Advanced Guide: Deploying Rootless Tailscale with DERP Server Integration
This comprehensive guide details the implementation of a rootless Tailscale configuration, including optional DERP server deployment and SOCKS5 proxy integration. This setup enables secure mesh networking without requiring root privileges, making it ideal for restricted environments and container-based deployments.
Core Components Overview
  • Tailscale daemon (tailscaled) in userspace networking mode
  • Optional SOCKS5 proxy configuration for service access
  • Custom DERP server deployment for optimized peer-to-peer connectivity
1. Tailscaled Deployment in Userspace Mode
1.1 Binary Acquisition
Obtain the static tailscaled binary from the official repository:
curl -O https://pkgs.tailscale.com/stable/tailscale_*_amd64.tgz
tar xzf tailscale_*_amd64.tgz
1.2 Daemon Configuration
Initialize the tailscale daemon with userspace networking:
# Environment Configuration
export TAILSCALED_SOCKET="/tmp2/${USER}/tailscaled.sock"
export TAILSCALED_STATE="${PWD}/tailscaled.state"
# Launch Daemon
./tailscaled \
  --tun=userspace-networking \
  --state="${TAILSCALED_STATE}" \
  --socket="${TAILSCALED_SOCKET}"
1.3 Client Operations
Execute tailscale commands using the custom socket:
# Authentication
./tailscale --socket="${TAILSCALED_SOCKET}" login
# Network Status
./tailscale --socket="${TAILSCALED_SOCKET}" status
# Additional Operations
./tailscale --socket="${TAILSCALED_SOCKET}" <command>
2. SOCKS5 Proxy Integration
2.1 Enhanced Daemon Configuration
Extend the daemon configuration with SOCKS5 proxy support:
./tailscaled \
  --socket="${TAILSCALED_SOCKET}" \
  --socks5-server=localhost:21055 \
  --outbound-http-proxy-listen=localhost:21055
2.2 Proxychains Configuration
Create a proxychains configuration file (proxychains.conf):
# Core Settings
strict_chain
proxy_dns
tcp_read_time_out 15000
tcp_connect_time_out 8000
# Proxy Definition
[ProxyList]
socks5 127.0.0.1 21055
2.3 Proxy Usage Examples
# Proxified SSH Connection
proxychains -f proxychains.conf -q ssh user@tailnet-host
# Shell Environment Proxification
proxychains -f proxychains.conf -q "${SHELL}"
3. DERP Server Implementation
3.1 Prerequisites
Install the DERP server implementation:
go install tailscale.com/cmd/derper@main
3.2 TLS Certificate Generation
Generate self-signed certificates for DERP server:
# Configuration
export DERP_DOMAIN="derp.example.com"  # or IP address
export DERP_PORT=28443
export STUN_PORT=23478
# Certificate Generation
openssl req -x509 \
  -newkey rsa:4096 \
  -sha256 \
  -days 3650 \
  -nodes \
  -keyout "${DERP_DOMAIN}.key" \
  -out "${DERP_DOMAIN}.crt" \
  -subj "/CN=${DERP_DOMAIN}" \
  -addext "subjectAltName=DNS:${DERP_DOMAIN}"
3.3 DERP Server Deployment
Launch the DERP server with custom configuration:
~/go/bin/derper \
  --hostname="${DERP_DOMAIN}" \
  -http-port=-1 \
  -a=:${DERP_PORT} \
  -stun-port=${STUN_PORT} \
  -certmode manual \
  -certdir "${PWD}" \
  -c derp_config.json
3.4 ACL Configuration
Add the DERP server configuration to your Tailscale ACLs:
  "derpMap": {
    "Regions": {
      "900": {
        "RegionID": 900,
        "RegionCode": "CUSTOM_DERP_01",
        "Nodes": [
            "Name": "custom-derp-1",
            "RegionID": 900,
            "DERPPort": 28443,
            "STUNPort": 23478,
            "HostName": "derp.example.com",
            "InsecureForTests": true
Security Considerations
  1. Certificate Management: In production environments, replace self-signed certificates with properly validated TLS certificates.
  2. Socket Permissions: Ensure proper file permissions on the UNIX socket to prevent unauthorized access.
  3. State File Security: Protect the state file as it contains sensitive configuration data.
  4. DERP Security: Disable InsecureForTests in production and implement proper TLS certificate validation.
  1. Connection Issues:
    • Verify DERP server accessibility
    • Check firewall rules for DERP and STUN ports
    • Validate TLS certificate configuration
  2. Proxy Problems:
    • Confirm SOCKS5 server functionality
    • Verify proxychains configuration
    • Check application compatibility with SOCKS5 proxying
