Complete Guide: Setting Up Minecraft Server with Pangolin
This guide will walk you through setting up a self-hosted Minecraft server using Crafty Controller and exposing it securely to the internet using Pangolin tunneling solution.
  1. Prerequisites
  2. Part 1: Server Preparation
  3. Part 2: Crafty Controller Setup
  4. Part 3: Creating the Minecraft Server
  5. Part 4: Pangolin Installation
  6. Part 5: Newt Tunnel Configuration
  7. Part 6: Exposing Services via Pangolin
  8. Part 7: Testing and Connection
  9. Part 8: Advanced Configuration (Optional)
  10. Troubleshooting
Before starting, ensure you have:
  • Server/VPS: A Linux server or virtual machine (Ubuntu/Debian recommended)
  • Docker and Docker Compose: Installed on your server
  • Domain Name: A registered domain pointed to your server (e.g., from Namecheap, Cloudflare, etc.)
  • Open Ports: The following ports must be open on your server and firewall:
    • TCP: 80, 443 (for web traffic)
    • UDP: 51820, 21820 (for Pangolin tunneling)
    • TCP: 25565 (for Minecraft)
  • Pangolin Account: Sign up at pangolin.io
  • Minecraft Java Edition: For testing the server
Step 1: Connect to Your Server
ssh user@your-server-ip
Step 2: Install Docker (if not already installed)
# Update package list
sudo apt update
# Install Docker
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
# Add your user to docker group
sudo usermod -aG docker $USER
# Log out and back in for group changes to take effect
exit
Step 3: Install Docker Compose
# Download Docker Compose
sudo curl -L "https://github.com/docker/compose/releases/latest/download/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
# Make it executable
sudo chmod +x /usr/local/bin/docker-compose
# Verify installation
docker-compose --version
Step 4: Create Project Directory
mkdir minecraft-pangolin
cd minecraft-pangolin
Step 1: Create Docker Compose File for Crafty
nano docker-compose.yml
Step 2: Add Crafty Configuration
Copy and paste this configuration:
  crafty_container:
    container_name: crafty_container
    image: registry.gitlab.com/crafty-controller/crafty-4:latest
      - TZ=Etc/UTC
      - "8443:8443"  # HTTPS Web UI
      - "8123:8123"  # HTTP Web UI
      - "19132:19132/udp"  # Bedrock
      - "25565-25600:25565-25600"  # Java
      - "8000:8000"  # Dynmap plugin
      - ./docker/backups:/crafty/backups
      - ./docker/logs:/crafty/logs
      - ./docker/servers:/crafty/servers
      - ./docker/config:/crafty/app/config
      - ./docker/import:/crafty/import
Step 3: Create Required Directories
mkdir -p docker/{backups,logs,servers,config,import}
Step 4: Start Crafty Container
docker compose up -d
Step 5: Get Default Credentials
# Wait a moment for the container to initialize
sleep 10
# Find the default credentials
cat docker/config/default-creds.txt
Save these credentials - you’ll need them to log in!
Step 6: Access Crafty Web UI
Open your browser and navigate to:
https://your-server-ip:8443
Note: You’ll see a security warning because of the self-signed certificate. It’s safe to proceed.
Step 7: Log In to Crafty
Use the credentials from Step 5 to log in.
Step 1: Navigate to Servers
In the Crafty dashboard, click on “Servers” in the left menu.
Step 2: Create New Server
Click “Create New Server” button.
Step 3: Configure Server Settings
  • Server Type: Minecraft Java
  • Server Version: Select latest stable (e.g., 1.20.4)
  • Server Name: MC Demo (or your preferred name)
  • Memory:
    • Minimum: 2000 MB
    • Maximum: 4000 MB (adjust based on your server’s RAM)
  • Server Port: 25565 (default)
Click “Build Server”
Step 4: Start the Server
  1. Click on your newly created server
  2. Click the “Start” button
  3. Accept the Minecraft EULA when prompted
  4. Click OK on the port forwarding notification
  5. Wait for the server to fully initialize (watch the console for “Done” message)
Step 1: Install Pangolin Base
Create a new terminal session and run:
cd ~
mkdir pangolin
cd pangolin
# Download and run the Pangolin installer
curl -fsSL https://get.pangolin.io | bash
Step 2: Configure Pangolin Installation
Follow the installer prompts:
  1. Choose Docker as the container type
  2. Enter your base domain (e.g., example.com)
  3. Enter dashboard subdomain (e.g., pangolin.example.com)
  4. Enter email for Let’s Encrypt certificates
  5. Configure email settings (optional, can skip)
  6. Choose to install Gerbil (recommended: yes)
Step 3: Verify Pangolin Installation
docker ps
You should see containers for:
  • pangolin
  • gerbil
  • traefik
Step 1: Access Pangolin Dashboard
Navigate to your Pangolin dashboard:
https://pangolin.your-domain.com
Step 2: Create Organization
If first time:
  1. Click “Create Organization”
  2. Enter organization name (e.g., “Lab”)
  3. Click “Create”
Step 3: Create Site
  1. Go to “Sites” tab
  2. Click “Add Site”
  3. Enter site name (e.g., “Minecraft-Server”)
  4. Click “Create Site”
  5. Copy the generated newt command
Step 4: Add Newt to Docker Compose
Go back to your minecraft-pangolin directory:
cd ~/minecraft-pangolin
Add the newt service to your existing docker-compose.yml:
  newt:
    image: ghcr.io/fosrl/newt:latest
    container_name: newt
    command: [
      "tunnel",
      "--remote", "https://pangolin.your-domain.com",
      "--token", "YOUR_TOKEN_HERE",
      "--site-id", "YOUR_SITE_ID_HERE"
      - default
Important: Replace YOUR_TOKEN_HERE and YOUR_SITE_ID_HERE with values from the copied newt command.
Step 5: Connect to Pangolin Network
Add this to the bottom of your docker-compose.yml:
  default:
    external:
Step 6: Restart Services
docker compose down
Step 7: Verify Newt Connection
docker logs newt
You should see “Successfully connected to Pangolin endpoint” message.
Step 1: Expose Crafty Web UI
In the Pangolin dashboard:
  1. Go to “Resources” tab
  2. Click “Add Resource”
  3. Configure HTTP resource:
    • Name: crafty
    • Type: HTTP Resource (toggle ON)
    • Subdomain: crafty
    • Site: Select your site (e.g., “Minecraft-Server”)
  4. Click “Create Resource”
Step 2: Configure Crafty Target
  1. In the resource settings page
  2. Under “Target Configuration”, add target:
    • Method: https
    • IP/Hostname: crafty_container
    • Port: 8443
  3. Click “Save Targets”
Your Crafty UI is now accessible at: https://crafty.your-org.pangolin.io
Step 3: Expose Minecraft Server Port
  1. Click “Add Resource” again
  2. Configure TCP resource:
    • Name: Minecraft
    • Type: HTTP Resource (toggle OFF)
    • Protocol: TCP
    • Port Number: 25565
  3. Click “Create Resource”
Step 4: Update Firewall Rules
For AWS EC2:
  1. Go to EC2 Dashboard → Security Groups
  2. Select your instance’s security group
  3. Add inbound rule:
    • Type: Custom TCP
    • Port: 25565
    • Source: 0.0.0.0/0
For other providers:
# Using ufw (Ubuntu/Debian)
sudo ufw allow 25565/tcp
sudo ufw reload
# Using firewalld (CentOS/RHEL)
sudo firewall-cmd --permanent --add-port=25565/tcp
sudo firewall-cmd --reload
Step 5: Configure Traefik Entrypoints
Edit the Traefik configuration to add the Minecraft port:
cd ~/pangolin
nano config/traefik/traefik_config.yml
Add the TCP entrypoint for Minecraft (add this to the existing entryPoints section):
entryPoints:
  http:
    address: ":80"
    # ... existing config
  https:
    address: ":443"
  minecraft:  # Add this new entrypoint
    address: ":25565/tcp"
Step 6: Configure Port Mapping
Edit the main Pangolin docker-compose file:
Add port mapping to the gerbil service:
  gerbil:
      - 51820:51820/udp
      - 21820:21820/udp
      - 443:443
      - 80:80
      - 25565:25565  # Add this line
Step 7: Restart Pangolin Stack
docker compose down
Step 8: Configure Minecraft Target in Pangolin
Back in Pangolin dashboard, in your Minecraft resource settings:
  1. Under “Target Configuration”, add target:
    • Port: 25565
  2. Click “Save Targets”
Important Note: If the TCP resource creation shows you need to add entrypoints, make sure you’ve completed Step 5 (Traefik entrypoints configuration) and restarted the stack.
Step 1: Get Your Server Address
Your Minecraft server address will be:
your-org.pangolin.io:25565
Step 2: Test with Minecraft Client
  1. Open Minecraft Java Edition
  2. Click “Multiplayer”
  3. Click “Add Server”
  4. Enter server details:
  5. Click “Done”
Step 3: Connect to Server
  1. Select your server from the list
  2. Click “Join Server”
  3. You should successfully connect!
Step 4: Verify in Crafty
Check the Crafty console - you should see your player joining the server.
Complete Traefik Configuration Example
Here’s what a complete traefik_config.yml should look like with all entrypoints:
# config/traefik/traefik_config.yml
api:
  dashboard: true
entryPoints:
  http:
    address: ":80"
    http:
      redirections:
        entryPoint:
          to: https
          scheme: https
          permanent: true
  https:
    address: ":443"
    http:
      tls:
        certResolver: letsencrypt
  # Minecraft Java server ports
  minecraft:
  # Additional server ports (if needed)
  minecraft2:
    address: ":25566/tcp"
  # Bedrock edition (if needed)
  bedrock:
    address: ":19132/udp"
  # Voice chat plugin (if needed)
  voicechat:
    address: ":24454/udp"
providers:
  docker:
    endpoint: "unix:///var/run/docker.sock"
    exposedByDefault: false
  file:
    directory: "/etc/traefik/dynamic"
    watch: true
  http:
    pollInterval: "5s"
certificatesResolvers:
  letsencrypt:
    acme:
      email: your-email@example.com
      storage: /letsencrypt/acme.json
      httpChallenge:
        entryPoint: http
Proxy Protocol Configuration
Note: Proxy Protocol is only supported by Minecraft Java Edition and requires additional configuration. Most users won’t need this unless they’re running multiple servers or need to preserve client IP addresses.
If you need to enable Proxy Protocol:
  1. Edit Traefik configuration:
cd ~/pangolin
nano config/traefik/dynamic_config.yml
  1. Add TCP service with Proxy Protocol:
tcp:
  routers:
    minecraft:
      rule: "HostSNI(`*`)"
      entryPoints:
        - "minecraft"
      service: "minecraft-service"
    minecraft-service:
      loadBalancer:
        servers:
          - address: "crafty_container:25565"
        proxyProtocol:
          version: 1
  1. Enable Proxy Protocol in your Minecraft server:
    • For Velocity proxy: Set proxy-protocol = true in velocity.toml
    • For BungeeCord: Add proxy_protocol: true to config.yml
    • For Paper/Spigot: Requires additional plugins
Multiple Server Ports
To expose additional Minecraft servers:
  1. Add entrypoints in Traefik configuration:
entryPoints:
  minecraft:
  minecraft2:
  minecraft3:
    address: ":25567/tcp"
  # Add more as needed
  1. Add ports to the gerbil service in docker-compose.yml:
gerbil:
    - 25565:25565
    - 25566:25566
    - 25567:25567
  1. In Crafty, create servers on different ports (25566, 25567, etc.)
  2. Create separate TCP resources in Pangolin for each port
  3. Configure targets for each resource
Voice Chat Support
For plugins like Simple Voice Chat:
  1. Add UDP port mapping to gerbil service in docker-compose.yml:
gerbil:
    - 24454:24454/udp
  1. Add UDP entrypoint in Traefik configuration:
entryPoints:
  udp-24454:
  1. In Pangolin config, enable raw resources:
# config/config.yml
flags:
  allow_raw_resources: true
  1. Restart the stack for changes to take effect:
docker compose down
Container Won’t Start
# Check logs
docker logs crafty_container
docker logs newt
# Verify network exists
docker network ls | grep pangolin
Can’t Connect to Minecraft Server
  1. Verify port is open:
netstat -tuln | grep 25565
  1. Check Docker port mapping:
docker port crafty_container
  1. Test connection locally:
telnet localhost 25565
SSL Certificate Issues
# Check Traefik logs
docker logs traefik
# Verify DNS records
nslookup your-domain.com
Player IP Shows as Proxy
This is expected behavior without Proxy Protocol. The server will see connections coming from the proxy IP. Only Minecraft Java Edition supports Proxy Protocol for preserving client IPs.
Performance Issues
  1. Increase Docker memory limits
  2. Optimize JVM flags in Crafty server settings
  3. Monitor resource usage:
docker stats
Security Recommendations
  1. Change Default Passwords: Always change Crafty’s default admin password
  2. Firewall Rules: Only open required ports
  3. Regular Updates: Keep Docker images updated
  4. Backups: Enable automatic backups in Crafty
  5. Resource Limits: Set appropriate memory/CPU limits in Docker
  6. Access Control: Use Pangolin’s authentication features for the web UI
You now have a fully functional Minecraft server accessible through Pangolin’s secure tunneling system! Your server is protected behind Pangolin’s proxy, and both the game server and management interface are accessible through your custom domain.
Remember that standard TCP mode will show all players connecting from the proxy IP address. This is normal and doesn’t affect gameplay. Proxy Protocol support requires additional configuration and is only available for Java Edition servers.
Is there an updated guide for self-hosted Pangolin?
i have to do an updated guide. few things have change. but i haven’t got time yet to post a new guide.
