Build a Remote Exit Node with Tailscale and Fly.io: Setup Instructions
How to setup Tailscale exit note on fly.io
[fly.toml]
app = "fly-scale"
[env]
  PATH="/usr/local/bin"
  TS_EXTRA_ARGS="--hostname=fly --advertise-exit-node"
[build]
  image = "tailscale/tailscale:stable"
[deploy]
  strategy="immediate"
[mounts]
  source="ts_data"
  destination="/var"
Install and authenticate your flyctl
$ brew install flyctl
$ flyctl auth login
Create a fly.io app from the provided fly.toml file
$ flyctl launch --copy-config
Set the TS_AUTH_KEY env var for the current app.
$ flyctl secrets set TS_AUTH_KEY=tskey-xxxxx
Create a volume to persist tailscale db.
$ fly volumes create ts_data --region fra --size 1
Re-deploy, if you change some settings
$ flyctl deploy
