GitHub discussion middleware-manager #60 in Q&A, started by
ahmaddxbon GitHub
Is there a way I can make these from the UI?
It can’t be added manually to resource-overrides.yml as it is overwritten.
nzb360-overides.yml
http:
routers:
4-router-auth-auth-bypass:
entryPoints:
- websecure
priority: 100
rule: "Host(`sonarr.{{env `DOMAINNAME0`}}`) && (Header(`X-Api-Key`, `{{env `SONARR_API_KEY`}}`) || Query(`apikey`, `{{env `SONARR_API_KEY`}}`))"
service: "4-service@http"
tls:
certResolver: "letsencrypt"
7-router-auth-auth-bypass:
entryPoints:
- websecure
priority: 100
rule: "Host(`radarr.{{env `DOMAINNAME0`}}`) && (Header(`X-Api-Key`, `{{env `RADARR_API_KEY`}}`) || Query(`apikey`, `{{env `RADARR_API_KEY`}}`))"
service: "7-service@http"
tls:
18-router-auth-auth-bypass:
entryPoints:
- websecure
priority: 100
rule: "Host(`nzbget.{{env `DOMAINNAME0`}}`) && (Header(`authorization`, `Basic {{env `NZBGET_API_KEY`}}`))"
service: "18-service@http"
tls:
19-router-auth-auth-bypass:
entryPoints:
- websecure
priority: 100
rule: "Host(`qbittorrent.{{env `DOMAINNAME0`}}`) && (PathPrefix(`/api/v2`))"
service: "19-service@http" …
💬 Join in here or [on GitHub](https://github.com/hhftechnology/middleware-manager/discussions/60).
<!-- hhf-forum-sync -->
