GitHub discussion middleware-manager #111 in Q&A, started by
svandiveon GitHub
Running Pangolin 1.19 (Requires Badger 1.4.1)
Middleware Manager version 4.5.0 installed.
Pangolin reports it’s using Badger 1.3.1, Middleware Manager reports Badger version 1.4.1 is installed, but not being used.
traefik_config.yml has the correct entry:
experimental:
plugins:
badger:
moduleName: github.com/fosrl/badger
version: v1.4.1
Any help or ideas on how to correct this that do not involve simply removing Middleware Manager and going back to a vanilla Pangolin install?
Thank you
Join in here or on GitHub.
