OTLP connection refused (traefik-log-dashboard discussion #50)
:speech_balloon: GitHub discussion traefik-log-dashboard #50 in Help, started by heeelga on GitHub
OTLP_ENABLED is set to true, the traefik container is able to rearch the backend, however the traefik log shows connection refused messages. Inside of the backend container, the ports does not seem to be routed.
{“time”:“2025-08-08T07:51:58Z”,“caller”:“log/log.go:245”,“level”:“debug”,“message”:“2025/08/08 07:51:58 handler.go:30: traces export: Post "http://backend:4318/v1/traces\”: dial tcp 172.25.0.3:4318: connect: connection refused"}
Inside the backend container:
~ # nc -vz 127.0.0.1 4318 || true
~ # nc -vz 127.0.0.1 4317 || true
~ # nc -vz 127.0.0.1 3001 || true
127.0.0.1 (127.0.0.1:3001) open
curl http://localhost:3001/api/otlp/status results in: 404 page not found
:speech_balloon: Join in here or on GitHub.
share your compose file
heeelga commented on GitHub:
Sure, its just the basic one you provided with your project:
proxy:
driver: bridge
dashboard-network:
driver: bridge
traefik-logs:
traefik-certs:
maxmind-data:
Enhanced Dashboard Backend with OTLP support
backend:
build: ./backend
container_name: ${BACKEND_CONTAINER_NAME:-traefik-dashboard-backend-otlp}
- dashboard-network
- “3001:3001” # API port
- “4317:4317” # OTLP GRPC port
- “4318:4318” # OTLP HTTP port
- ${TRAEFIK_LOG_PATH:-./logs}:/logs:ro
- maxmind-data:/maxmind:ro
# Basic configuration
- PORT=3001
- TRAEFIK_LOG_FILE=/logs/access.log
  # MaxMind GeoIP configuration
  - USE_MAXMIND=${USE_MAXMIND:-true}
  - MAXMIND_DB_PATH=/maxmind/GeoLite2-City.mmdb
  - MAXMIND_FALLBACK_ONLINE=${MAXMIND_FALLBACK_ONLINE:-true}
  # OTLP Configuration
  - OTLP_ENABLED=${OTLP_ENABLED:-true}
  - OTLP_GRPC_PORT=${OTLP_GRPC_PORT:-4317}
  - OTLP_HTTP_PORT=${OTLP_HTTP_PORT:-4318}
  # Performance tuning
  - GOGC=${GOGC:-50}
  - GOMEMLIMIT=${GOMEMLIMIT:-500MiB}
healthcheck:
  test: ["CMD", "wget", "--quiet", "--tries=1", "--spider", "http://localhost:3001/health"]
  interval: 30s
  timeout: 10s
  retries: 3
deploy:
  resources:
    limits:
      cpus: '1.0'
      memory: 512M
    reservations:
      cpus: '0.2'
      memory: 128M
Dashboard Frontend
frontend:
build: ./frontend
container_name: ${FRONTEND_CONTAINER_NAME:-traefik-dashboard-frontend-otlp}
- dashboard-network
- proxy
- “${FRONTEND_PORT:-3000}:80”
- BACKEND_SERVICE=${BACKEND_SERVICE_NAME:-backend}
- BACKEND_PORT=${PORT:-3001}
depends_on:
- backend
labels:
# Traefik labels for routing (optional)
- “traefik.enable=true”
- “traefik.docker.network=traefik-network”
- “traefik.http.routers.dashboard-frontend.rule=Host(dashboard.localhost) || Host(dashboard.example.com)”
- “traefik.http.routers.dashboard-frontend.entrypoints=websecure”
- “traefik.http.services.dashboard-frontend.loadbalancer.server.port=80”
healthcheck:
test: [“CMD”, “wget”, “–quiet”, “–tries=1”, “–spider”, “http://localhost/”]
interval: 30s
timeout: 10s
retries: 3
deploy:
resources:
limits:
cpus: ‘0.5’
memory: 256M
reservations:
cpus: ‘0.1’
memory: 64M
MaxMind GeoLite2 database updater
maxmind-updater:
image: alpine:latest
container_name: maxmind-db-updater
restart: “no”
- maxmind-data:/data
- MAXMIND_LICENSE_KEY=${MAXMIND_LICENSE_KEY:-your-license-key-here}
command: >
sh -c "
apk add --no-cache wget tar …
hhftechnology replied in a thread on GitHub to heeelga:
Visualizing Your Traefik Logs: Deploying the Traefik Log Dashboard with the Pangolin Stack - #16 by hhf.technoloy
