I got MWM running on my VPS together with Pangolin … I got it going but i am running into an issue. It seems like when I define Pangolin as “Active Data Source” any rule I do set up in Pangolin itself is completly being ignored. Prefix Match and Stripping is being ignored and also any rules to bypass authentification.
Is this except behaviour or am I doing something wrong?
My goal was basically to have Pangolin do most of the lifting and just use MWD for the finer stuff.
I can “force” the Pangolin rules to be applied again by raising the priority in the pangolin gui higher but in that case every rule set in MWM gets ignored.
Currently however I am struggling to get MWM to apply any rules at all to pangolin routes (even when MWM has a priority of 500 and pangolin sitting at 200).
Rules are being ignored even something as simple as { "permanent": false, "regex": "https://sub.example.com/123455678", "replacement": "https://google.com" }
I can’t get the linebreaks correctly on git for some reason right now.
I think this is a configuration mistake on my side as I haven’t changed the configuration from original deployment to the new one for v4, I will try to look into it on the weekend.
