Setup Overview:
- Platform: Discourse (Bitnami installation)
- Bucket: Cloudflare R2
- Custom Domain: Set up for serving files publicly
- Configuration: Done entirely through Discourse site settings (no environment variables were touched)
Step-by-Step Guide:
- Create a Cloudflare R2 Bucket:
- Log in to your Cloudflare account and navigate to R2 storage.
- Create a new bucket for your Discourse uploads (e.g.,
forum-uploads). - Note down the Bucket S3 API URL, Access Key ID, and Secret Access Key.
- Set Up Custom Domain for CDN:
- To serve your R2 bucket content publicly, create a custom domain in Cloudflare.
- For example, I used
forumfiles.example.in. - Make sure to configure DNS settings to point to Cloudflare’s provided CNAME. Since I have a domain on cloudflare, it did it for me.
- Configure Discourse Site Settings:
s3_bucket: Your R2 bucket name (e.g.,
forum-uploads). -
s3_region: Set as US East (N. Virginia). There was no option of auto.
s3_endpoint: Use your Bucket S3 API URL provided by Cloudflare (e.g.,
https://<your-bucket-unique-id>.r2.cloudflarestorage.com). -
s3_access_key_id: Your R2 Access Key ID.
s3_secret_access_key: Your R2 Secret Access Key.
s3_cdn_url: Your custom domain for CDN (e.g.,
https://forumfiles.example.in). -
Ensure that enable s3 backups and enable s3 uploads are checked.
- Adjust Permissions and CORS:
- Set your R2 bucket to private and configure a CORS policy:
"AllowedHeaders": ["*"],
"AllowedMethods": ["GET", "POST", "PUT", "HEAD"],
"AllowedOrigins": ["*"],
"ExposeHeaders": ["ETag"],
"MaxAgeSeconds": 3000
- This ensures that the uploads work correctly without CORS issues.
- Testing the Setup:
- Upload a test file or image through your Discourse forum to verify that uploads are working correctly.
- Check if the files are accessible via your custom domain (e.g.,
https://forumfiles.example.in/original/1X/...). - Check the backups, I could successfully get backups executed. Cross checked at R2 bucket and its also listed in the site settings.
Conclusion:
By following these steps, I was able to integrate Cloudflare R2 with Discourse seamlessly, handling both uploads and backups efficiently. If you have any questions or run into issues, feel free to ask!
