I’ve created a Bash script that:
- Analyzes Nginx logs across all user directories
- Tracks outbound traffic using netstat/ss
- Monitors user activities and authentication attempts
- Checks for recent file changes
To use the script:
- Save it to a file (e.g.,
server_analyzer.sh)
touch server_analyzer.sh
nano server_analyzer.sh
- Make it executable:
chmod +x server_analyzer.sh
- Run it as root or with sudo:
sudo ./server_analyzer.sh
The script will provide:
- Top IP addresses accessing your servers
- HTTP status code distribution
- Error requests (4xx and 5xx)
- Outbound connection statistics
- Recent user login activities
- Failed login attempts
- Recent file modifications
#!/bin/bash
set -euo pipefail
RED='\033[0;31m'
GREEN='\033[0;32m'
YELLOW='\033[1;33m'
BLUE='\033[0;34m'
NC='\033[0m'
# CloudPanel paths
CLP_PATH="/home/clp"
CLP_DB="${CLP_PATH}/htdocs/app/data/db.sq3"
COMMON_NGINX="/etc/nginx"
COMMON_PHP="/etc/php"
# Timestamp for reports
TIMESTAMP=$(date +%Y%m%d_%H%M%S)
OUTPUT_DIR="cloudpanel_analysis_${TIMESTAMP}"
mkdir -p "${OUTPUT_DIR}"
# Log function
log() {
echo -e "${2}[$(date '+%Y-%m-%d %H:%M:%S')] ${1}${NC}" | tee -a "${OUTPUT_DIR}/analysis.log"
# Function to analyze CloudPanel database
analyze_clp_database() {
log "Analyzing CloudPanel Database..." "${BLUE}"
# Create directory for database analysis
mkdir -p "${OUTPUT_DIR}/database"
# Method 1: Using PHP console command for user data
log "Fetching user data from Doctrine..." "${BLUE}"
sudo -u clp /usr/bin/php8.1 /home/clp/htdocs/app/files/bin/console doctrine:query:sql "SELECT * from user;" \
> "${OUTPUT_DIR}/database/user_data.txt" 2>/dev/null || \
log "Error fetching user data from Doctrine" "${RED}"
# Method 2: Using SQLite for event data
log "Fetching event data from SQLite..." "${BLUE}"
if [ -f "${CLP_DB}" ]; then
sqlite3 "${CLP_DB}" <<EOF > "${OUTPUT_DIR}/database/event_history.txt"
.mode column
.headers on
SELECT
event_name,
user_name,
datetime(created_at, 'unixepoch') as event_time
FROM event
ORDER BY event_time DESC;
EOF
log "Database analysis completed" "${GREEN}"
else
log "CloudPanel database not found at ${CLP_DB}" "${RED}"
fi
# Generate a combined analysis report
echo "CloudPanel Database Analysis Report"
echo "================================="
echo "Generated at: $(date)"
echo ""
echo "1. User Data (from Doctrine):"
echo "----------------------------"
cat "${OUTPUT_DIR}/database/user_data.txt"
echo ""
echo "2. Event History (from SQLite):"
echo "-----------------------------"
cat "${OUTPUT_DIR}/database/event_history.txt"
} > "${OUTPUT_DIR}/database/database_analysis_report.txt"
# Function to analyze bash configuration changes
analyze_bash_configs() {
log "Analyzing Bash configurations..." "${BLUE}"
# Compare with default Ubuntu configs
diff "/etc/skel/.bashrc" "${CLP_PATH}/.bashrc" > "${OUTPUT_DIR}/bashrc_changes.diff" 2>&1 || true
diff "/etc/skel/.bash_logout" "${CLP_PATH}/.bash_logout" > "${OUTPUT_DIR}/bash_logout_changes.diff" 2>&1 || true
# Get last modification times
stat "${CLP_PATH}/.bashrc" "${CLP_PATH}/.bash_logout" > "${OUTPUT_DIR}/bash_config_stats.txt"
# Function to analyze user site structure
analyze_user_sites() {
log "Analyzing user sites structure..." "${BLUE}"
# Find all user directories
for user_dir in /home/*/; do
# Skip clp directory
if [ "$user_dir" = "/home/clp/" ]; then
continue
fi
username=$(basename "$user_dir")
log "Analyzing user: ${username}" "${GREEN}"
# Create user report directory
user_report_dir="${OUTPUT_DIR}/users/${username}"
mkdir -p "${user_report_dir}"
# Analyze site structure
if [ -d "${user_dir}htdocs" ]; then
find "${user_dir}htdocs" -type d -maxdepth 2 > "${user_report_dir}/site_structure.txt"
# Check WordPress installations
find "${user_dir}htdocs" -name "wp-config.php" > "${user_report_dir}/wordpress_installations.txt"
fi
# Analyze logs
if [ -d "${user_dir}logs" ]; then
# Nginx logs analysis
if [ -d "${user_dir}logs/nginx" ]; then
log "Analyzing Nginx logs for ${username}..." "${BLUE}"
for nginx_log in "${user_dir}logs/nginx"/*access.log; do
if [ -f "$nginx_log" ]; then
# Extract unique IPs and their request counts
awk '{print $1}' "$nginx_log" | sort | uniq -c | sort -rn > "${user_report_dir}/nginx_ip_stats.txt"
# Get error requests (4xx and 5xx)
awk '$9 ~ /^[45]/' "$nginx_log" > "${user_report_dir}/nginx_errors.txt"
# Look for suspicious patterns (common attack vectors)
grep -i "wp-login.php\|wp-admin\|xmlrpc.php" "$nginx_log" > "${user_report_dir}/wordpress_access_attempts.txt"
fi
done
fi
# PHP logs analysis
if [ -d "${user_dir}logs/php" ]; then
log "Analyzing PHP logs for ${username}..." "${BLUE}"
for php_log in "${user_dir}logs/php"/*error.log; do
if [ -f "$php_log" ]; then
# Extract PHP errors and warnings
grep -i "error\|warning\|notice" "$php_log" > "${user_report_dir}/php_errors.txt"
fi
done
fi
# Varnish cache analysis
if [ -d "${user_dir}logs/varnish-cache" ]; then
log "Analyzing Varnish cache logs for ${username}..." "${BLUE}"
ls -lah "${user_dir}logs/varnish-cache" > "${user_report_dir}/varnish_cache_stats.txt"
fi
fi
# Analyze backups
if [ -d "${user_dir}backups" ]; then
ls -lah "${user_dir}backups" > "${user_report_dir}/backup_stats.txt"
fi
done
# Function to analyze common Nginx and PHP configurations
analyze_common_configs() {
log "Analyzing common configurations..." "${BLUE}"
# Nginx config analysis
if [ -d "$COMMON_NGINX" ]; then
mkdir -p "${OUTPUT_DIR}/common_configs/nginx"
cp -r "$COMMON_NGINX/sites-enabled" "${OUTPUT_DIR}/common_configs/nginx/"
nginx -T 2> "${OUTPUT_DIR}/common_configs/nginx/nginx_config_test.txt" || true
fi
# PHP config analysis
if [ -d "$COMMON_PHP" ]; then
mkdir -p "${OUTPUT_DIR}/common_configs/php"
for version in "$COMMON_PHP"/*; do
if [ -d "$version" ]; then
version_num=$(basename "$version")
php_info_file="${OUTPUT_DIR}/common_configs/php/phpinfo_${version_num}.txt"
php -v > "$php_info_file" 2>&1
php -i >> "$php_info_file" 2>&1
fi
done
fi
# Main execution
main() {
log "Starting CloudPanel analysis..." "${GREEN}"
# Create output directory structure
mkdir -p "${OUTPUT_DIR}/users"
# Run analysis functions
analyze_user_sites
# Generate summary report
echo "CloudPanel Analysis Summary"
echo "=========================="
echo "Analysis Date: $(date)"
echo ""
echo "Analysis Components:"
echo "1. CloudPanel Database"
echo "2. Bash Configurations"
echo "3. User Sites Structure"
echo "4. Common Configurations"
echo ""
echo "Output Directory: ${OUTPUT_DIR}"
} > "${OUTPUT_DIR}/summary.txt"
log "Analysis complete. Results are in: ${OUTPUT_DIR}" "${GREEN}"
main "$@"
Script 2
touch analyze_logs.sh
nano analyze_logs.sh
#paste the script from below.
chmod +x analyze_logs.sh
sudo ./analyze_logs.sh
#!/bin/bash
set -euo pipefail
RED='\033[0;31m'
GREEN='\033[0;32m'
YELLOW='\033[1;33m'
BLUE='\033[0;34m'
NC='\033[0m'
# Timestamp and Output Directory
mkdir -p "${OUTPUT_DIR}/traffic_analysis"
mkdir -p "${OUTPUT_DIR}/security"
mkdir -p "${OUTPUT_DIR}/file_changes"
# Log function
log() {
# Function to analyze IP addresses and traffic patterns
analyze_traffic_patterns() {
local user_dir="$1"
local username="$2"
local analysis_dir="${OUTPUT_DIR}/traffic_analysis/${username}"
mkdir -p "$analysis_dir"
log "Analyzing traffic patterns for user: ${username}" "${BLUE}"
for access_log in "${user_dir}logs/nginx"/*access.log; do
if [ -f "$access_log" ]; then
# Top IP addresses
log "Extracting top IP addresses..." "${GREEN}"
awk '{print $1}' "$access_log" | sort | uniq -c | sort -rn | head -n 20 > \
"${analysis_dir}/top_ips.txt"
# HTTP Status Distribution
log "Analyzing HTTP status codes..." "${GREEN}"
awk '{print $9}' "$access_log" | sort | uniq -c | sort -rn > \
"${analysis_dir}/http_status_distribution.txt"
# Error Requests Analysis (4xx and 5xx)
log "Analyzing error requests..." "${GREEN}"
awk '$9 ~ /^[45]/ {print $1,$9,$7,$time_local}' "$access_log" | \
tail -n 100 > "${analysis_dir}/error_requests.txt"
# Traffic by Hour
log "Analyzing traffic patterns by hour..." "${GREEN}"
awk '{print $4}' "$access_log" | cut -d: -f2 | sort | uniq -c | \
sort -n > "${analysis_dir}/traffic_by_hour.txt"
# Large File Transfers
log "Identifying large file transfers..." "${GREEN}"
awk '$10 > 1000000 {print $7,$10,$1}' "$access_log" | \
sort -nr -k2 | head -n 20 > "${analysis_dir}/large_transfers.txt"
# Suspicious Patterns
log "Checking for suspicious patterns..." "${GREEN}"
echo "=== SQL Injection Attempts ==="
grep -i "union\|select\|insert\|delete\|update" "$access_log" | tail -n 20
echo -e "\n=== Script Injection Attempts ==="
grep -i "<script\|alert(" "$access_log" | tail -n 20
echo -e "\n=== File Upload Attempts ==="
grep -i "\.php\|\.jsp\|\.asp" "$access_log" | tail -n 20
} > "${analysis_dir}/suspicious_patterns.txt"
fi
done
fi
# Function to analyze outbound connections
analyze_outbound_traffic() {
log "Analyzing outbound connections..." "${BLUE}"
local outbound_dir="${OUTPUT_DIR}/traffic_analysis/outbound"
mkdir -p "$outbound_dir"
# Current outbound connections
if command -v ss &> /dev/null; then
ss -ntp 2>/dev/null | grep ESTAB > "${outbound_dir}/current_connections.txt"
elif command -v netstat &> /dev/null; then
netstat -ntp 2>/dev/null | grep ESTABLISHED > "${outbound_dir}/current_connections.txt"
fi
# Analyze varnish cache connections if available
log "Analyzing Varnish cache connections for ${username}..." "${GREEN}"
ls -lah "${user_dir}logs/varnish-cache" > "${outbound_dir}/varnish_${username}.txt"
fi
done
# Function to analyze user activities and security
analyze_security() {
log "Analyzing security events..." "${BLUE}"
local security_dir="${OUTPUT_DIR}/security"
# Recent user logins
last -n 100 > "${security_dir}/recent_logins.txt"
# Failed login attempts
echo "=== Failed SSH Attempts ==="
grep "Failed password" /var/log/auth.log 2>/dev/null | tail -n 50
echo -e "\n=== Invalid Users ==="
grep "Invalid user" /var/log/auth.log 2>/dev/null | tail -n 50
echo -e "\n=== Failed sudo ==="
grep "sudo.*COMMAND" /var/log/auth.log 2>/dev/null | tail -n 50
} > "${security_dir}/failed_attempts.txt"
# CloudPanel specific security events
sqlite3 "${CLP_DB}" <<EOF > "${security_dir}/clp_security_events.txt"
.mode column
.headers on
SELECT event_name, user_name, datetime(created_at, 'unixepoch') as event_time
FROM event
WHERE event_name LIKE '%login%' OR event_name LIKE '%fail%' OR event_name LIKE '%error%'
ORDER BY created_at DESC LIMIT 100;
EOF
fi
# Function to analyze file modifications
analyze_file_changes() {
log "Analyzing file modifications..." "${BLUE}"
local changes_dir="${OUTPUT_DIR}/file_changes"
if [ "$username" != "clp" ]; then
log "Analyzing file changes for user: ${username}" "${GREEN}"
echo "=== Recently Modified Files ==="
find "${user_dir}" -type f -mtime -1 -ls 2>/dev/null | \
awk '{print $11,$7,$8,$9,$10}' | tail -n 50
echo -e "\n=== Recently Created Files ==="
find "${user_dir}" -type f -ctime -1 -ls 2>/dev/null | \
echo -e "\n=== Large Files (>100MB) ==="
find "${user_dir}" -type f -size +100M -ls 2>/dev/null | \
} > "${changes_dir}/${username}_file_changes.txt"
fi
done
# Monitor CloudPanel specific files
if [ -d "/home/clp" ]; then
log "Analyzing CloudPanel file changes..." "${GREEN}"
echo "=== CloudPanel Configuration Changes ==="
find "/home/clp/services" -type f -mtime -7 -ls 2>/dev/null
echo -e "\n=== Recent Database Changes ==="
ls -la "/home/clp/htdocs/app/data/db.sq3"
} > "${changes_dir}/cloudpanel_changes.txt"
fi
# Main execution
main() {
log "Starting enhanced log analysis..." "${GREEN}"
# Process each user's directory
analyze_traffic_patterns "$user_dir" "$username"
fi
done
analyze_security
echo "CloudPanel Analysis Summary Report"
echo ""
echo "1. Traffic Analysis"
echo " - Top IP addresses"
echo " - HTTP status distribution"
echo " - Error requests (4xx and 5xx)"
echo " - Traffic patterns by hour"
echo ""
echo "2. Security Analysis"
echo " - Recent logins"
echo " - Failed login attempts"
echo " - Suspicious activities"
echo ""
echo "3. File Changes"
echo " - Recent modifications"
echo " - New files"
echo " - Large files"
echo ""
echo "4. Outbound Traffic"
echo " - Current connections"
echo " - Varnish cache analysis"
} > "${OUTPUT_DIR}/analysis_summary.txt"
main "$@"
