Existing Middlewares not detected (middleware-manager discussion #37)
:speech_balloon: GitHub discussion middleware-manager #37 in Ideas, started by woutervanelten on GitHub
Hi there,
At least for Traefik stand alone version, existing middlewares are not detected.
I have some middlewares declared in Docker labels and some in dynamic files (IP Allowlist, Rewrite, etc.).
The Routes and Services are detected.
And in the Traefik dashboard I can also see that the middlewares are applied.
But Middleware-Manager says “Not protected” and also doesn’t list the applied middlewares outside of middleware-manager.
Can this be fixed or integrated?
:speech_balloon: Join in here or on GitHub.
you are right it doesn’t scan existing middleware. i have a plan to add it as a feature but i am currently focus on streamlining it. so may be in version v3
woutervanelten commented on GitHub:
Ok, great.
Thanks!
philalama commented on GitHub:
I would also be interested in this feature. If I want to use Middleware-Manager as the “one-stop-solution” to manage traefik middlewares, it would be great so see the ones already configured manually. E.g. middlewares set on entryPoints should be listed on each resource that uses this entryPoint
