Comprehensive Guide: Compiling lua-nginx-module with NGINX 1.26.2
CRITICAL ENVIRONMENT NOTICE
Execution Environment Requirements
WARNING: This operation must be executed exclusively in a non-production environment.
Risk Assessment:
- Data loss or corruption may be irreversible if executed in production
- System state recovery may not be possible
- No rollback mechanisms are guaranteed
Required Environment:
- Development instance
- Staging environment
- Secondary/backup system
- Test environment with equivalent configuration
Prerequisites:
- Full system backup
- Verified restore capabilities
- Isolated network segment
- Non-production datasets
DO NOT PROCEED with execution in any production environment under any circumstances.
This guide provides step-by-step instructions for compiling and installing lua-nginx-module with NGINX 1.26.2 on a Debian/Ubuntu system.
First, switch to root user and install the required dependencies:
sudo su
# Install ModSecurity dependencies
apt install libmodsecurity3 libmodsecurity-dev
# Install PCRE dependencies
apt-get install libpcre3 libpcre3-dev
# Install additional required dependencies
apt-get install libpcre3 libpcre3-dev zlib1g zlib1g-dev libssl-dev
SSH Configuration (Optional)
If you need to modify SSH settings:
nano /etc/ssh/sshd_config
service ssh restart
passwd # Set root password if needed
Download and Extract Required Components
Navigate to your desired directory (e.g., /root) and download/extract the necessary components:
# Download and extract NGINX
wget https://nginx.org/download/nginx-1.26.2.tar.gz
tar -xzvf nginx-1.26.2.tar.gz
# Clone LuaJIT repository
git clone https://luajit.org/git/luajit.git
# Download and extract NGX Devel Kit
wget https://github.com/vision5/ngx_devel_kit/archive/refs/tags/v0.3.3.tar.gz
tar -xzf v0.3.3.tar.gz
# Clone Lua Resty components
git clone https://github.com/openresty/lua-resty-core.git
git clone https://github.com/openresty/lua-resty-lrucache.git
# Download and extract lua-nginx-module
wget https://github.com/openresty/lua-nginx-module/archive/refs/tags/v0.10.27.tar.gz
tar -xzf v0.10.27.tar.gz
Compile and Install LuaJIT
cd /root/luajit/
make && sudo make install
Configure and Install NGINX with Lua Module
cd /root/nginx-1.26.2
# Set LuaJIT environment variables
export LUAJIT_LIB=/usr/local/lib
export LUAJIT_INC=/usr/local/include/luajit-2.1
# Configure NGINX with required modules and paths
./configure \
--with-ld-opt="-Wl,-rpath,/usr/local/include/luajit-2.1" \
--prefix=/usr/share/nginx \
--conf-path=/etc/nginx/nginx.conf \
--http-log-path=/var/log/nginx/access.log \
--error-log-path=/var/log/nginx/error.log \
--lock-path=/var/lock/nginx.lock \
--pid-path=/run/nginx.pid \
--modules-path=/usr/lib/nginx/modules \
--http-client-body-temp-path=/var/lib/nginx/body \
--http-fastcgi-temp-path=/var/lib/nginx/fastcgi \
--http-proxy-temp-path=/var/lib/nginx/proxy \
--http-scgi-temp-path=/var/lib/nginx/scgi \
--http-uwsgi-temp-path=/var/lib/nginx/uwsgi \
--with-pcre-jit \
--with-compat \
--with-ld-opt='-lpcre' \
--add-dynamic-module=/root/ngx_devel_kit-0.3.3 \
--add-dynamic-module=/root/lua-nginx-module-0.10.27
# Install NGINX
make install
Install Lua Resty Components
# Install lua-resty-core
cd /root/lua-resty-core
make install PREFIX=/etc/nginx
# Install lua-resty-lrucache
cd /root/lua-resty-lrucache
Configure NGINX Modules
Create module configuration files:
# Create NDK module configuration
echo "load_module modules/ndk_http_module.so;" > /usr/share/nginx/modules-available/mod-ndk-http-module.conf
# Create Lua module configuration
echo "load_module modules/ngx_http_lua_module.so;" > /usr/share/nginx/modules-available/mod-ngx-lua-module.conf
Create symbolic links in modules-enabled directory:
cd /etc/nginx/modules-enabled
ln -s /usr/share/nginx/modules-available/mod-ndk-http-module.conf 50-mod-ndk-http-module.conf
ln -s /usr/share/nginx/modules-available/mod-ngx-lua-module.conf 50-mod-ngx-lua-module.conf
Configure NGINX
Add the following line to your nginx.conf file to set the Lua package path:
lua_package_path "/etc/nginx/lib/lua/?.lua;;";
Post-Installation Verification
- Verify NGINX configuration:
nginx -t
- Check if Lua module is loaded:
nginx -V 2>&1 | grep lua
- Restart NGINX:
systemctl restart nginx
Common Issues and Troubleshooting
If you encounter “module not found” errors, verify that the symbolic links are correctly created in the modules-enabled directory.
If you see LuaJIT-related errors, ensure that the environment variables (LUAJIT_LIB and LUAJIT_INC) are correctly set.
For permission issues, ensure that the nginx user has appropriate access to the Lua modules directory.
Directory Structure
After installation, verify these important directories:
- NGINX configuration:
/etc/nginx/ - NGINX modules:
/usr/lib/nginx/modules/ - Lua modules:
/etc/nginx/lib/lua/
Security Considerations
- Ensure proper file permissions on Lua scripts and modules
- Regularly update all components to their latest stable versions
- Implement appropriate access controls for Lua scripts
- Monitor error logs for any security-related issues
Remember to always back up your configuration files before making any changes and test in a staging environment first.
