version: "3"
adguard:
image: adguard/adguardhome:latest
container_name: adguard
- /volume1/docker/adguard/config:/opt/adguardhome/conf
- /volume1/docker/adguard/data:/opt/adguardhome/work/data
restart: always
macvlan-host:
ipv4_address: 192.168.178.2 # change it to your internal IPv4 exisitng network
ipv6_address: xxxx:xxxx:xxxx:xxxx::2 # fixed external IPv6/64 prefix + your own private /64 identifier
macvlan-bridge:
ipv4_address: 172.16.0.2 # randon private ipv4 address which is not in the same segment as above
ipv6_address: xxxx:xxxx:xxxx:xxxx::2 # random ipv6 address which has not the same prefix as above
macvlan-host:
enable_ipv6: true
driver: macvlan
driver_opts:
parent: eth0
ipam:
config:
- subnet: "192.168.178.0/16" # paste in your existing private subnet address (look on your router)
gateway: "192.168.178.1" # paste in your existing private gateway address (look on your router)
ip_range: "192.168.178.2/32" # the ip range for addresses for this macvlan. Past in your choosen address from 12 (/32 means only one to use)
- subnet: "xxxx:xxxx:xxxx:xxxx::/64" # paste in your existing private ipv6 subnet address (look on your router)
gateway: "xxxx:xxxx:xxxx:xxxx::1" # paste in your existing private ipv6 gateway address (look on your router)
ip_range: "xxxx:xxxx:xxxx:xxxx::2/128" # the ip range for ipv6 addresses for this macvlan. Past in your choosen address from 13 (/128 means only one to use)
macvlan-bridge:
enable_ipv6: true
driver: bridge
ipam:
config:
- subnet: "172.16.0.0/24" # paste in a random private subnet address
gateway: "172.16.0.1" # paste in a random private gateway address
ip_range: "172.16.0.2/32" # the ip range for addresses for this bridge. Paste in your choosen address from 15 (/32 means only one to use)
- subnet: "xxxx:xxxx:xxxx:xxxx::/64" # paste in a random private ipv6 subnet address
gateway: "xxxx:xxxx:xxxx:xxxx::1" # paste in a random private ipv6 gateway address
ip_range: "xxxx:xxxx:xxxx:xxxx::2/128" # the ip range for ipv6 addresses for this bridge. Past in your choosen address from 16 (/128 means only one to use)
how to specify both IPv6 and IPv4 addresses for one container
coredns:
image: coredns/coredns
container_name: coredns
command: -conf /data/Corefile
- 53:53/udp
- 53:53/tcp
- 9153:9153/tcp
- ./coredns:/data:ro
sapling:
ipv4_address: 172.16.238.5
ipv6_address: 2404:xxxx:4314:d::5
sapling:
driver: bridge
driver_opts:
com.docker.network.bridge.gateway_mode_ipv6: "routed"
enable_ipv6: true
ipam:
driver: default
config:
- subnet: 172.16.238.0/24
gateway: 172.16.238.1
- subnet: 2404:xxxx:4314:d::/64
gateway: 2404:xxxx:4314:d::1
