Adminsyspro/proxcenter-ui releases
New releases of adminsyspro/proxcenter-ui are posted here automatically.
Join @releases-proxcenter to get a DM and a bell for every release.
adminsyspro/proxcenter-ui v1.5.1
ProxCenter v1.5.1
Micro-segmentation improvements and fixes.
New
  • Micro-segmentation shared between several clusters under one policy.
  • sFlow traffic volumes on the micro-segmentation map, matrix, Sankey and dashboard; the Network Flows tab is removed.
  • IP filter of zone members, set from ProxCenter on the native Proxmox IP filter, with addresses disputed between two zones named.
  • Firewall logs collected by a forwarder installed on each Proxmox node, with a Logs tab on Proxmox VE connections.
  • A constellation view of the micro-segmentation map, with internal flows, a filter of several zones, nodes and guests, and the inside of a zone on a double click.
  • Deploy Ceph on a cluster that has none, then manage its pools and OSDs from the Ceph cockpit, with a Logs tab.
  • Proxmox VE 9.3 managed multipath for iSCSI, with LUN paths and their health.
  • Cross-cluster migration without a disk copy when the target cluster reaches the same storage as the stopped guest.
  • Update a Proxmox Backup Server from its Updates tab: checks, options, live progress and a report.
  • Service accounts: API identities of a tenant that survive the person who created their tokens, with per-tenant API self-service.
  • SSO can require a mapped group to sign in, and a failed compliance check can be accepted as a risk.
  • Live progress of a failback reverse sync pass in Site Recovery, with readable failures.
  • A platform status tab and a retention for the notification history.
  • The built-in image catalogue can be hidden from a tenant, and the VLAN trunks of a NIC are shown and edited.
  • An in-app rolling update of the HA images for clusters already converted.
Improvements
  • Proxmox VE 9.3: restore over another guest, migration tunnel, negative node affinity.
  • Migrations check from the Proxmox node that it reaches the VMware source before the run.
  • Warm migration copies disks with more than 2 TiB of data, and reports what nbdkit logged when a copy fails.
  • The upstream OpenVDDK 0.7.5 runtime kit is installed instead of a ProxCenter build.
  • A started migration is followed, and a VMID clash is fixed from the row that reports it.
  • The target storage of a migration is honoured for HA-managed guests.
  • Compliance scans share one collection per connection, read Proxmox VE more gently and build their PDFs in the background; NIST SP 800-171 moves to Revision 3.
  • Turning the cluster firewall on is refused when it would cut traffic between the nodes.
  • Security groups count the guests that really carry them, and are detached before deletion.
  • Node tabs and charts stay reachable on short screens.
  • Guest agent exec results are read from qemu-ga 10 and later.
Fixes
  • Destroying a guest keeps the disks another cluster may own on a shared storage.
  • An absolute disk resize counts as the growth it asks for, and a creation reserves its vDC quota until its task ends.
  • Site Recovery orphans are cleaned after a connection is deleted, and a connection still in use cannot be deleted.
  • A failback after a point-in-time failover no longer stalls.
  • A guest that is gone answers 404.
  • HA clusters deployed by the wizard render PDF reports.
Security and isolation
  • Alert rule and report writes need a write permission (alerts.manage, new reports.manage).
  • 2FA enforcement reaches open sessions, and the storage upload route requires 2FA enrollment.
  • The onboarding status no longer returns counts.
  • API routes are checked by a test that fails when a route has no permission check within reach.
  • The report renderer runs WeasyPrint 70 on a hash-pinned tree, and every published image is scanned.
  • HA images: etcd 3.5.36, HAProxy 3.4 LTS and current Alpine bases.
next 16.4.6, jose 6.2.18, undici 8.13.0, ws 8.23.0, next-intl 4.15, MUI X 9.18, The Go Programming Language 0.62.0, GitHub Actions updates. The image package layer is rebuilt once a day.
Upgrading
Pull the images. Five schema migrations ship with this release, applied by the frontend entrypoint at first boot.
  • Reports need reports.manage to be generated, deleted or scheduled. Built-in roles get it; a custom role gets it when it already holds reports.view and alerts.manage.
  • Firewall log forwarders need port 6344/tcp from the Proxmox nodes to ProxCenter. An install updated with docker compose pull keeps its previous compose file: take the new docker-compose.enterprise.yml or run the installer again.
  • HA clusters converted before this release keep their rendered compose and HAProxy files: the image update reaches them from the HA tab, the forwarder relay and the PDF renderer address of the orchestrator do not.
  • The InfluxDB volume is no longer used: sFlow volumes are stored in PostgreSQL.
Docker Images
docker pull ghcr.io/adminsyspro/proxcenter-frontend:v1.5.1
docker pull ghcr.io/adminsyspro/proxcenter-orchestrator:v1.5.1
docker pull ghcr.io/adminsyspro/proxcenter-weasyprint:v1.5.1
Verify the images
gh attestation verify oci://ghcr.io/adminsyspro/proxcenter-frontend:v1.5.1 --owner adminsyspro
The CycloneDX SBOM of the frontend image is attached below.
Air-gapped bundle
Community: the proxcenter-community-1.5.1.tar.gz asset below. Enterprise: your account on proxcenter.io, Air-gapped tab. Guide: Air-gapped installation | ProxCenter Documentation
