#20 · 2026-11-27 · Severity: Critical
Threat types: vulnerability-exploit, data-breach, zero-day · Industries: cross-industry
Verified status
| CVE | CVSS | Vendor/product | Exploitation | References |
| CVE-2026-106125 | 9.8 | — | None known | NVD |
| CVE-2026-99362 | 9.8 | — | None known | NVD |
| CVE-2026-137544 | 9.4 | — | None known | NVD |
| CVE-2026-137499 | 9.3 | — | None known | NVD |
Checked against NVD and CISA KEV on 2026-11-27.
TL;DR
- An unpatched Cacti zero-day vulnerability enables remote code execution in just four HTTP requests using guest access. Additionally, a new NFS2ROOT Linux flaw can allow attackers to gain root privileges. Finally, Drupal has issued a warning regarding a new site takeover flaw that is currently being exploited in attacks.
- No new CISA KEV entries in this window
Executive summary
The overall threat level for this reporting window is critical. Analysts tracked 97 critical or high CVEs published, along with 19 new ransomware victims listed and 4 verified CVEs tracked for the first time. Since yesterday, four new vulnerabilities were identified: CVE-2026-106125, CVE-2026-137499, CVE-2026-137544, and CVE-2026-99362.
Top threats
1. Unpatched Cacti Zero-Day Enables RCE in Just Four HTTP Requests via Guest Access
Source : The Hacker News
Technical Details : The Hacker News published the linked report. Compare the report with activity in your environment.
- Severity : Critical
- Affected : Not applicable
- Fixed : Not applicable
- Workaround : Not applicable
Remediation Steps
- Check the linked report for products you run and verify details with the vendor before acting.
- Record which systems or detection rules need follow-up.
Official References
Reference : The Hacker News
2. New NFS2ROOT Linux flaw can let attackers gain root privileges
CVE-2026-99362 | Disclosed: November 19, 2026
New today
Technical Details : The linked advisory records provide details for CVE-2026-99362. Use the linked guidance to check your exposure.
- Severity : Critical (CVSS 9.8)
- Affected : Affected versions are not listed in the available sources.
- Fixed : Check the vendor release notes.
- Workaround : None published. Upgrade when a fix is available.
| CVE | CVSS | Exploitation | EPSS | Action |
| CVE-2026-99362 | 9.8 | None known | 0.8% (51st percentile) | Patch within 72h |
Remediation Steps
- Review exposed systems for signs of exploitation.
- If remediation requires a restart, verify the fix and service health afterward.
Official References
- NVD CVE-2026-99362: NVD - Home
- BleepingComputer: https://www.bleepingcomputer.com/news/security/new-nfs2root-linux-flaw-can-let-attackers-gain-root-privileges/
Reference : CVE-2026-99362
3. Drupal warns of new site takeover flaw exploited in attacks
Source : BleepingComputer
Technical Details : BleepingComputer published the linked report. Compare the report with activity in your environment.
Remediation Steps
Official References
- BleepingComputer: https://www.bleepingcomputer.com/news/security/drupal-warns-of-new-access-bypass-flaw-exploited-in-attacks/
Reference : BleepingComputer
4. CVE-2026-137544: LaraDashboard before 1.5.0 contains a path traversal vulnerability in module.json providers
CVE-2026-137544 | Disclosed: November 26, 2026
New today
Technical Details : LaraDashboard before 1.5.0 contains a path traversal vulnerability in module.json providers and composer.json psr-4 namespace parsing that derives destination folder names without excluding traversal characters. Use the linked guidance to check your exposure.
- Severity : Critical (CVSS 9.4)
| CVE-2026-137544 | 9.4 | None known | 1.5% (74th percentile) | Patch within 72h |
Remediation Steps
- Check whether you run the affected product and apply the vendor fix when it is available.
- Prioritise internet-facing systems.
Official References
Reference : CVE-2026-137544
5. CVE-2026-106125: The Sneeit Framework plugin for WordPress is vulnerable to Remote Code Execution in versions up
CVE-2026-106125 | Disclosed: November 27, 2026
New today
Technical Details : The Sneeit Framework plugin for WordPress is vulnerable to Remote Code Execution in versions up to, and including, 8.7 via the ‘callback’ parameter of the sneeit_compact_menu_mega_content AJAX action. Use the linked guidance to check your exposure.
| CVE-2026-106125 | 9.8 | None known | 1.2% (69th percentile) | Patch within 72h |
Remediation Steps
Official References
Reference : CVE-2026-106125
Ongoing: previously reported
| CVE | Vendor/product | CVSS | KEV due date | First reported |
| CVE-2026-131914 | Idunno AntiCsrf | 9.3 | 2026-11-27 | 2026-11-23 |
| CVE-2026-132165 | Drupal Core | N/A | 2026-11-27 | 2026-11-25 |
| CVE-2026-132224 | Optimizely Web Experimentation | 7.1 | 2026-11-27 | 2026-11-25 |
| CVE-2023-25914 | Danfoss AK-SM 800A Series | 8.8 | 2026-11-28 | 2026-11-26 |
| CVE-2023-25915 | Danfoss AK-SM 800A Series | 8.8 | 2026-11-28 | 2026-11-26 |
| CVE-2026-103406 | Hewlett Packard Enterprise (HPE) Juniper Session Smart Conductor and Session Smart Router | 9.8 | 2026-11-28 | 2026-11-25 |
| CVE-2026-133275 | Mitel MiCollab | 5.3 | 2026-11-28 | 2026-11-26 |
| CVE-2026-133303 | Mitel MiCollab | 9.8 | 2026-11-28 | 2026-11-26 |
| CVE-2026-133323 | Mitel MiCollab | 9.8 | 2026-11-28 | 2026-11-26 |
| CVE-2026-133324 | Mitel MiCollab | 5.3 | 2026-11-28 | 2026-11-26 |
Today’s action checklist
- Ransomware activity is concentrated in Professional Services: verify offline backups, patch internet-facing edge devices and review remote-access logins.
- Pull current indicators from the linked abuse.ch and OTX pages and add them to blocklists or detection rules where relevant.
- Read the linked sources for the products you run and subscribe to vendor security notices.
Indicators
19 new ransomware victims were listed in this window.
| Sector | Victims | Most active groups |
| Professional Services | 4 | direwolf, PixelLeaks, aurora |
| Technology | 4 | PixelLeaks, medusalocker, Inception |
| Financial Services | 3 | PixelLeaks |
| Energy & Utilities | 2 | bravox, Whitearmor |
| Retail & E-Commerce | 2 | anubis, qilin |
Raw indicators are not republished here. Pull them from the source pages.
- ThreatFox: 2028 new IOCs (view on threatfox.abuse.ch)
- URLhaus: 100 new malicious URLs (view on urlhaus.abuse.ch)
- MalwareBazaar: 6 new malware samples (view on bazaar.abuse.ch)
Source notes
- CISA Advisories check failed for this window.
- CISA ICS Advisories check failed for this window.
- OTX skipped: OTX_KEY not set
Sources
- CISA Known Exploited Vulnerabilities Catalog
- CISA Cybersecurity Advisories and ICS Advisories
- This product uses data from the NVD API but is not endorsed or certified by the NVD
- EPSS scores by FIRST
- Ransomware victim data: ransomware.live
- Data: abuse.ch (URLhaus, ThreatFox, MalwareBazaar) Used non-commercially.
- BleepingComputer
- The Hacker News
- SecurityWeek
- The Record
- Krebs on Security
- NCSC UK
- CERT-EU
AI-assisted, published automatically, not human-reviewed; verify with vendors before acting.
