Tailscale doesn't work like implemented (newt-cloudflare-tailscale-integration #2)
:octopus: GitHub issue newt-cloudflare-tailscale-integration #2, opened by DennisGaida on GitHub
Tailscale can’t work right now and just keeps restarting. The culprit is newt-cloudflare-tailscale-integration/scripts/tailscale-up.sh at 55d702317a51a0035bb22a3bbe87709b356b9fa6 · hhftechnology/newt-cloudflare-tailscale-integration · GitHub or getent hosts app since app isn’t defined.
In have replaced the check with the following and it works: target_ip=$(tailscale status --json | jq -r '.Self.TailscaleIPs[0]'). Whether this is the best way to go about this, I am not sure.
:speech_balloon: Discuss it here. Status, fixes and code review stay on GitHub.
will look into this
