- Introduction
- Prerequisites
- Initial System Bootstrap
- Storage Configuration
- Base System Installation
- Post-Installation Configuration
- Advanced Configuration with Flakes
Introduction
This technical guide provides detailed instructions for installing NixOS on Oracle Cloud Infrastructure (OCI) virtual machines. Since NixOS isn’t officially supported on OCI, we’ll use the kexec method to bootstrap the installation process.
- Access to an Oracle Cloud Infrastructure account
- A running VM instance (x86_64 or aarch64 architecture)
- Administrative (root) access to the VM
- Basic understanding of Linux system administration
- Familiarity with disk partitioning and SSH
Step 1: Bootstrapping the NixOS Installer
Choose the appropriate architecture and execute the following commands:
# Gain root privileges
sudo -i
# For x86_64 systems
curl -L https://github.com/nix-community/nixos-images/releases/download/nixos-unstable/nixos-kexec-installer-noninteractive-x86_64-linux.tar.gz | tar -xzf- -C /root
# For aarch64 systems
curl -L https://github.com/nix-community/nixos-images/releases/download/nixos-unstable/nixos-kexec-installer-noninteractive-aarch64-linux.tar.gz | tar -xzf- -C /root
# Execute the installer
/root/kexec/run
Note: Your SSH connection will be terminated during this process. Wait approximately 30 seconds before reconnecting.
Step 1: Disk Partitioning
The following partition scheme is recommended for optimal performance:
- 512MB EFI System Partition (ESP)
- Root partition (adjustable size)
- Swap partition (typically 1GB or matched to RAM)
fdisk /dev/sda
Detailed partitioning commands:
# Create new GPT partition table
g
# Create EFI System Partition (ESP)
n
<Enter>
+512M
# Create root partition
n
2
<Enter>
-1G
# Create swap partition
n
3
<Enter>
<Enter>
# Mark ESP partition
t
uefi
# Verify partition layout
p
# Write changes
w
Step 2: Filesystem Creation
# Format ESP
mkfs.fat -F 32 -n boot /dev/sda1
# Format root partition
mkfs.ext4 -L nixos /dev/sda2
# Initialize swap
mkswap -L swap /dev/sda3
Step 3: Mount Filesystems
# Mount root filesystem
mkdir -p /mnt
mount /dev/disk/by-label/nixos /mnt
# Mount ESP
mkdir -p /mnt/boot
mount /dev/disk/by-label/boot /mnt/boot
# Activate swap
swapon /dev/sda3
Step 1: Channel Configuration
nix-channel --add https://nixos.org/channels/nixos-unstable nixpkgs
nix-channel --update
Step 2: System Configuration
Generate initial configuration:
nixos-generate-config --root /mnt
Create /etc/nixos/configuration.nix:
{ config, lib, pkgs, ... }: {
imports = [ ./hardware-configuration.nix ];
# Bootloader configuration
boot.loader.systemd-boot.enable = true;
boot.loader.efi.canTouchEfiVariables = true;
# Network configuration
networking = {
hostName = "nixos-oci";
networkmanager.enable = true;
# System time configuration
time.timeZone = "America/New_York";
# User management
users.users.admin = {
isNormalUser = true;
extraGroups = [ "wheel" ];
# Essential packages
environment.systemPackages = with pkgs; [
curl
git
vim
# SSH configuration
services.openssh = {
enable = true;
settings = {
PermitRootLogin = "prohibit-password";
PasswordAuthentication = false;
users.users.root.openssh.authorizedKeys.keys = [
"YOUR_SSH_PUBLIC_KEY"
system.stateVersion = "23.11";
Step 3: Installation
# Install the system
nixos-install
# Set user password
nixos-enter --root "/mnt"
passwd admin
# Reboot into the new system
reboot
SSH Key Configuration
# Generate SSH key
ssh-keygen -t ed25519 -C "user@example.com"
# Display public keys
cat ~/.ssh/id_ed25519.pub
cat /etc/ssh/ssh_host_ed25519_key.pub
# Add GitHub to known hosts
ssh git@github.com
Step 1: Clone Configuration Repository
git clone https://github.com/your-username/nixfiles
cd nixfiles
Step 2: Apply Configuration
nixos-rebuild switch --flake ".#hostname"
Common issues and their solutions:
- Boot failures: Verify ESP mounting and bootloader configuration
- Network connectivity: Check NetworkManager status and configuration
- SSH access issues: Verify authorized_keys permissions and content
Security Considerations
- Always use SSH key authentication
- Regularly update system packages
- Configure firewall rules appropriately
- Follow the principle of least privilege for user permissions
Performance Optimization
- Adjust swap size based on workload
- Configure appropriate filesystem options
- Optimize network settings for cloud environment
Note: This guide is maintained as a reference. Always refer to the official NixOS documentation for the most up-to-date information.
