# Self-hosted community bulletin, morning, Thu 15 Oct 2026
Big news and drama
Ubuntu 26.10 “Stonking Stingray” is out. It finishes the move to Rust coreutils and adds post-quantum-ready package signing, more TPM-backed full-disk encryption, Linux 7.3 and GNOME 51. It only gets 9 months of support, so stay on 26.04 LTS for servers.
Microsoft Defender for Endpoint now runs on Linux desktops. It needs Plan 2 or Microsoft 365 E5/E7, so it’s aimed at corporate fleets, not homelabs.
Flock’s CEO says people who want less crime should be ready to give up privacy. He defended Flock’s licence-plate reader network. Critics point to a Roseville study that found a 71% failure rate across about 1,500 alerts.
New or trending projects
VoiceStudio is a fully local, open-source ElevenLabs alternative under AGPL-3.0. It does voice cloning, dubbing, dictation and audiobooks, and has a local API and MCP. It has about 68k stars, with roughly 3k added today.
Flipflop keeps lasting device-to-device tunnels open for files, links and text, over Bluetooth, LAN or the internet. It’s written in Rust and built on Iroh.
OpenCode 2.0 runs as one background service shared by its terminal, web and desktop apps. It adds an MCP “code mode” and background subagents, but 1.x plugins won’t work with it.
Notable releases
Libreboot 26.10 makes full UEFI support through EDK2 the default and adds 233 Chromebooks as source-only targets. Read the changelog twice before you reflash.
Nextcloud 35.0.2, 34.0.5 and 33.0.10 fix remember-me cookies and a bug where a reshare could get more permissions than the person resharing had.
ZITADEL 4.19.5 adds a consent screen to device flow, and Login V2 now relies more on ZITADEL_SESSION_COOKIE_SECRET. If you copied the example value from the docs, replace it with a random secret.
Glance, copyparty and n8n patches: Glance fixes its Reddit widget, copyparty fixes a minor advisory, and n8n now uses a fresh XML parser for each webhook request.
Sonarr v5 preview 5.0.0.2608 moves to .NET 10.0.13. Try it on a test instance only.
Community discussions
“Wanted to download an ISO, ended up writing a kernel exploit.” A TP-Link EAP770 was silently corrupting downloads because of a DMA cache bug, so the author rooted it with an AI-assisted exploit. It makes a strong case for buying hardware that can run OpenWrt.
An investigation says reports from EU “Chat Control” scanning are run through Palantir Foundry at NCMEC. NCMEC says it runs the software locally and Palantir can’t see the data.
Security quick hits
Vercel’s sandbox challenge found a Linux kernel networking flaw that can be reached from inside KVM guests. It can leak host memory or run code as root on the host. CVEs are still pending, so Proxmox and KVM hosts should watch for kernel updates.
“SneakPeek”: a crafted HTML file in a repo could get Claude Code Desktop’s preview pane to read local secrets like SSH keys (CVSS 8.7). It’s fixed in Claude Desktop 1.30096.1 and later.
