GitHub issue traefik-log-dashboard #217, opened by
nomanderaon GitHub
It would appear that both the dashboard and the agent may support an environmental variable simply named PORT.
This can result in issues if the same ENVARS are shared e.g. via a common .env file.
For the avoidance of confusion, clashes and to better fall inline with other variable naming I request that each image allow the use of a unique ENVAR e.g. TRAEFIK_LOG_DASHBOARD_PORT or similar.
Discuss it here. Status, fixes and code review stay on GitHub.
