GitHub issue tailscale-access #3, opened by
traefikeron GitHub
The plugin was not imported into Traefik Plugin Catalog.
Cause:
failed to get sources: failed to get code (archive): failed to get archive link: unexpected status code: 200 OK
Traefik Plugin Analyzer will restart when you will close this issue.
If you believe there is a problem with the Analyzer or this issue is the result of a false positive, please fill an issue on piceus repository.
Discuss it here. Status, fixes and code review stay on GitHub.
