CVE-2026-98432: patching the kernel, and which MPTCP mitigations actually hold up
Last verified 2 November 2026. Distribution status changes daily — check your own vendor tracker before you act on the table below.
There is a Linux kernel bug doing the rounds that deserves a slot in this week’s maintenance window rather than next quarter’s. CVE-2026-98432 is a use-after-free in the IPv4 TCP handshake, scored 9.8 by the kernel CVE team, present in every kernel from 4.4 onward. A remote, unauthenticated attacker can reach it with a single SYN packet. Your application never sees a byte of it — the vulnerable code runs before the connection is ever handed to userspace.
The reason it got attention isn’t just the score. On 27 October, Anthropic’s Frontier Red Team published a write-up in which a Claude research model built a working remote-root exploit against a server exposing a Multipath TCP (MPTCP) listener. Two stages: about 48 minutes of retrying to leak a kernel pointer past KASLR, then roughly five more minutes to hijack a callback and run a command as root. A lost race costs the attacker one failed handshake and doesn’t crash the box, so they can retry indefinitely.
No exploitation in the wild has been reported, it is not in CISA’s KEV catalogue, and the exploit code isn’t public. That’s a window to patch, not a reason to relax.
What the bug actually is
A TCP SYN can carry IPv4 options — Record Route, Timestamp. The kernel stores those options with the pending connection request in ireq_opt, and when the handshake completes, tcp_v4_syn_recv_sock() hands the pointer to the child socket without copying. Now the request socket and the child socket share one allocation. If the client retransmits the SYN and another CPU picks it up, that CPU builds a SYN-ACK from the same options in ip_options_build(). If the child socket is torn down in the meantime, inet_sock_destruct() frees the options with a plain kfree() — and the SYN-ACK path reads freed memory.
Eric Dumazet’s fix is about as small as kernel fixes get: two kfree() calls become kfree_rcu() in net/ipv4/af_inet.c and net/ipv4/tcp_ipv4.c, so the memory waits out an RCU grace period before it goes away. It landed upstream on 5 October and reached the stable branches on 11 and 15 October.
Two things follow from that description, and they matter for how you prioritise.
First, the bug is in plain TCP, not in MPTCP. MPTCP is only the configuration Anthropic’s exploit used. Disabling MPTCP removes the demonstrated path; it does not remove the bug. Go’s security team said this explicitly, and added the uncomfortable corollary: systems with no MPTCP listeners may still be vulnerable to similar attacks.
Second, there’s a narrower second path through request-socket migration, gated on net.ipv4.tcp_migrate_req=1 or a BPF_SK_REUSEPORT_SELECT_OR_MIGRATE program. Both are off by default. Worth confirming they’re still off, but that’s a check, not a project.
The Go wrinkle
MPTCP on Linux is opt-in: an application has to ask for IPPROTO_MPTCP when it creates the socket. For years that made it safe to assume you weren’t running it.
Go broke that assumption. Since Go 1.24, Go programs enable MPTCP on listening sockets by default where the kernel supports it — the multipathtcp GODEBUG defaults to 2, meaning listeners only, dialers stay plain TCP. So a Go API gateway, reverse proxy, or internal service built with a recent toolchain may be holding an MPTCP listener nobody asked for. Build the same source with Go 1.23 and it isn’t.
That’s the whole reason to go look rather than assume. EL 8, 9 and 10 ship with MPTCP compiled in but disabled by default, so a stock RHEL-family host can’t produce an MPTCP listener unless someone turned it on. Distributions that follow the upstream default of 1 are a different story.
1. Patch the kernel and reboot
This is the fix. Everything below is a stopgap.
| Distribution | Status (2 Nov 2026) |
| Upstream stable | Fixed: 5.10.272, 5.15.223, 6.1.190, 6.6.159, 6.12.113, 6.18.56, 7.2.10, 7.3. Branches older than 5.10 are EOL upstream — distro fix only |
| Debian 12 / 13 | Fixed: linux 6.1.190-1 (DLA-4841-1), 6.12.113-1 (DSA-6568-1) |
| RHEL 8.10 / 9.8 / 10.2 | Advisories dated 1 Nov: 4.18.0-553.182.1.el8_10, 5.14.0-687.64.1.el9_8, 6.12.0-211.72.1.el10_2. Only counts once your stream actually syncs them — EUS and older minor streams, OpenShift and RHEL CoreOS are not confirmed |
| AlmaLinux 8.10 / 9.8 / 10.2 | Fixed, verified in production 2 Nov |
| Oracle Linux UEK | Fixed 16 Oct (ELSA-2026-500397/8/9). The RHCK kernel has no errata yet |
| Amazon Linux 2 / 2023 | Fixed, 24–30 Oct |
| SUSE | Fixed for SLES 16.0 and 15 SP4–SP6 LTSS; SP7 and Leap 15.6 still open |
| Ubuntu 22.04 / 24.04 / 26.04 / 26.10 | No fix shipped. Target versions are named on the tracker — 5.15.0-203.213, 6.8.0-149.149, 7.0.0-43.43, 7.3.0-10.10 — but not released |
| Ubuntu 16.04 / 18.04 / 20.04 | Vulnerable, no fix in progress (Ubuntu Pro only) |
Three traps. uname -r against the upstream table tells you nothing, because distro kernels carry backported fixes under their own version numbers — compare the installed package against your vendor’s advisory. Installing the package isn’t remediating: the new kernel only runs after a reboot, and unattended-upgrades won’t reboot for you. And “the vendor shipped it” is not the same as “my host can get it” — a RHEL advisory dated 1 November says nothing about the EUS stream you’re pinned to, whether your mirror has synced, or whether the package is in the repo you’re subscribed to. Check dnf updateinfo list --cve CVE-2026-98432 on the box itself rather than trusting the advisory date. If you run KernelCare or Canonical Livepatch, check the livepatch actually lists this CVE (kcarectl --patch-info | grep CVE-2026-98432 returns nothing → not patched, whatever the update run said).
2. While you wait
If your distribution hasn’t shipped — Ubuntu, as of this writing — you have three levers, in descending order of how much they actually cover.
Drop inbound TCP packets carrying IPv4 options
This is the widest one, and it’s the one Red Hat, AWS and AlmaLinux all point at. The trigger needs IPv4 options in the SYN, and ordinary traffic essentially never sends them, so a filter on the IP header length costs you nothing in practice:
bash
sudo nft -f - <<'EOF'add table ip cve_2026_98432delete table ip cve_2026_98432table ip cve_2026_98432 { chain prerouting { type filter hook prerouting priority -300; policy accept; meta l4proto tcp ip hdrlength > 5 counter drop }}EOF
AlmaLinux tested this on 8, 9 and 10 and says it works alongside firewalld and is safe to re-run. It’s also the only option here that doesn’t care whether anything on the host uses MPTCP, which is why it’s the one to reach for first.
Caveats: it doesn’t survive a reboot unless you fold it into your persistent nftables config, and it should go in both input and forward if the host routes traffic. Traffic between containers on the same host can bypass a prerouting rule. And skip it if your network relies on CIPSO security labels, which travel in IP options.
Turn MPTCP off
bash
sudo sysctl -w net.mptcp.enabled=0echo 'net.mptcp.enabled = 0' | sudo tee /etc/sysctl.d/90-no-mptcp.conf
Keep it in its own drop-in file so deleting one file reverts it when the patch lands. Ubuntu builds MPTCP into the kernel, so blacklisting a module won’t do anything — the sysctl is the only lever.
The part that catches people out: net.mptcp.enabled is per network namespace, and a new namespace starts at 1. Setting it on the host does not cover containers that have their own netns. Which brings us to the check script.
3. Finding the listeners you didn’t know about
This script walks the host and every running Docker container’s network namespace and prints MPTCP listeners that aren’t bound to loopback:
sh
#!/bin/shecho "== host"ss -Mlnp | tail -n +2 | grep -Ev '\s(127\.|\[::1\])'
host_ns=$(readlink /proc/1/ns/net)for c in $(docker ps -q); do name=$(docker inspect -f '{{.Name}}' "$c" | sed 's|^/||') pid=$(docker inspect -f '{{.State.Pid}}' "$c") if [ "$(readlink /proc/$pid/ns/net)" = "$host_ns" ]; then echo "== $name (host network, covered by the host check)" continue fi out=$(nsenter -t "$pid" -n ss -Mlnp | tail -n +2 | grep -Ev '\s(127\.|\[::1\])') [ -n "$out" ] && printf '== %s\n%s\n' "$name" "$out"doneecho "done"
bash
chmod +x mptcp-check.sh && ./mptcp-check.sh
Three notes on running it. It needs root (or at least CAP_SYS_ADMIN in the container namespaces) for nsenter and for -p to resolve process names. ss -M needs an iproute2 new enough to know the flag — if ss rejects it, that host is too old for this check and you’re probably fine by accident. And grep -Ev '\s...' relies on GNU grep; busybox grep in an Alpine-based image won’t understand \s, so swap in [[:space:]] if you port this into a container.
The host_ns comparison is the right instinct, by the way. Containers on network_mode: host genuinely share the host namespace, so nsenter into them would just print the host’s sockets twice and inflate your findings.
What the output means: every line is an MPTCP listener reachable from off-box. Empty output on a host with net.mptcp.enabled = 1 is genuinely good news — nothing has asked the kernel for MPTCP, so the demonstrated chain has nothing to aim at. It is not, however, an all-clear for the bug itself.
4. Answering the open questions
GODEBUG=multipathtcp=0 — is it valid? Yes, that’s the documented form, and the Go security team recommends exactly it. GODEBUG is a comma-separated list of key=value pairs, so the colon variant you saw floating around (multipathtcp: 0) is just wrong syntax and gets ignored — that’s the source of the conflicting reports. In Compose, both of these end up as the same environment variable:
yml
environment: - GODEBUG=multipathtcp=0
yml
environment: GODEBUG: multipathtcp=0
The second is plain YAML mapping syntax; the value is still the string multipathtcp=0. If a service already sets GODEBUG, append rather than replace: GODEBUG=something=1,multipathtcp=0.
Remember it only affects Go binaries started after the change, so the container needs recreating, not just restarting — and it does nothing for nginx, Postgres, Python, or anything else. You can also set it at build time with godebug multipathtcp=0 in the main module’s go.mod, which is more durable than an environment variable. Per-socket calls to SetMultipathTCP override all of it.
sysctls: net.mptcp.enabled: "0" in Compose — does it work? Yes, for containers with their own network namespace. net.mptcp.enabled is a namespaced sysctl, so Docker will accept it without --privileged. It does nothing for network_mode: host containers, since those inherit the host’s value anyway. And like any sysctls entry, it applies at container creation, so recreate the container. Keep the quotes on "0" — Docker wants a string.
“Can it be done without MPTCP, with raw TCP filtering?” Nobody has publicly demonstrated remote root without an MPTCP listener, but the bug lives in the plain IPv4 handshake path and the Go team won’t rule out other routes. So: MPTCP off is a meaningful reduction in exposure, not a fix. If you want a stopgap that doesn’t depend on the MPTCP question at all, use the nftables rule above.
5. Detection, while you’re in there
The trigger is a SYN carrying Record Route or Timestamp options, followed by retransmissions of the same SYN. Anthropic’s leak stage ran for 48 minutes, so a real attempt looks like a long burst of option-bearing SYNs from one source to one listener, with a pile of failed handshakes. Legitimate traffic with IP options is rare — CIPSO/NetLabel networks and nmap --ip-options are the usual false positives.
NetFlow and cloud flow logs can’t see this, because IP options aren’t in the flow record. You need packet-level visibility, placed before anything that terminates TCP — a proxy that terminates and re-originates protects the backend; an L4 pass-through does not. Correlate a network hit with kernel-side signals on the same host for confidence.
6. Appliances and embedded Linux
Appliances are the hard part of this, and they need their own plan, because not one of the levers above is available on them. Think NAS boxes, hypervisors, firewall and UTM appliances, VPN concentrators, IPMI and BMC controllers, printers, storage arrays, set-top boxes, industrial gateways, medical devices.
What they have in common: a vendor kernel you can’t replace, no package manager, no /etc/sysctl.d you can reach, no nftables, and a firmware cycle measured in quarters — if the vendor ships anything at all.
What to check.
Start with uname -r on the device, if you can get a shell on it at all. Anything below 4.4 isn’t affected by the main path — that covers a lot of older gear on 3.10 and 4.1, and the same reason RHEL 7 and CentOS 7 are in the clear. Kernels from 4.4 through 5.4 have no upstream fix and never will, because those branches are end-of-life; a vendor backport is the only route that exists. Then ask whether the box is IPv4-reachable from somewhere untrusted. If its management UI lives only on a management VLAN, this is an insider and supply-chain question rather than an internet one. Almost every appliance listens on IPv4 TCP regardless — 443, 22, 445, 548, 623, 5900.
What you can’t do. Patch it, disable MPTCP on it, or add firewall rules to it. If the appliance has no usable firewall, that’s the end of the on-box options.
What you can do. Move the compensating control to the network. The IP-options rule from section 2 works at an edge as well as on a host, and one router or firewall in front of a segment covers every appliance behind it — provided all traffic to those appliances genuinely passes through that edge. That’s the single highest-value action for an appliance fleet. Behind it: management interfaces onto a management VLAN, nothing published to the internet, and access restricted to the people and systems that need it.
On embedded Linux specifically — Yocto, Buildroot, OpenWrt, vendor SDK kernels — a few things worth knowing before you assume either the best or the worst.
Check whether MPTCP is compiled in at all: zcat /proc/config.gz | grep MPTCP, or the kernel .config in your build tree. Most Yocto and OpenWrt default configurations ship # CONFIG_MPTCP is not set. That removes the chain Anthropic demonstrated, and it means net.mptcp.enabled doesn’t exist on the device at all — but it does not remove the bug, which sits in the ordinary IPv4 TCP path.
Most of these devices are behind NAT and single- or dual-core. The race needs two CPUs processing the same connection at the same moment, so a single-core device is a substantially harder target for this specific race. Take that as a factor that works in your favour, not as a control you can rely on or design around.
If you have the source and a toolchain, the fix itself is portable: it’s a two-line change to kfree_rcu() in inet_sock_destruct() and tcp_v4_reqsk_destructor(). Backporting it into a BSP tree pinned to 4.19 or 5.4 is realistic engineering work, and for a fleet of identical devices it’s often cheaper than waiting on the vendor. OpenWrt users should track the current release branch rather than the target they originally flashed.
For the rest, the honest answer is that the vendor will ship something in weeks or months, or won’t. Segment them, put the IP-options drop in front of them, keep them off the internet, and revisit when firmware lands.
What not to conclude
A host with MPTCP disabled and the nftables rule loaded is less exposed, not patched. Neither mitigation touches the two kfree() calls. The only thing that does is the kernel package and the reboot that follows it — so put the internet-facing hosts first in line, and treat everything in section 2 as something you remove from /etc/sysctl.d and nftables.conf once uname -r shows a fixed kernel.
Sources
- Linux kernel CVE / fix commit
e3f33b0a1d89, “ipv4: free inet_opt and ireq_opt after an RCU grace period” (Eric Dumazet) - Go Security Team, “Protecting against CVE-2026-98432 when using Go programs”, 29 Oct 2026 — groups.google.com/g/golang-announce
- Go documentation, GODEBUG history and
multipathtcpvalues — go.dev/doc/godebug - LWN, “Remote code execution on Linux systems with multipath TCP”, 30 Oct 2026
- Red Hat RHSB-2026-016 and RHSA-2026:93412 / 93413 / 93414 / 93415
- AlmaLinux, “CVE-2026-98432: Patched kernels available in testing”, 30 Oct 2026
- Ubuntu security tracker, CVE-2026-98432
- Anthropic Frontier Red Team, “Discovering and exploiting vulnerabilities in critical, real-world software with Claude”, 27 Oct 2026
