system
August 4, 2025, 6:09pm
GitHub discussion traefik-log-dashboard #46 in Help , started by fhptech on GitHub
With a working 1.0.5 configuration, changing to the 1.0.6 release, no logs are read but no errors shown in logs that I can see. Was there a breaking change or something I missed? I’m using a mounted NFS folder with two subfolders, both listed for log reading. Snipped below
env:
- name: NODE_ENV
value: production
- name: PORT
value: "3001"
- name: TRAEFIK_LOG_FILE
value: /logs/logs/,/logs/vlogs/
volumeMounts:
- name: traefik-logs
mountPath: /logs/
nfs:
server: fhp-afs-nfs.fhpaschen.com
path: /nfsvol/traefik/
Join in here or on GitHub .
system
August 5, 2025, 2:41pm
2
hhftechnology commented on GitHub :
try latest 1.0.7
system
August 5, 2025, 6:47pm
3
fhptech commented on GitHub :
Same result with ‘latest’ (no 1.0.7 tag yet)
[GIN-debug] [WARNING] Creating an Engine instance with the Logger and Recovery middleware already attached.
[GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
- using env: export GIN_MODE=release
- using code: gin.SetMode(gin.ReleaseMode)
[GIN-debug] GET /api/stats --> main.getStats (4 handlers)
[GIN-debug] GET /api/logs --> main.getLogs (4 handlers)
[GIN-debug] GET /api/services --> main.getServices (4 handlers)
[GIN-debug] GET /api/routers --> main.getRouters (4 handlers)
[GIN-debug] GET /api/geo-stats --> main.getGeoStats (4 handlers)
[GIN-debug] GET /api/geo-processing-status --> main.getGeoProcessingStatus (4 handlers)
[GIN-debug] POST /api/set-log-file --> main.setLogFile (4 handlers)
[GIN-debug] POST /api/set-log-files --> main.setLogFiles (4 handlers)
[GIN-debug] GET /api/maxmind/config --> main.getMaxMindConfig (4 handlers)
[GIN-debug] POST /api/maxmind/reload --> main.reloadMaxMindDatabase (4 handlers)
[GIN-debug] POST /api/maxmind/test --> main.testMaxMindDatabase (4 handlers)
[GIN-debug] GET /api/websocket/status --> main.getWebSocketStatus (4 handlers)
[GIN-debug] GET /health --> main.healthCheck (4 handlers)
[GIN-debug] GET /ws --> main.handleWebSocket (4 handlers)
2025/08/05 16:52:20 Server running on port 3001
2025/08/05 16:52:20 MaxMind configuration: {Enabled:false DatabasePath:/maxmind/GeoLite2-City.mmdb FallbackToOnline:true DatabaseLoaded:false DatabaseError:}
2025/08/05 16:52:20 WebSocket clients tracking enabled
2025/08/05 16:52:20 Setting up monitoring for log file(s): [/logs/logs/ /logs/vlogs/]
2025/08/05 16:52:20 Loading last 0 log entries from /logs/logs/
Strangely also now, 1.0.5 is are entering a crashbackoff loop without anything unusual being logged
2025/08/05 18:44:24 Server running on port 3001
2025/08/05 18:44:24 Setting up monitoring for 2 log path(s)
2025/08/05 18:44:24 MaxMind configuration: {Enabled:false DatabasePath:/maxmind/GeoLite2-City.mmdb FallbackToOnline:false DatabaseLoaded:false DatabaseError:}
[GIN-debug] GET /api/geo-processing-status --> main.getGeoProcessingStatus …
system
August 6, 2025, 3:52am
4
env:
- name: NODE_ENV
value: production
```not needed
we are using go for backend
system
August 6, 2025, 5:40am
5
try thr new dev tag and please report back. it should scan dir.
system
August 7, 2025, 1:09pm
6
With :dev tag. Same results
2025/08/07 13:08:14 Server running on port 3001
2025/08/07 13:08:14 MaxMind configuration: {Enabled:false DatabasePath:/maxmind/GeoLite2-City.mmdb FallbackToOnline:false DatabaseLoaded:false DatabaseError:}
2025/08/07 13:08:14 WebSocket clients tracking enabled
2025/08/07 13:08:14 Setting up monitoring for log file(s): [/logs/logs/ /logs/vlogs/]
2025/08/07 13:08:14 Loading last 0 log entries from /logs/logs/
2025/08/07 13:08:14 Starting background geo processing...
system
August 8, 2025, 2:39pm
7
Saw in the other issue/thread that the ghrc images weren’t updated. I tried the 1.1.0 image from dockerhub and can report that the logs are loading fine in my configuration now. Glad to see the OTLP support also. Thanks!
