CrowdSec Manager for Pangolin: User Guide
From Bash Script to Web Application: The CrowdSec Manager Evolution
Migration
CrowdSec Manager has evolved from a command-line bash script into a full-featured web application. This migration represents a significant leap forward in usability, functionality, and maintainability. In this post, we’ll explore the journey, the improvements, and how to migrate from the old script-based approach to the new web-based solution.
The Evolution: Why We Migrated
The Original Bash Script
The original CrowdSec Manager was a comprehensive bash script (setup_crowdsec_manager.sh) that provided 15 menu-driven options for managing CrowdSec in a Pangolin Docker environment. While functional, it had limitations:
  • Terminal-only interface: Required SSH access and command-line knowledge
  • Limited interactivity: Menu-driven navigation with text prompts
  • No persistent state: Settings weren’t saved between sessions
  • Manual log viewing: Required terminal commands to view logs
  • No real-time monitoring: Static views of system status
  • Limited automation: Difficult to integrate with other tools
The New Web Application
The new CrowdSec Manager is a modern, full-stack application built with:
  • Backend: Go (Golang) with Gin web framework
  • Frontend: React 18 with TypeScript, Vite, and Shadcn/ui components
  • Architecture: RESTful API with WebSocket support for real-time features
  • Database: SQLite for persistent settings and configuration
  • Deployment: Docker container for easy deployment
Key Improvements
1. Modern Web Interface
Before (Bash Script):
CrowdSec Manager - Main Menu
1. Check System Health
2. Run Complete Diagnostic Check
Enter your choice [0-15]:
After (Web Application):
  • Beautiful, responsive web UI accessible from any browser
  • Real-time dashboard with live status updates
  • Intuitive navigation with sidebar menu
  • Visual indicators for system health
  • Interactive charts and graphs for metrics
2. Real-Time Features
New Capabilities:
  • Live Log Streaming: WebSocket-based real-time log viewing for all services
  • Live Status Updates: Automatic refresh of container status and metrics
  • Real-Time Decision Monitoring: Watch security decisions as they happen
  • Live Alert Feed: See security alerts in real-time
Before: Static log viewing required manual terminal commands
docker logs -f crowdsec
After: Click a button in the web UI to stream logs with automatic scrolling and filtering
3. Enhanced IP Management
New Features:
  • Visual IP Security Dashboard: See all blocked IPs with reasons and timestamps
  • Bulk Operations: Manage multiple IPs at once
  • IP History: Track IP actions over time
  • Advanced Filtering: Search and filter decisions by type, reason, or date
  • Quick Actions: One-click unban, whitelist, or block operations
Before: Manual IP entry through text prompts
Enter IP to unban: 1.2.3.4
After: Visual table with search, sort, and bulk actions
4. Comprehensive Backup System
New Capabilities:
  • Automated Backups: Schedule backups with cron job integration
  • Backup Management UI: View, restore, and delete backups visually
  • Retention Policies: Automatic cleanup of old backups
  • Backup Verification: Check backup integrity before restoration
  • One-Click Restore: Restore entire system with a single click
Before: Manual backup creation required script execution
After: Automated scheduling with visual management interface
5. Advanced Log Analysis
New Features:
  • Multi-Service Log Viewer: View logs from CrowdSec, Traefik, Pangolin, and Gerbil
  • Advanced Traefik Analysis: Statistics, top IPs, status codes, and more
  • Log Filtering: Filter by service, date, or search term
  • Export Capabilities: Download logs for analysis
  • Real-Time Streaming: Watch logs as they’re generated
Before: Separate commands for each service
docker logs crowdsec --tail 50
docker logs traefik --tail 50
After: Unified log viewer with tabs for each service and real-time streaming
6. Decision and Alert Analysis
New Capabilities:
  • Decision Analysis Dashboard: Visual breakdown of security decisions
  • Alert Analysis: Detailed analysis of CrowdSec alerts
  • Trend Visualization: See security trends over time
  • Export Reports: Generate reports for analysis
Before: Simple list of blocked IPs
After: Comprehensive analysis with charts and statistics
7. Enhanced Configuration Management
New Features:
  • Visual Configuration Editor: Edit CrowdSec and Traefik configs through the UI
  • Settings Persistence: Save preferences and settings in database
  • Configuration Validation: Validate configs before applying
  • Version History: Track configuration changes
Before: Manual file editing with vi/nano
After: Web-based editor with syntax highlighting and validation
8. Service Management
New Capabilities:
  • Service Control Panel: Start, stop, restart services from the UI
  • Service Health Monitoring: Real-time status of all services
  • Graceful Shutdown: Safe shutdown procedures
  • Service Dependencies: Visual representation of service relationships
![Services Management](images/Services Management.png)
9. Cron Job Management
New Feature:
  • Visual Cron Editor: Create and manage cron jobs through the UI
  • Pre-configured Jobs: Templates for common tasks
  • Job History: View execution history and logs
![Cron Job Management](images/Cron Job Management.png)
10. System Updates
New Capabilities:
  • Update Management UI: Update Docker images with custom tags
  • Rollback Support: Automatic rollback on failure
  • Update History: Track update operations
  • Flexible Updates: Update with or without CrowdSec
![System Update](images/System Update.png)
Feature Comparison
| Feature | Bash Script | Web Application |
| Interface | Terminal menu | Modern web UI |
| Access | SSH required | Browser from anywhere |
| Real-Time Logs | Manual docker logs -f | WebSocket streaming |
| IP Management | Text prompts | Visual table with search |
| Backup Management | Manual script execution | Automated with UI |
| Log Analysis | Basic tail commands | Advanced analysis with stats |
| Decision Analysis | Simple list | Charts and trends |
| Configuration | File editing | Web-based editor |
| Multi-User | Single terminal session | Multiple concurrent users |
| Mobile Access | Not practical | Responsive design |
| API Access | N/A | Full REST API |
| Settings Persistence | None | SQLite database |
| Automation | Limited | Cron job integration |
Migration Guide
For Existing Bash Script Users
If you’re currently using the bash script version, here’s how to migrate:
Step 1: Backup Your Current Setup
# Create a backup of your current configuration
./setup_crowdsec_manager.sh
# Select option for backup (if available)
# Or manually backup:
cp -r /root/config ./backup-config-$(date +%Y%m%d)
Step 2: Prepare for Migration
# Ensure you have Docker and Docker Compose installed
docker --version
docker compose version
# Create required directories
sudo mkdir -p /root/config /root/config/traefik/logs
mkdir -p ./backups ./data
# Ensure the pangolin network exists
docker network create pangolin
Step 3: Deploy the Web Application
# Pull the latest image
docker pull hhftechnology/crowdsec-manager:latest
# Create docker-compose.yml (see README.md for full config)
# Start the container
docker compose up -d
# Verify it's running
docker ps | grep crowdsec-manager
curl http://localhost:8080/health
Step 4: Access the Web Interface
  1. Open your browser to http://your-server-ip:8080
  2. Verify all services are running via the Dashboard
  3. Whitelist your current IP (Whitelist Management page)
  4. Review your existing configuration
Step 5: Migrate Settings
The web application will automatically detect your existing CrowdSec and Traefik configurations. However, you may want to:
  1. Review Whitelists: Check that all whitelisted IPs are present
  2. Verify Scenarios: Ensure custom scenarios are still active
  3. Check Captcha Setup: Verify captcha configuration if previously set up
  4. Review Backups: Create a new backup through the UI
Step 6: Set Up Automation
  1. Configure Automated Backups: Set up cron jobs through the Cron Management page
  2. Schedule Health Checks: Use the API to set up monitoring
  3. Configure Alerts: Set up notifications for critical events
API Access
One of the major advantages of the new application is full API access. You can now integrate CrowdSec Manager with other tools:
Example: Automated IP Whitelisting
#!/bin/bash
# Whitelist current IP automatically
curl -X POST http://localhost:8080/api/whitelist/current \
-H "Content-Type: application/json" \
-d '{"add_to_crowdsec": true, "add_to_traefik": true}'
Example: Health Check Monitoring
#!/bin/bash
# Check system health and alert if issues found
HEALTH=$(curl -s http://localhost:8080/api/health/complete)
if echo "$HEALTH" | grep -q '"status":"error"'; then
# Send alert notification
echo "CrowdSec Manager health check failed!"
fi
Example: Automated Backup
#!/bin/bash
# Create backup via API
curl -X POST http://localhost:8080/api/backup/create \
-d '{"dry_run": false}'
Technical Architecture
Backend (Go)
  • Framework: Gin web framework for high performance
  • Docker Integration: Direct Docker API access for container management
  • Database: SQLite for lightweight, file-based storage
  • Logging: Structured logging with configurable levels
  • API: RESTful API with comprehensive error handling
Frontend (React)
  • Framework: React 18 with TypeScript
  • Build Tool: Vite for fast development and builds
  • UI Components: Shadcn/ui for modern, accessible components
  • State Management: TanStack Query for server state
  • Routing: React Router for navigation
  • Styling: Tailwind CSS for responsive design
Key Technologies
  • WebSockets: Real-time log streaming and updates
  • Docker API: Direct container management
  • File System Access: Read/write configuration files
  • Cron Integration: Schedule automated tasks
  • Backup System: Comprehensive backup and restore
Benefits of the Migration
For End Users
  1. Easier Access: No SSH required, access from any browser
  2. Better UX: Intuitive interface with visual feedback
  3. Real-Time Monitoring: See what’s happening as it happens
  4. Mobile Friendly: Responsive design works on phones/tablets
  5. Multi-User Support: Multiple people can use it simultaneously
For Administrators
  1. Better Monitoring: Comprehensive dashboards and analytics
  2. Automation: Cron job integration for scheduled tasks
  3. API Access: Integrate with other tools and scripts
  4. Audit Trail: Database tracks all operations
  5. Easier Maintenance: Web-based configuration management
For Developers
  1. Extensible: Well-structured codebase for adding features
  2. API-First: Full REST API for integration
  3. Modern Stack: Go and React are industry-standard technologies
  4. Type Safety: TypeScript prevents common errors
  5. Maintainable: Clean architecture and separation of concerns
What’s Next?
The migration to a web application opens up many possibilities:
  • Mobile App: Native mobile applications using the API
  • Multi-Instance Support: Manage multiple CrowdSec installations
  • Advanced Analytics: Machine learning for threat detection
  • Integration Hub: Connect with other security tools
  • Notification System: Email, Slack, Discord integrations
  • Role-Based Access: Multi-user with permissions
  • Audit Logging: Comprehensive audit trail
  • Plugin System: Extensible architecture for custom features
The migration from bash script to web application represents a significant evolution in CrowdSec Manager. While the bash script served its purpose well, the new web application provides:
  • Better User Experience: Modern, intuitive interface
  • More Features: Real-time monitoring, advanced analysis, automation
  • Better Integration: API access for automation and tooling
  • Easier Maintenance: Web-based configuration and management
  • Future-Proof: Modern architecture ready for new features
Whether you’re a long-time user of the bash script or new to CrowdSec Manager, the web application provides a superior experience for managing your CrowdSec security stack.
Getting Started
Ready to make the switch? Check out the README.md for installation instructions and the USAGE.md for detailed usage guide.
Important: This is currently BETA software. Always test on a non-production environment first!
Support
Built with :heart: for the CrowdSec community
Will update more features to this script later this month. It’s an evolved version of the trouble shooting script.
When I run this directly after a sudo docker compose up -d command on my Pangolin VPS, I get a notice saying that traefik container is NOT running…
user@vps:~# sudo docker compose up -d
[+] Running 5/5
:check_mark: Network pangolin Created
:check_mark: Container crowdsec Started
:check_mark: Container pangolin Healthy
:check_mark: Container gerbil Started
:check_mark: Container traefik Started
user@vps:~# sudo ./crowdsec-manager.sh
CHECKING PREREQUISITES
[+] Docker is running
[+] crowdsec container is running
[-] traefik container is NOT running
[*] Temporary files cleaned up.
I am working on a fix. Please wait
error resolved please try and let me know.
Working now, thank you for all you do!
Polished few bugs today also.
I’m being banned 100% of the time:
crowdsec  | time="2025-03-08T00:05:57Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:57 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 1.796826ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
crowdsec  | time="2025-03-08T00:05:57Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:57 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 2.029658ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
crowdsec  | time="2025-03-08T00:05:58Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:58 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 2.578648ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
crowdsec  | time="2025-03-08T00:05:58Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:58 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 2.18327ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
crowdsec  | time="2025-03-08T00:05:58Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:58 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 3.558341ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
crowdsec  | time="2025-03-08T00:05:58Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:58 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 1.545924ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
crowdsec  | time="2025-03-08T00:05:58Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:58 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 4.6205ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
crowdsec  | time="2025-03-08T00:05:59Z" level=info msg="172.18.0.6 - [Sat, 08 Mar 2025 00:05:59 UTC] \"GET /v1/decisions?ip=<my-ip>&banned=true HTTP/1.1 403 1.282028ms \"Crowdsec-Bouncer-Traefik-Plugin/1.X.X\" \""
I’ve made sure that I’m whitelisted:
[+] IP <my-ip> is NOT currently blocked by CrowdSec.
[+] IP <my-ip> is whitelisted in Traefik configuration (likely part of a subnet).
Thoughts?
I recently followed your iptables advice (in another thread)… that shouldn’t have any impact here since I’m seeing it logged in Crowdsec, but figured I’d point it out anyhow…
Your bounce is not registered or keys don’t match.
docker exec crowdsec cscli bouncers list
docker exec crowdsec cscli bouncers delete traefik-bouncer
docker exec crowdsec cscli bouncers add traefik-bouncer
It does say “valid” and I had already tried deleting and re-adding the bouncer. Tried again now and no dice.
Could it be an iptables issue with fail2ban or geoblocking?
I mostly followed your guide here: Discord < could this be an issue at all?
INPUT DROP [4571:309566]
-A INPUT -i lo -j ACCEPT
-A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A INPUT -m conntrack --ctstate INVALID -j DROP
-A INPUT -p tcp -m tcp --dport 80 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 443 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 42522 -j ACCEPT
-A INPUT -p udp -m udp --dport 51820 -j ACCEPT # Wireguard
-A INPUT -p udp -m udp --dport 17072 -j ACCEPT # Wireguard
-A INPUT -p tcp -m tcp --dport 8080 -j ACCEPT # Crowdsec
-A INPUT -p tcp -m tcp --dport 6060 -j ACCEPT # Crowdsec metrics
-A INPUT -p tcp -m tcp --dport 7422 -j ACCEPT # Crowdsec AppSec endpoint
-A INPUT -i docker0 -j ACCEPT
-A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -m conntrack --ctstate INVALID -j DROP
-A FORWARD -i docker0 -o docker0 -j ACCEPT
-A FORWARD -i docker0 -o eth0 -j ACCEPT
-A FORWARD -i eth0 -o docker0 -j ACCEPT
-A OUTPUT -m conntrack --ctstate INVALID -j DROP
Fail2ban for sure. Please remove it.
"If you encounter issues adding IP addresses to your CrowdSec whitelist through the usual methods (e.g., using a management interface), you can manually edit the whitelist configuration file and restart CrowdSec. Here’s an example configuration:
description: "Whitelist events from my IPv4 addresses"
whitelist:
  reason: "My IPv4 ranges"
  ip:
    - "51.20.140.83"  # Added by IP Shield
    - "10.0.0.88"  # Added by IP Shield
    - "127.0.0.1"
  cidr:
    - "65.36.22.25/32"  # Added by IP Shield
    - "192.168.0.0/16"
    - "10.0.0.0/8"
    - "172.16.0.0/12"
  expression:
    - evt.Parsed.source_ip == '127.0.0.1'
    - evt.Parsed.source_ip contains '172.17.'
Remember to restart the CrowdSec service after making changes to the configuration file for them to take effect."
docker compose restart crowdsec
Crowdsec is running, yet the script does not detect it. What could I do to have the container recognized?
[opc@debian ~]$ docker compose up -d --remove-orphans
[+] Running 5/5
 ✔ Container backrest  Running        0.0s
 ✔ Container crowdsec  Running        0.0s
 ✔ Container pangolin  Healthy        1.0s
 ✔ Container gerbil    Running        0.0s
 ✔ Container traefik   Running        0.0s
[-] CrowdSec container does not exist. Please ensure it's created.
[!] You may need to run your docker-compose first.
sudo apt install grep gawk sed tar
Run the above command and try.
Which is your OS Version?
Thanks for the quick answer - it’s still the same. But this is my mistake, I’m on Oracle Linux and I read too quickly and missed the Debian & derivatives prerequisite… :slight_smile:
I don’t have oracle linux. so didn’t test on it. No issues.
Use the bot instead
Pangolin Discord bot to Manage the stack
If you just need crowdsec management then use hhftechnology/pangolin-discord-bot:crowdsec
I have the same issue running on Debian 12.
Not detecting crowdsec. apt install grep gawk sed tar has been run
share your docker ps and did you run sudo apt update && sudo apt upgrade -y ?
sudo apt update && sudo apt upgrade -y has been performed
6f2c4b4d3f47   traefik:latest                    "/entrypoint.sh --co…"   About a minute ago   Up About a minute        traefik
8f49d4f5074c   fosrl/gerbil:latest               "/entrypoint.sh --re…"   About a minute ago   Up About a minute             0.0.0.0:80->80/tcp, [::]:80->80/tcp, 0.0.0.0:443->443/tcp, [::]:443->443/tcp, 0.0.0.0:51820->51820/udp, [::]:51820->51820/udp   gerbil
bef78c75814b   fosrl/pangolin:latest             "docker-entrypoint.s…"   About a minute ago   Up About a minute (healthy)        pangolin
5a06ba1d80c2   crowdsecurity/crowdsec:latest     "/bin/bash /docker_s…"   About a minute ago   Up About a minute (healthy)   0.0.0.0:6060->6060/tcp, [::]:6060->6060/tcp        crowdsec
b5ebb601e9ec   portainer/portainer-ce:latest     "/portainer"             33 hours ago         Up 2 hours                    8000/tcp, 9000/tcp, 0.0.0.0:9443->9443/tcp, [::]:9443->9443/tcp        portainer
b79bdc4f4d1c   portainer/agent:latest            "./agent"                33 hours ago         Up 2 hours                    0.0.0.0:9001->9001/tcp, [::]:9001->9001/tcp        portainer_agent
1c75e4361c66   henrygd/beszel-agent              "/agent"                 4 days ago           Up 2 hours        beszel-agent
72e965180b63   louislam/dockge:1                 "/usr/bin/dumb-init …"   2 weeks ago          Up 2 hours (healthy)          0.0.0.0:5001->5001/tcp, [::]:5001->5001/tcp        dockge
234265b03979   rustdesk/rustdesk-server:latest   "hbbs -r rust.manilx…"   2 weeks ago          Up 2 hours                    0.0.0.0:21115-21116->21115-21116/tcp, [::]:21115-21116->21115-21116/tcp, 0.0.0.0:21116->21116/udp, [::]:21116->21116/udp        hbbs
dc7b605b61d8   rustdesk/rustdesk-server:latest   "hbbr -k a37AQsWJwuL…"   2 weeks ago          Up 2 hours                    0.0.0.0:21117->21117/tcp, [::]:21117->21117/tcp        hbbr
0bf348f470e6   containrrr/watchtower             "/watchtower"            4 weeks ago          Up 2 hours (healthy)          8080/tcp        watchtower
└─# ./setup_crowdsec_manager.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  128k  100  128k    0     0   377k      0 --:--:-- --:--:-- --:--:--  376k
100  4066  100  4066    0     0  12722      0 --:--:-- --:--:-- --:--:-- 12746
100  1860  100  1860    0     0   6627      0 --:--:-- --:--:-- --:--:--  6642
100  2842  100  2842    0     0   9956      0 --:--:-- --:--:-- --:--:--  9937
100 11989  100 11989    0     0  45960      0 --:--:-- --:--:-- --:--:-- 46111
100  3526  100  3526    0     0  14055      0 --:--:-- --:--:-- --:--:-- 14104
100 15554  100 15554    0     0  59171      0 --:--:-- --:--:-- --:--:-- 59140
100  8864  100  8864    0     0   9170      0 --:--:-- --:--:-- --:--:--  9175
100  2315  100  2315    0     0   1930      0  0:00:01  0:00:01 --:--:--  1932
