GitHub discussion traefik-log-dashboard #215 in General, started by
jimmylevellon GitHub
Within the settings panel, I do not see the “historical data” panel as mentioned in the documentation.
I am running the latest version v3.0.0 of the app.
The solution is deployed based on the provided docker compose sample:
traefik-dashboard:
image: hhftechnology/traefik-log-dashboard:latest
- /srv/docker/traefik-dashboard/dashboard:/app/data
- /srv/docker/traefik-dashboard/positions:/data
# Agent Configuration - REPLACE WITH YOUR TOKEN
- AGENT_API_URL=http://traefik-agent:5000
- AGENT_API_TOKEN=<secret key>
- AGENT_NAME=Default Agent
# Node Environment
- NODE_ENV=production
- PORT=3000
# Display Configuration
- NEXT_PUBLIC_SHOW_DEMO_PAGE=true
- NEXT_PUBLIC_MAX_LOGS_DISPLAY=500
Am I missing an env variable?
I appreciate your help!
Join in here or on GitHub.
