first let me thank you for your Application and good documentation. It was a lot of work to provide this piece of software.
I got everything up and running (just a minor issue with the folder for the captcha.yaml. When I change the folder in Traefik, Captcha HTML is shown, but it is marked as missing in your Application).
But: Using your captcha-Example and set up for turnstile, I can see the Cloudflare-Check, but after check was successful, nothing happens, e.g. it does not forward to the page I want to go.
Any idea what I am missing?
In internal/api/handlers/captcha.go line 105-106, the {{.RedirectURL}} is replaced with empty string, making the form submit to nowhere. Fix: Either set a proper redirect URL in the template replacement OR ensure the CrowdSec bouncer plugin is properly handling captcha validation at the middleware level. The template also needs data-callback="captchaCallback" with a 500ms delay instead of immediate submission (reference the official plugin’s captcha.html).
