Automate adding Traefik labels to containers on Unraid
[unraid-traefik-labels.sh]
#!/bin/bash
# Run the script as ./unraid-traefik-labels.sh main_clicks <APP_NAME> <APP_PORT>           #
#   Example: ./unraid-traefik-labels.sh main_clicks my-app 5554                            #
# To get coordinates for click options place your mouse on the desired location and use:   #
#   eval $(xdotool getmouselocation --shell)                                               #
#   echo $X        #
#   echo $Y        #
# Ensure the browser window is in focus
# Ensure that the name matches your tab
# If you are updating an existing container it should be
# UNRAID/UpdateContainer
xdotool search --name "UNRAID/AddContainer" windowactivate --sync
# Set delay for all subsequent xdotool commands
delay="--delay 35"
new() {
    xdotool key $delay Return
    sleep 0.5
    xdotool key $delay Down
    xdotool key $delay Tab
new_click() {
    sleep 0.5
    xdotool mousemove 2788 642 click 1
    sleep 0.5
    xdotool mousemove 2741 716 click 1
save() {
enable() {
    xdotool type $delay "Enable Traefik"
    xdotool type $delay "traefik.enable"
    xdotool type $delay "true"
rule() {
    xdotool type $delay "Traefik Rule"
    xdotool type $delay "traefik.http.routers.$1.rule"
    xdotool type $delay "Host(\`$1.$3\`)"
entrypoints() {
    xdotool type $delay "Traefik EntryPoints"
    xdotool type $delay "traefik.http.routers.$1.entryPoints"
    xdotool type $delay "web,websecure"
port() {
    xdotool type $delay "Traefik Port"
    xdotool type $delay "traefik.http.services.$1.loadbalancer.server.port"
    xdotool type $delay "$2"
tls() {
    xdotool type $delay "Traefik TLS"
    xdotool type $delay "traefik.http.routers.$1.tls"
middleware() {
    xdotool type $delay "Authentik Middleware"
    xdotool type $delay "traefik.http.routers.$1.middlewares"
    xdotool type $delay "authentik@file"
# Doesn't work because of bug
# https://forums.unraid.net/bug-reports/stable-releases/6126-docker-add-configuration-menu-breaks-when-selecting-config-type-with-keyboard-arrows-r2773/
main() {
    local container_name=$1
    local port_number=$2
    new
    enable
    save
    new
    rule "$container_name"
    save
    new
    entrypoints "$container_name"
    save
    new
    port "$container_name" "$port_number"
    save
    new
    tls "$container_name"
    save
main_clicks() {
    new_click
    enable
    save
    new_click
    save
    new_click
    save
    new_click
    save
    new_click
    save
