documentation
- Vendor advisory: Empty-object login token · Advisory · vatesfr/xen-orchestra · GitHub
Reference : CVE-2026-133469
2. Mitel MiCollab: OS Command Injection Vulnerability
CVE-2026-133323 | Disclosed: November 19, 2026
Project : Mitel MiCollab
New today
Technical Details : CISA confirmed exploitation in the wild. Use the linked guidance to check your exposure.
- Affected : mitel micollab ≤ 10.3.0.18
- Fixed : Check the vendor release notes.
| CVE-2026-133323 | 9.8 | Confirmed exploited (CISA KEV) | 5.6% (94th percentile) | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-133323 following the vendor guidance. CISA set a remediation due date of 2026-11-28.
Official References
- NVD CVE-2026-133323: NVD - Home
- Vendor advisory: Mitel Product Security Advisory MISA-2026-0012 | Mitel
Reference : CVE-2026-133323
3. Mitel MiCollab: XML Injection Vulnerability
CVE-2026-133303 | Disclosed: November 19, 2026
New today
Technical Details : A critical XML injection vulnerability, tracked as CVE-2026-133303 with a CVSS score of 9.8, affects Mitel MiCollab versions 10.3.0.18 and prior. CISA has confirmed exploitation in the wild and set a remediation due date of November 28, 2026, with an EPSS score of 1.3 percent at the 71st percentile. Operators should check the vendor release notes to patch or mitigate the issue, review exposed systems for signs of exploitation, and verify service health after any required restarts.
| CVE-2026-133303 | 9.8 | Confirmed exploited (CISA KEV) | 1.3% (71st percentile) | Patch now |
Remediation Steps
- Patch or mitigate CVE-2026-133303 following the vendor guidance. CISA set a remediation due date of 2026-11-28.
Official References
- NVD CVE-2026-133303: NVD - Home
Reference : CVE-2026-133303
4. CVE-2026-136823: A vulnerability was found in D-Link R32 1.10B02.
CVE-2026-136823 | Disclosed: November 25, 2026
New today
Technical Details : A vulnerability was found in D-Link R32 1.10B02. Use the linked guidance to check your exposure.
- Severity : Critical (CVSS 9.3)
- Affected : Affected versions are not listed in the available sources.
| CVE-2026-136823 | 9.3 | None known | 2.5% (85th percentile) | Patch within 72h |
Remediation Steps
- Check whether you run the affected product and apply the vendor fix when it is available.
- Prioritise internet-facing systems.
Official References
Reference : CVE-2026-136823
5. CVE-2026-137090: build-git-clone before 1.0.4 contains an OS command injection vulnerability
CVE-2026-137090 | Disclosed: November 25, 2026
New today
Technical Details : build-git-clone before 1.0.4 contains an OS command injection vulnerability in the clone() function that allows attackers to execute commands by supplying crafted repository URLs. Use the linked guidance to check your exposure.
| CVE-2026-137090 | 9.3 | None known | 2.3% (84th percentile) | Patch within 72h |
Remediation Steps
Official References
Reference : CVE-2026-137090
Ongoing: previously reported
| CVE | Vendor/product | CVSS | KEV due date | First reported |
| CVE-2026-133968 | Project MONAI MONAI Label | 9.8 | 2026-11-26 | 2026-11-24 |
| CVE-2026-134624 | N-able MailAssure | 9.3 | 2026-11-26 | 2026-11-23 |
| CVE-2026-131914 | Idunno AntiCsrf | 9.3 | 2026-11-27 | 2026-11-23 |
| CVE-2026-132224 | Optimizely Web Experimentation | 7.1 | 2026-11-27 | 2026-11-25 |
| CVE-2026-115731 | Perforce Puppet Enterprise | 9.4 | 2026-12-01 | 2026-11-18 |
| CVE-2026-40217 | BerriAI LiteLLM | 8.8 | 2026-12-02 | 2026-11-19 |
Today’s action checklist
- Patch or mitigate the newly listed CISA KEV vulnerabilities (CVE-2026-133469, CVE-2026-133324, CVE-2026-133323, CVE-2026-133311, CVE-2026-133303) first; they are exploited in the wild and carry a CISA due date.
- Ransomware activity is concentrated in Manufacturing: verify offline backups, patch internet-facing edge devices and review remote-access logins.
- Pull current indicators from the linked abuse.ch and OTX pages and add them to blocklists or detection rules where relevant.
- Read the linked sources for the products you run and subscribe to vendor security notices.
Indicators
25 new ransomware victims were listed in this window.
| Sector | Victims | Most active groups |
| Manufacturing | 5 | everest, PixelLeaks, Dark Project |
| Unknown | 5 | N0n, netrunner, medusalocker |
| Professional Services | 4 | rhysida, SilentRansomGroup |
| Financial Services | 3 | N0n |
| Education | 2 | interlock, Scarlettgroup |
Raw indicators are not republished here. Pull them from the source pages.
- ThreatFox: 2496 new IOCs (view on threatfox.abuse.ch)
- URLhaus: 100 new malicious URLs (view on urlhaus.abuse.ch)
- MalwareBazaar: 16 new malware samples (view on bazaar.abuse.ch)
Source notes
- CISA Advisories check failed for this window.
- CISA ICS Advisories check failed for this window.
- OTX skipped: OTX_KEY not set
Sources
- CISA Known Exploited Vulnerabilities Catalog
- CISA Cybersecurity Advisories and ICS Advisories
- This product uses data from the NVD API but is not endorsed or certified by the NVD
- EPSS scores by FIRST
- Ransomware victim data: ransomware.live
- Data: abuse.ch (URLhaus, ThreatFox, MalwareBazaar) Used non-commercially.
- BleepingComputer
- The Hacker News
- SecurityWeek
- The Record
- Krebs on Security
- NCSC UK
- CERT-EU
AI-assisted, published automatically, not human-reviewed; verify with vendors before acting.
