The Challenge
If you’ve ever hosted a website with a provider that doesn’t offer API access for DNS management, you’ve likely encountered challenges with automating SSL certificate generation - particularly for wildcard certificates. This is a common issue when you need to secure multiple subdomains but can’t automatically verify domain ownership through DNS challenges.
The Solution: Using a Secondary Domain
A clever workaround for this limitation is to leverage a secondary domain hosted with a provider that does support API access. Here’s how it works:
- Purchase a secondary domain from a provider with API support (like Hetzner)
- Set up DNS CNAME records to redirect the ACME challenge verification
- Use
acme.shto automate certificate generation
How It Works
When requesting a wildcard certificate for *.primary-domain.com, Let’s Encrypt requires verification through a TXT record at _acme-challenge.primary-domain.com. Instead of placing the TXT record directly there, we:
Create a CNAME record on the primary domain:
_acme-challenge.primary-domain.com IN CNAME _acme-challenge.secondary-domain.com -
Let the automation script place the TXT record on the secondary domain where we have API access
When Let’s Encrypt checks the challenge, it follows the CNAME and finds the verification record
Automated Implementation
Here’s a comprehensive script that automates the entire process:
#!/bin/bash
# Configuration
PRIMARY_DOMAIN="myblog.technology"
SECONDARY_DOMAIN="myblog-alternative.technology"
ADMIN_EMAIL="admin@myblog.technology"
CERT_DIR="/etc/ssl/private"
SERVICE_RESTART_CMD="systemctl restart nginx"
# Function to check if acme.sh is installed
check_acme_sh() {
if ! command -v acme.sh &> /dev/null; then
echo "acme.sh not found. Installing..."
curl https://get.acme.sh | sh
source ~/.bashrc
fi
# Function to validate environment
validate_environment() {
if [ -z "$HETZNER_TOKEN" ]; then
echo "Error: HETZNER_TOKEN environment variable not set"
echo "Please set it using: export HETZNER_TOKEN=your_token_here"
exit 1
fi
# Function to generate and deploy certificate
generate_certificate() {
local domain="*.$PRIMARY_DOMAIN"
local challenge_domain="$SECONDARY_DOMAIN"
echo "Generating certificate for $domain using $challenge_domain for verification..."
acme.sh --issue \
--server letsencrypt \
-d "$domain" \
--dns dns_hetzner \
--challenge-alias "$challenge_domain" \
-m "$ADMIN_EMAIL" \
--renew-hook "$0 deploy" || {
echo "Certificate generation failed"
exit 1
# Function to deploy certificate
deploy_certificate() {
local cert_path="$HOME/.acme.sh/*.$PRIMARY_DOMAIN"
echo "Deploying certificates to $CERT_DIR..."
# Create directory if it doesn't exist
mkdir -p "$CERT_DIR"
# Copy certificates
cp "$cert_path/fullchain.cer" "$CERT_DIR/fullchain.pem"
cp "$cert_path/*.tech-tales.blog.key" "$CERT_DIR/privkey.pem"
# Set permissions
chmod 644 "$CERT_DIR/fullchain.pem"
chmod 600 "$CERT_DIR/privkey.pem"
# Restart services
echo "Restarting services..."
$SERVICE_RESTART_CMD
# Main execution
main() {
case "$1" in
"generate")
check_acme_sh
"deploy")
deploy_certificate
echo "Usage: $0 {generate|deploy}"
echo " generate: Generate new certificate"
echo " deploy: Deploy existing certificate"
exit 1
esac
main "$@"
- A primary domain where you want to use the wildcard certificate
- A secondary domain with API access for DNS management (e.g., Hetzner)
acme.shinstalled on your system- Hetzner API token (for this example)
Setting Up
First, set up your Hetzner API token:
export HETZNER_TOKEN=your_token_here -
Add the CNAME record to your primary domain’s DNS:
_acme-challenge.tech-tales.blog IN CNAME _acme-challenge.tech-tales-alternative.blog -
Save the script above as
ssl-cert-manager.shand make it executable:chmod +x ssl-cert-manager.sh
To generate a new certificate:
./ssl-cert-manager.sh generate
The script will handle:
- Checking for acme.sh installation
- Validating the environment
- Generating the certificate using DNS challenge
- Deploying the certificate to the specified location
- Restarting necessary services
Automation Tips
Add the script to cron for automatic renewal:
0 0 1 * * /path/to/ssl-cert-manager.sh generate -
Store the Hetzner token in a secure environment file:
echo "export HETZNER_TOKEN=your_token_here" > ~/.ssl-cert-env chmod 600 ~/.ssl-cert-env -
Source the environment file in your cron job:
0 0 1 * * source ~/.ssl-cert-env && /path/to/ssl-cert-manager.sh generate
If you encounter issues:
- Check the Let’s Encrypt logs in ~/.acme.sh/acme.sh.log
- Verify DNS propagation using dig or nslookup
- Ensure the HETZNER_TOKEN has sufficient permissions
- Test with Let’s Encrypt staging environment first by modifying the --server parameter
Security Considerations
- Keep your API token secure and regularly rotate it
- Use restricted permissions for certificate files
- Monitor certificate expiration dates
- Maintain backup copies of certificates
Remember to replace the example domains, email addresses, and paths with your actual values before using the script.
This solution provides a robust way to automate wildcard certificate generation even when your primary domain host doesn’t provide API access for DNS management.
