#9 · 2026-11-16 · Severity: Critical
Threat types: vulnerability-exploit, ransomware · Industries: healthcare
Verified status
| CVE | CVSS | Vendor/product | Exploitation | References |
| CVE-2026-114713 | 7.7 | UnrealIRCd UnrealIRCd | Confirmed exploited (CISA KEV) | NVD · CISA KEV |
| CVE-2026-129483 | 9.3 | — | None known | NVD |
| CVE-2026-129550 | 9.3 | — | None known | NVD |
| CVE-2026-129552 | 9.3 | — | None known | NVD |
Checked against NVD and CISA KEV on 2026-11-16.
TL;DR
- Cyrus SASL through version 2.1.28 contains an authentication bypass vulnerability designated as CVE-2026-129483. Additionally, Tensei through version 0.11.5 contains vulnerabilities in @tensei/auth, specifically a privilege escalation vulnerability tracked as CVE-2026-129550 and an authentication bypass vulnerability tracked as CVE-2026-129552.
- No new CISA KEV entries in this window
Executive summary
The overall threat level for this window is critical. We tracked 9 critical or high CVEs published, and 23 new ransomware victims listed. The briefing tracked 3 verified CVEs for the first time.
Top threats
1. CVE-2026-129483: Cyrus SASL through 2.1.28 contains an authentication bypass vulnerability
CVE-2026-129483 | Disclosed: November 15, 2026
New today
Technical Details : Cyrus SASL through 2.1.28 contains an authentication bypass vulnerability in the SRP server mechanism because srp_server_mech_step2 does not reject client public values A that are multiples of N. Use the linked guidance to check your exposure.
- Severity : Critical (CVSS 9.3)
- Affected : Affected versions are not listed in the available sources.
- Fixed : Check the vendor release notes.
- Workaround : None published. Upgrade when a fix is available.
| CVE | CVSS | Exploitation | EPSS | Action |
| CVE-2026-129483 | 9.3 | None known | N/A | Patch within 72h |
Remediation Steps
- Check whether you run the affected product and apply the vendor fix when it is available.
- Prioritise internet-facing systems.
- Review exposed systems for signs of exploitation.
- If remediation requires a restart, verify the fix and service health afterward.
Official References
Reference : CVE-2026-129483
2. CVE-2026-129550: Tensei through 0.11.5 contains a privilege escalation vulnerability in @tensei/auth that allows…
CVE-2026-129550 | Disclosed: November 16, 2026
New today
Technical Details : Tensei through 0.11.5 contains a privilege escalation vulnerability in @tensei/auth that allows unauthenticated or authenticated users to assign themselves arbitrary roles via the exposed User Roles field. Use the linked guidance to check your exposure.
| CVE-2026-129550 | 9.3 | None known | N/A | Patch within 72h |
Remediation Steps
Official References
Reference : CVE-2026-129550
3. CVE-2026-129552: Tensei through 0.11.5 contains an authentication bypass vulnerability in @tensei/auth
CVE-2026-129552 | Disclosed: November 16, 2026
New today
Technical Details : Tensei through 0.11.5 contains an authentication bypass vulnerability in @tensei/auth that falls back to the hard-coded JWT signing key ‘auth-secret-key’ when JWT_SECRET is unset. Use the linked guidance to check your exposure.
| CVE-2026-129552 | 9.3 | None known | N/A | Patch within 72h |
Remediation Steps
Official References
Reference : CVE-2026-129552
4. Ransomware: 23 new victims listed across 9 sectors
Source : ransomware.live
Technical Details : The ransomware.live feed listed 23 victims in this window, with Manufacturing being the most affected sector at 9 listings. Operators should verify offline backups, patch internet-facing edge devices, and review remote-access logins. Finally, record which systems or detection rules need follow-up.
- Severity : High
- Affected : Not applicable
- Fixed : Not applicable
- Workaround : Not applicable
Remediation Steps
- Verify offline backups, patch internet-facing edge devices and review remote-access logins.
- Record which systems or detection rules need follow-up.
Official References
- ransomware.live: https://www.ransomware.live
Reference : ransomware.live
5. UnrealIRCd UnrealIRCd: Recent UnrealIRCd Vulnerability Exploited in Attacks
CVE-2026-114713 | Disclosed: November 8, 2026
Project : UnrealIRCd UnrealIRCd
Technical Details : Operators running UnrealIRCd versions prior to 6.2.7.1 should patch now, as CISA has confirmed exploitation in the wild for CVE-2026-114713, a high-severity vulnerability with a CVSS score of 7.7. There are no published workarounds available, and users must check the vendor release notes to upgrade. Review exposed systems for signs of exploitation and verify service health after applying the fix.
- Severity : High (CVSS 7.7)
- Affected : unrealircd unrealircd < 6.2.7.1
| CVE-2026-114713 | 7.7 | Confirmed exploited (CISA KEV) | 0.5% (44th percentile) | Patch now |
Remediation Steps
- Check the linked report for products you run and verify details with the vendor before acting.
Official References
- NVD CVE-2026-114713: NVD - Home
- CISA KEV: Known Exploited Vulnerabilities Catalog | CISA
- Vendor advisory: https://forums.unrealircd.org/viewtopic.php?t=9487
- SecurityWeek: Recent UnrealIRCd Vulnerability Exploited in Attacks - SecurityWeek
Reference : CVE-2026-114713
Ongoing: previously reported
| CVE | Vendor/product | CVSS | KEV due date | First reported |
| CVE-2026-123039 | Check Point Multiple Products | 7.8 | 2026-11-16 | 2026-11-13 |
| CVE-2026-19868 | SonicWall SonicOS SSLVPN | 7.5 | 2026-11-20 | 2026-11-09 |
| CVE-2026-111793 | Openwave Messaging Limited Webtop Media Transcoder | 4.3 | 2026-11-24 | 2026-11-11 |
| CVE-2026-124194 | Microsoft Office | 6.5 | 2026-11-24 | 2026-11-11 |
| CVE-2026-125350 | Google Chromium | 8.8 | 2026-11-24 | 2026-11-10 |
| CVE-2026-20320 | Cisco BroadWorks | 7.5 | 2026-11-24 | 2026-11-11 |
Today’s action checklist
- Ransomware activity is concentrated in Manufacturing: verify offline backups, patch internet-facing edge devices and review remote-access logins.
- Pull current indicators from the linked abuse.ch and OTX pages and add them to blocklists or detection rules where relevant.
- Read the linked sources for the products you run and subscribe to vendor security notices.
Indicators
23 new ransomware victims were listed in this window.
| Sector | Victims | Most active groups |
| Manufacturing | 9 | qilin, metaencryptor, ShadowByt3$ |
| Healthcare | 3 | ShadowByt3$, PixelLeaks, lockbit5 |
| Retail & E-Commerce | 3 | metaencryptor, ShadowByt3$, Aoqin |
| Energy & Utilities | 2 | ShadowByt3$, Vortex |
| Unknown | 2 | PixelLeaks, qilin |
Raw indicators are not republished here. Pull them from the source pages.
- ThreatFox: 1141 new IOCs (view on threatfox.abuse.ch)
- URLhaus: 100 new malicious URLs (view on urlhaus.abuse.ch)
- MalwareBazaar: 20 new malware samples (view on bazaar.abuse.ch)
Source notes
- CISA Advisories check failed for this window.
- CISA ICS Advisories check failed for this window.
- OTX skipped: OTX_KEY not set
Sources
- CISA Known Exploited Vulnerabilities Catalog
- CISA Cybersecurity Advisories and ICS Advisories
- This product uses data from the NVD API but is not endorsed or certified by the NVD
- EPSS scores by FIRST
- Ransomware victim data: ransomware.live
- Data: abuse.ch (URLhaus, ThreatFox, MalwareBazaar) Used non-commercially.
- BleepingComputer
- The Hacker News
- SecurityWeek
- The Record
- Krebs on Security
- NCSC UK
- CERT-EU
AI-assisted, published automatically, not human-reviewed; verify with vendors before acting.
