Automating Development Environment Setup with Ansible
Ansible Playbook for Oh My Zsh:
- Write tasks to install Oh My Zsh.
- Create a template for the
.zshrcfile to configure themes and plugins. - Apply the template to both macOS and Linux systems.
Ruby Environment Setup:
- Write conditional Ansible tasks: ruby-install and chruby for macOS, rbenv for Linux.
- Automate the Ruby version installation and global version setting.
Node.js Version Manager:
- Choose a Node.js version manager and write tasks to install and configure it.
- Automate Node.js installations and version management.
Go Language Setup:
- Write tasks to install Go and configure the GOPATH.
- Ensure the Go binary path is added to the PATH environment variable.
Terraform Version Manager (tfenv):
- Write tasks to install tfenv.
- Automate the installation of desired Terraform versions.
SSH Configuration:
- Automate the SSH agent setup and ssh-add commands.
- Consider using Ansible Vault for managing private SSH keys securely.
Docker Installation:
- Write tasks to install Docker.
- Ensure Docker is properly configured on both macOS and Linux.
Unix Tools Installation:
- Identify and write tasks to install tools like
fzfand others you find useful.
Tailscale Setup:
- Write tasks to install and configure Tailscale.
AWS CLI Configuration:
- Write tasks to install the AWS CLI.
- Configure the AWS CLI, potentially using Ansible’s
aws_ssmmodule to manage secrets securely.
Fonts and Themes:
- Write tasks to download and install Nerd Fonts if required.
- Configure the “Shades of Purple” theme for your terminal and code editor.
Validation and Testing:
- After creating your playbooks, run them in test environments.
- Validate that all configurations are applied correctly and environments are set up as expected.
